MHB Odd Composite Property 1: A Unique Factorization Rule
  • Thread starter Thread starter yourskadhir
    Composite Property
For any odd composite number 'N', the relationship between u = (N-1)/2 and v = u+1 establishes that u^2 ≡ v^2 (mod p) if and only if p is a factor of N. This is derived from the equivalence 0 ≡ 2u + 1 (mod p), leading to the conclusion that N = kp for some integer k. Conversely, if N = kp, the calculations show that u^2 and v^2 also satisfy the modular equivalence. The discussion emphasizes that p cannot be 2, highlighting the unique properties of odd composites. This unique factorization rule provides insights into the behavior of odd composite numbers in modular arithmetic.
yourskadhir
Hi,
For any odd composite 'N', let u = (N-1)/2, v = u+1, then u^2(mod p) = v^2(mod p) if and only if 'p' is a factor of 'N'.
Mathematics news on Phys.org
Re: Odd composite property1
suppose that:
$u^2 \equiv v^2\ (\text{mod }p)$
since $v = u+1$ this is the same as saying:
$0 \equiv 2u + 1\ (\text{mod }p)$
that is:
$2u + 1 = kp$ for some integer $k$.
recalling that $u = \frac{N-1}{2}$, we see that:
$2u + 1 = N = kp$, in which case $p$ divides (is a factor of) $N$.
on the other hand, suppose that $N = kp$.
then:
$u^2 = \frac{N^2 - 2N + 1}{4}$ while:
$v^2 = \left(\frac{N+1}{2}\right)^2 = \frac{N^2 + 2N + 1}{4}$
so:
$v^2 - u^2 = \frac{4N}{4} = N = kp$ thus:
(it might be instructive to see why p cannot be 2).
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
