Odd delayed choice interferometer interpretations
In summary, the photon is considered to either travel as a particle or wave depending on whether or not a beam splitter is present. Scientists concluded that the photon reacts retroactively to the apparatus being changed, which led them to assert that the photon makes a 'decision' on how to travel.
Thomasphysicist
This thread is about my not understanding the conclusion that scientists came to that the photon makes a 'decision' on how to travel.
In a simple interferometer experiment, a photon displays interference fringes only when a second beam splitter is present. According to Wiki, this led scientists to assert that the photon 'decides' to travels as a particle when there is no beam splitter and a wave when there is a beam splitter.
The delayed choice version of the experiment demonstrates that the photon shows interference fringes, even if the second beam splitter is placed after the photon is already on it's way. Given the initial idea that the photon decides to travel as either a particle or wave depending on the apparatus, this led some scientists to conclude that the photon must act retroactively- if a 2nd beam splitter is placed, the photon goes back in time and decides to travel as a wave, whereas it was initially traveling as a particle (before the 2nd beam splitter was placed).
Now, either I'm missing something very simple or these scientists were- I see no reason to assert that the photon makes any kind of decision in the first place. Going back to the simple interferometer experiment, I understand that the photon must be said to travel as a wave when the beam splitter is present- how else do the interference fringes appear- but I do not see any reason that it must be said to travel as a particle when the beam splitter is not present. Why not posit that it travels as a wave in both instances? I mean, in the simple interferometer exp, without the 2nd beam splitter you wouldn't expect interference fringes from a wave as the waves are traveling in perpendicular directions. If this is the case, then you can say that the photon travels as a wave in both instances and therefore there is no photon 'decision'. In the delayed choice version, this means there is no need to posit retroactivity.
Where have I gone wrong?
Reading wiki :smile:
Seriously, kidding aside, there are some good wikipedia articles and some not so good ones. Without a pointer to the specific article (which is why PF has a rule that references must be cited!) we can't tell whether you're misunderstanding one of the good ones or being misled by one one of the not-so-good ones.
The idea that a particle can be either a particle or a wave, let alone that it "decides" which, is no part of the modern understanding of quantum mechanics. It's one of those things that drifted into the popular imagination decades ago when the theory was less well-developed, and like an invasive weed, once established it's very hard to get rid of.
Likes bhobba
Just to elaborate on what Nugatory said you may find the following useful:
http://arxiv.org/pdf/quant-ph/0609163.pdf
I shouldn't have to say this but from discussions about that paper in the past, it clearly states its using wave in the sense of wave-function which is different from what is usually thought of as a wave.
Thanks
Bill
Good point. http://en.wikipedia.org/wiki/Wheeler's_delayed_choice_experiment
You can skip to the simple interferometer section.
In short it says experimenters considered the photon to travel in a particle like fashion in the first instance but wave like in the second. The last line in that section says that the delayed choice results led experimenters to conclude the photon reacts retroactively to the apparatus being changed.
However, since the experimenters would have known that with the 2nd beam splitter, the photon exhibits wave like nature, followed by particle like nature upon detection (i.e. the way it behaves apparently alters), why then could they not conclude that similarly, the photon exhibits wave like nature, followed by particle like nature upon detection without the 2nd beam splitter. Instead they insist the photon exhibits particle like nature throughout, leading to the need to introduce 'decision making' and retrocausality.
That is, what forces them to consider the photon as exhibiting particle like behaviour in the 'no-2nd beam splitter' instance?
The real answer is its neither wave or particle - the question is meaningless.
If you want a correct analysis of the experiment here it is:
http://quantum.phys.cmu.edu/CQT/chaps/cqt20.pdf
But you need beyond a pop-sci understanding to get to grips with it. For that studying the whole text its from is really the only solution:
http://quantum.phys.cmu.edu/CHS/histories.html
Thanks
Bill
I seem to have trouble getting my point across as everyone seems to think I'm asking how to correctly interpret QM. Which I'm not. What I'm doing is trying to understand the evolution of thought/theory over the last century and how it has been affected by various experimental results."Observing that photons show up in equal numbers at the two detectors, experimenters generally say that each photon has behaved as a particle from the time of its emission to the time of its detection" - From the wiki article
"in the first case the photon is said to "decide" to travel as a particle and in the second case it is said to "decide" to travel as a wave" - From the same article
What I'm wondering is why, back then, these scientists regarded the photon as behaving as a particle (rather than a wave) prior to detection, given that it was both unnecessary and introduced further complications such as 'decision making' and retro causality.
Thanks for the 'myths' paper btw, very interesting.
A better way of putting it is why were they happy to concede that the photon travels down both paths of the interferometer in one instance, but not happy to concede that is does so in the other instance?
Its a hangover from its history (particularly De-Broglies hypothesis) and the way its usually taught. Modern textbooks like Ballentine that is my bible on QM are carefull to tell it correctly - but its at graduate level. And the correct explanation for things like Schroedinger's equation via symmetry is rather involved and not really suitable for undergraduates who may get bogged down in the math.
Thanks
Bill
Sorting out QM took time. Even now our understanding is evolving eg the PBR theorem.
Thanks
Bill
Likes Derek Potter
I have not tried to find source of this "photon decides to be particle or wave" model but my bet would be that it's straw man. As you say It's unnecessary complicated.
You've found one of the not-so-good wikipedia articles. Take a look at the Talk page associated with the article (always wise and often entertaining when dealing with wikipedia) you will see that the article is not derived from Wheeler's serious scientific publications, but rather from the popularizations that he wrote for a non-technical audience. The author of that part of the wikipedia article is probably unaware of the distinction.
Some of the experimental results that led scientists to question the neat classical physics of the 19th century did indeed suggest that something could behave as a wave one moment and a particle the next; and that's how the notion slipped into the discussion. But the experiment being discussed in that wikipedia article is not one of the convincing ones, and you are right to be question it.
Related to Odd delayed choice interferometer interpretations
1. What is the Odd Delayed Choice Interferometer (ODCI)?
The Odd Delayed Choice Interferometer is an experimental setup used to study the behavior of particles, such as photons, in a quantum system. It consists of two interferometers, where one interferometer is used to manipulate the path of the particles, while the other interferometer is used to observe the interference pattern created by the particles.
2. What is the purpose of the ODCI experiment?
The purpose of the ODCI experiment is to investigate the concept of wave-particle duality in quantum mechanics. It aims to understand how particles behave as both waves and particles, and how the act of observation can affect their behavior.
3. What are the different interpretations of the ODCI experiment?
There are several interpretations of the ODCI experiment, including the Copenhagen interpretation, the many-worlds interpretation, and the transactional interpretation. These interpretations offer different explanations for the behavior of particles in the experiment and the role of observation in quantum systems.
4. How does the ODCI experiment challenge our understanding of quantum mechanics?
The ODCI experiment challenges our understanding of quantum mechanics by demonstrating the bizarre and counterintuitive behavior of particles at the quantum level. It also raises questions about the role of consciousness and observation in shaping reality, and the fundamental nature of particles as both waves and particles.
5. What are the implications of the ODCI experiment?
The implications of the ODCI experiment extend beyond the realm of quantum mechanics and have implications for our understanding of reality. It challenges our traditional notions of cause and effect, and raises questions about the nature of time and the role of consciousness in shaping the universe.
