Odd or Even? - Arbritrary Period Fourier Series
In summary: The hairy coefficients are because the functions ##u_n(x)## are not orthogonal because they are not even functions. They are orthogonal only on [0,3], not on [-3,3]. If we only use the odd functions ##v_n(x)##, the coefficients are zero for n even and can be expressed in terms of ##A_n## for n odd. But the series for the extended function is not the same as the series for the function on ##[0,3]##.That's because the series of odd functions is a sine series, whereas the series of even functions is a cosine series. So if you want to use a cosine series, you have to
Charge2
Hello everyone,
I'm new to the great field that is Fourier analysis, and have a question about the way in which to determine if the function is a odd or even function.
Given the function, of one period
f(x) = { x; 0 <= x < =1, 1; 1 < x < 2, (3 -x); 2 <= x <= 3:
Is there a definitive way in which you can determine if this function will be even about the y-axis or odd about the x axis.
f(-x) = f(x) (even)
f(-x) = -f(x) (odd)
Drawing this function I immediately thought that it was even, although on second thought the function could indeed go down into the 3rd quadrant in the Cartesian coordinate system when repeated in the negative x direction. So I turned to numerical analysis.
Is it correct to use the relevant equations as follows?
f(-x) = { -x; 0>= -x>=-1, 1; -1>=-x>=-2, (3 + x); -2>=-x>=-3.
As you would then have a negative slope going from -1 to 0, the constant remains the same in the negative x direction and a positive slope in the -3 to -2 boundaries.
Wouldn't this imply that it is an even function? Or, the only way to really know is if the function boundary conditions that are initially given, includes the area in the negative x direction?
Charge2 said:
Hello everyone,
f(-x) = f(x) (even)
f(-x) = -f(x) (odd)
If you look at your f(x) on [0,3] as the basic building block of a periodic function with period 3, the result is naturally even. That happens in this case only because of the special form of f(x) on [0,3], being symmetric about x = 1.5.
So because the function is mirrored at the period T= 3/2 therefore x = 3/2, it is even..? I ran a program through Matlab to doubly check if the function was even and check the coefficients calcs, and the b_n coefficient did not equate to 0- with some quite "hairy" coefficients at that.
@Charge2: You need to understand that the function you gave is neither even nor odd. In fact it doesn't make sense to ask whether it is even or odd because it is only defined on ##[0,3]##. And for the same reason, it isn't periodic either. What you can do is talk about extending the definition of the function into an even or odd periodic function. For example, if you add to your definition that$$
f(x) = -3-x, ~-3\le x \le -2,~f(x) = -1,~-2\le x \le -1,~f(x) = x,~-1\le x \le 0$$ and periodic thereafter you would have an odd function of period ##6##. This is the function that a half range sine series of the given function would represent.
Just repeating the graph as in post #2 would give an even extension of the function of period ##3##. If you use the half range cosine expansion on the given function it would represent the even extension and would be calculated as a function of period ##6## even though it is also of period ##3##.
[Edit, added]: I just noticed that your OP states the given function on ##[0,3]## represents one period. So it is defined on the whole line and periodic and is even. Nevertheless, I think you may find my comments above useful, at least I hope so.
No software can tell you if the extended function is even, odd, or neither. YOU can decide to make it even, or you can extend it as an odd function (but not in any natural way). If you apply the Fourier series formulas to your function without further thought, you are tacitly assuming that the function is extended outside [0.3\ in some way.
I did the same thing in Maple, and for expansion functions ##u_0 = \sqrt{1/3}## and ##u_n = \sqrt{2/3} \, \cos(2 \pi n x/3)##, ##v_n = \sqrt{2/3} \, \sin(2 \pi n x/3)## for ##n = 1, 2, 3, \ldots## (which are orthonormal on ##[0,3]##) the coefficients in
[tex] f(x) = A_0 u_0 + \sum_{n=1}^{\infty}( A_n u_n(x) + B_n v_n(x) ) [/tex]
are given by
[tex] A_n = \int_0^3 f(x) u_n(x) \, dx, \;\; B_n= \int_0^3 f(x) v_n(x) \, dx [/tex]
for all ##k##.
Maple gets
[tex] B_n = \frac{3 \sqrt{6}}{4 \pi^2 n^2} \left( \sin \left(\frac{2 \pi n}{3}\right) + \sin \left(\frac{4 \pi n}{3} \right) \right) [/tex]
Although this does not look like 0, when you evaluate it at positive integer ##n## you do, actually, get 0! You can even prove this analytically, just by looking at the locations of the points at angles ##2 \pi n/3## and ##4 \pi n/3## on the unit circle.
Therefore, the Fourier series of ##f(x)## is a Fourier-cosine series, exactly as you would expect of an even function. Is that what was bothering you?
Thanks Ray and LcKurtz, the series has been solved with the help of your clarifications. And yes distinguishing between with what Fourier series to use was a major issue. I made the mistake of thinking that if function was given piecewise and not extended then you would have to take into account the possibility of the function going down into the lower quadrants. This of course was just neglecting the explicit period given, thus I needed to repeat the function as written. To throw that in the mix I'm using two textbooks to learn the material and they both have slightly different notation. Which was confusing when starting this out. I ended up using the period of w = 2pi/3 and doubled each integral for ease of calculation from 3/2 to 0. Anyway, I calculated the coefficients, and got a_0 = 4/6 and a_n = -9/n^2*2*pi^2 for n = 1,2,4,5,7.. which when graphed, fitted my initial sketch of the function with great accuracy. It was very pleasing to see this and I am just starting to see the beautiful mathematics of Fourier analysis. I'm now going to try my hand at more functions with the common periods of pi to -pi then move onto more arbitrary length functions for now just to to let the process and let it all soak in then learn about transforms. Again thanks. :).
Related to Odd or Even? - Arbritrary Period Fourier Series
1. What is an "Odd or Even - Arbitrary Period Fourier Series?"
An Odd or Even - Arbitrary Period Fourier Series is a mathematical representation of a function that is expressed as a sum of sine and cosine functions with arbitrary periods. It is used to analyze the periodicity and symmetry of a function, and can be used to approximate any periodic function with a finite number of terms.
2. How is the "Odd or Even - Arbitrary Period Fourier Series" different from a regular Fourier Series?
The main difference between the two is that a regular Fourier Series has a fixed period, while an Odd or Even - Arbitrary Period Fourier Series has an arbitrary period. This means that the function being represented in the latter may have a different period for each term, allowing for a more flexible and accurate approximation.
3. What is the purpose of using an Odd or Even - Arbitrary Period Fourier Series?
The main purpose of using this type of Fourier Series is to analyze the symmetry and periodicity of a function that may not have a fixed period. It can also be used to approximate a function with a high degree of accuracy, making it useful in various fields such as signal processing, image analysis, and data compression.
4. How is the "Odd or Even - Arbitrary Period Fourier Series" calculated?
The coefficients of an Odd or Even - Arbitrary Period Fourier Series are calculated using the Fourier coefficients formula, which involves integrating the function being represented with respect to the arbitrary period. The resulting coefficients are then used in the series to approximate the function.
5. What are some real-world applications of the "Odd or Even - Arbitrary Period Fourier Series"?
This type of Fourier Series has many real-world applications, such as in signal processing for analyzing non-periodic signals, in image processing for image compression and reconstruction, and in data analysis for identifying patterns in non-periodic data. It is also used in music and sound engineering for analyzing and synthesizing complex waveforms.
