Odd extension: Show that if [K(a) : K] is odd, then K(a) = K(a^2)
The discussion focuses on proving that if the extension degree [K(a) : K] is odd, then K(a) equals K(a^2). The argument presented establishes that K(a^2) is a subset of K(a), and since a is a root of the polynomial X^2 - (a^2), the degree [K(a) : K(a^2)] must be less than or equal to 2. It is concluded that this degree cannot be 2, leading to the result that [K(a) : K(a^2)] is 1, thus confirming K(a) = K(a^2). Additionally, there is a discussion on finding a counterexample for the converse statement, with examples provided from finite fields and polynomial roots.
Hill
[M:K]=[M:L][L:K]
My solution:
1. ##K(a^2) \subseteq K(a)##.
2. ##a## is zero of the quadratic polynomial ##X^2 - (a^2)##, i.e., ##[K(a) : K(a^2)] \leq 2##.
3. It is not 2 because ##[K(a) : K] = [K(a) : K(a^2)][K(a^2) : K]## is odd.
4. Thus, it is 1, and hence ##K(a) = K(a^2)##.
Is this solid enough?
Hill said:
Homework Statement: Show that if [K(a) : K] is odd, then K(a) = K(a^2)
Looks ok to me. I would only add that ##X^2-(a^2)\in K(a^2)[X]## since it is important where the coefficients are from.
Of course. Thank you.
Now I struggle with finding a counterexample to the statement: if ##K(a) = K(a^2)##, then ##[K(a) : K]## is odd.
How about ##\mathbb{Z}_2[X] / \bigl\langle X^2+X+1 \bigr\rangle ##? We have ##a^2=a+1## so ##K(a)=K(a^2)## and the degree is two.
fresh_42 said:
the degree is two
Is the degree what we are looking for? We need a dimension of ##K(a)## over ##K## to be even, but I don't even know how to find this dimension for ##K=\mathbb{Z}_2[X] / \bigl\langle X^2+X+1 \bigr\rangle##.
The polynomial is irreducible and prime, so ##K## is a field. ##K## is a field with four elements, i.e. a two-dimensional vector space over ##\mathbb{Z}_2## and so of degree two. It cannot be one since ##X^2+X+1## is irreducible. That the degree is therefore two is your own argument from post #1. What else could it be?
https://de.wikiversity.org/wiki/Endlicher_Körper/4/Operationstafeln
well, [C:R} = 2, and I bet you can find z such that R(z) = R(z^2) = C. (C = R(i), R = reals, i^2 = -1.). or adjoin a new cube root w of 1 to Q. ohh. this is fresh's example, since x^3-1 = (x-1)(x^2+x+1). i.e. w^3 = 1 implies w = (w^2)^2, so Q(w) = Q(w^2).
You can also replace ##\mathbb{Z}_2## by ##\mathbb{Q}## and it still works since ##a^2=-a-1.## You can calculate the roots of the polynomial as ##\dfrac{1}{2}\left(-1\pm i \sqrt{3}\right)## and work it out explicitly. And if you want higher even degrees, consider ##X^{2n}+X+1.##
