Odds of having exactly 12 correct answers out of 13
  • B
  • Thread starter Addez123
In summary, the odds are expressed as ##\frac {1}{3}^{12} * \frac {2}{3} * 13P1## and this equation is used to determine the number of ways to choose one incorrect line from a total of 13 lines. This is a binomial problem and should be solved using combinations instead of permutations because the order of the trials is already fixed. This means that ##13C1## is the correct choice for calculating the number of combinations, which is equal to ##13P1##.
Addez123
199
TL;DR Summary
On a lottery ticket you can choose 1,x,2 as answer on 13 questions.
Whats the odds that you get exactly 12 correct answers?
The odds are:
$$\frac {1}{3}^{12} * \frac {2}{3} * 13P1$$
And it's the 13P1 that I don't understand.
It's basically saying, among 13 lines, how many ways can 1 line be choosen to be incorrect?
Shouldn't 13P12 be equally correct?
That would be like saying: Among 13 lines, how many ways can 12 lines be choosen correctly?
My question is, why 13P1 and not 13P12?
Maybe it should be 13C1?
But that doesn't make sense since combinations doesn't regard order. Having first answer wrong isn't the same as having second answer wrong. So I should be using permutations, right?
It's a binomial problem, so it should be ##n C r##. If you have 13 trials. (labelled 1,2,3,...,13) and get ##r## successes, you have ##13 C r## combinations for possible sets of trials on which you succeed. It's a combination because we already fixed the order of the trials, so for anyone combination there is only one permutation that makes sense.
That is to say, for example, that the events that the successful trials are ##\{1,4,7\}## and ##\{4,1,7\}## are the same event, so we need only count it once! If all permutations of a set are equivalent in the context of our problem, then it is the number of combinations that is meaningful.
Luckily for you (or unluckily?), ##13C1 = 13P1##.
Likes Addez123
Related to Odds of having exactly 12 correct answers out of 13
What is the probability of getting exactly 12 correct answers out of 13?
The probability of getting exactly 12 correct answers out of 13 depends on the total number of possible outcomes and the number of desired outcomes. In this case, the total number of possible outcomes is 13C13 = 1 and the number of desired outcomes is 13C12 = 13. Therefore, the probability is 13/1 = 13.
How can I calculate the odds of getting exactly 12 correct answers out of 13?
To calculate the odds of getting exactly 12 correct answers out of 13, you can use the formula: odds = desired outcomes / (total outcomes - desired outcomes). In this case, the odds would be 13 / (13 - 13) = 13/0 = undefined. This means that the odds are 0, or that it is impossible to get exactly 12 correct answers out of 13.
What is the binomial distribution for the odds of getting exactly 12 correct answers out of 13?
The binomial distribution for the odds of getting exactly 12 correct answers out of 13 is a discrete probability distribution that describes the likelihood of getting a certain number of successes (in this case, 12 correct answers) in a fixed number of independent trials (in this case, 13 questions) with a known probability of success (in this case, 13/13 = 1).
Can the odds of getting exactly 12 correct answers out of 13 change?
No, the odds of getting exactly 12 correct answers out of 13 cannot change because the number of desired outcomes and the total number of possible outcomes are fixed. However, the probability of getting exactly 12 correct answers out of 13 may change if the total number of questions or the probability of success changes.
Is there a way to increase the odds of getting exactly 12 correct answers out of 13?
No, there is no way to increase the odds of getting exactly 12 correct answers out of 13. The only way to increase the probability of getting exactly 12 correct answers out of 13 is to increase the total number of questions or the probability of success.
  • General Math
