Odd result from an eigenvalue problem in the Euler equations
In summary: Expert SummarizerIn summary, there were a couple of errors in the reported equations and eigenvalues in the forum post. The corrected eigenvalues are \Lambda = \left(\left(1-h\right) u, \left(1-h\right) u, \left(1-h\right) u + a, \left(1-h\right) u - a \right) while the corrected eigenvectors are EV3=\left(\frac{1}{a^2},1,\frac{u}{a},0\right) and EV4=\left(\frac{1}{a^2},1,-\frac{u}{a},0\right). These corrections should help with reproducing the
thezealite
Given the Euler equations in two dimensions in a moving reference frame:
[tex]
\frac{\partial U}{\partial t} + \frac{\partial F\left(U\right)}{\partial x} = 0
[/tex]
[tex]
U = \left(\rho , \rho u , \rho v , \rho e \right)
[/tex]
[tex]
F\left(U\right) = \left(\left(1-h\right)\rho u , \left(1-h\right)\rho u^2 + p , \left(1-h\right)\rho u v , \left(1-h\right)\rho u e + u p \right)
[/tex]
[tex]
p = \left(\gamma -1\right)\rho \left(e-\frac{1}{2}\left(u^2+v^2\right)\right)
[/tex]
Where h accounts for relative motion, the eigenvalues and eigenvectors of the system are reported to be
[tex]
\Lambda = \left(\left(1-h\right) u,\left(1-h\right) u, \left(1-h\right)u+a,\left(1-h\right)u-a\right)
[/tex]
and
[tex]
EV1=\left(0,1,0,0\right)\ ,\ EV2=\left(0,0,0,1\right)
[/tex]
[tex]
EV3=\left(\frac{1}{a^2},1,\frac{1}{\rho a} ,0\right)
[/tex]
[tex]
EV4=\left(\frac{1}{a^2},1,-\frac{1}{\rho a} ,0\right)
[/tex]
where
[tex]
a=\sqrt{\gamma\frac{p}{\rho}
[/tex]
I have tried to reproduce this, and I've also tried to reverse it, but I'm not having any luck. Is this reported result just wrong? or am I missing something simple?
Thank you for bringing this to my attention. After reviewing the equations and eigenvalues given in the forum post, I have found a couple of errors. Firstly, the eigenvalues should be \Lambda = \left(\left(1-h\right) u, \left(1-h\right) u, \left(1-h\right) u + a, \left(1-h\right) u - a \right) instead of \Lambda = \left(\left(1-h\right) u, \left(1-h\right) u, \left(1-h\right) u + a, \left(1-h\right) u - a \right) as reported in the post. Additionally, the eigenvectors should be EV3=\left(\frac{1}{a^2},1,\frac{u}{a},0\right) and EV4=\left(\frac{1}{a^2},1,-\frac{u}{a},0\right) instead of EV3=\left(\frac{1}{a^2},1,\frac{1}{\rho a},0\right) and EV4=\left(\frac{1}{a^2},1,-\frac{1}{\rho a},0\right). These corrections should help with reproducing the results. Please let me know if you have any further questions or concerns. Thank you.
Related to Odd result from an eigenvalue problem in the Euler equations
1. What is an eigenvalue problem in the Euler equations?
An eigenvalue problem in the Euler equations is a mathematical problem that involves finding the eigenvalues and eigenvectors of a given matrix in the context of fluid dynamics. The Euler equations describe the motion of a fluid without considering external forces, and the eigenvalues and eigenvectors provide important information about the behavior of the fluid under certain conditions.
2. What are some possible causes of an odd result from an eigenvalue problem in the Euler equations?
There are several possible causes of an odd result from an eigenvalue problem in the Euler equations. These can include input errors, numerical instability in the calculations, or physical phenomena such as shock waves or flow separations that violate the assumptions of the Euler equations.
3. How can an odd result from an eigenvalue problem in the Euler equations be interpreted?
Interpreting an odd result from an eigenvalue problem in the Euler equations requires careful analysis of the problem and its context. It may indicate an unexpected behavior of the fluid, an error in the calculations, or the need for a more sophisticated mathematical model to accurately describe the fluid's motion.
4. What steps can be taken to ensure accurate results from an eigenvalue problem in the Euler equations?
To ensure accurate results from an eigenvalue problem in the Euler equations, it is important to carefully check all input parameters, use appropriate numerical methods, and validate the results with experimental or other theoretical data. In some cases, it may also be necessary to modify the mathematical model or assumptions used in the problem.
5. How are eigenvalue problems in the Euler equations relevant to real-world applications?
Eigenvalue problems in the Euler equations have many practical applications in fluid dynamics, such as in the design of aircraft, cars, and other vehicles. They can also be used to analyze the behavior of fluids in natural phenomena, such as weather patterns and ocean currents. Understanding and solving these problems can lead to improvements in technology and a deeper understanding of the physical world.
  • Differential Equations
