ODE Homogeneous Eqn - What did I do wrong this time?
In summary, the problem is that the student is stuck and does not know how to solve it. They have been trying to use homogeneous equations, but have not been able to get anywhere.
hahutzy
Hey guys, I've been stuck on this problem for a good hour... I have no idea how to finish it up.
Solve: dy/dx = 4y-3x / (2x-y)
Use homogeneous equations method.
Answer : |y - x| = c|y + 3x|5 (also y = -3x)
dy/dx = 4y-3x / (2x-y) * [(1/x) / (1/x)]
dy/dx = (4y/x)-3 / (2-(y/x))
let v = y/x
y = v(x) x
dy/dx = x dv/dx + v
x dv/dx + v = 4v-3 / (2-v)
x dv/dx = [4v-3 / (2-v)] - v
x dv/dx = 4v-3 -[2v-v2] / (2-v)
x dv/dx = 2v-3+v2] / (2-v)
dx/x = [(-v + 2) / (v^2 + 2v -3)] dv
dx/x = [(-5/4)(1/(v+3)) + (1/4)(1/(v-1))] dv (partial fractions)
Integrating both sides:
ln |x| = (1/4) ln |v-1| - (5/4) ln |v+3| + c
ln |x| = (1/4) [ln |v-1| - 5 ln |v+3| + c]
|x| = (1/4) exp {[ln |v-1| - 5 ln |v+3| + c]}
|x| = c |v-1| |v+3|-5
c|v+3|5 = |v-1|/|x|
|(y/x)-1| / |x| = c|(y/x)+3|5
Answer from book : |y - x| = c|y + 3x|5 (also y = -3x)
Much appreciated.
c|v+3|^5 = |v-1|/|x|
What happened to your 1/4! it disappeared
rework it, you should have
c|v+3|^-5 = |v-1|/|x|^4
rearrange and substitute
|x|^4 = |y/x-1|/c|y/x+3|^-5
factor out a 1/x^-5 from the right
|x|^4 = |y/x-1| / (c|y+3x|^-5 * 1/x^-5)
Multiply both sides
c 1/x = |y/x-1| / (|y+3x|^-5 )
c 1/x*(|y+3x|^-5 ) = |y/x-1|
facor out 1/x from the right and everything should be clear
- srry it was just quick and dirty but bear with me =]
Edit! O man sorry OP, that ^5 was ^-5, recheck your partial fractions, now it all works out
Thanks! But just making sure I'm getting this.
Code:
Multiply both sides
cx = |y/x-1| / (|y+3x|^5 )
cx*(|y+3x|^5 ) = |y/x-1|
Should be
Code:
Multiply both sides
c(1/|x|) = |y/x-1| / (|y+3x|^5 )
c*(|y+3x|^5 ) = |y/x-1|*|x|
c*(|y+3x|^5 ) = |y-x|
Right?
Also, is there any easy way to remember that (y/x + 3)^5 = (y + 3x)^5 * (1/x)^5?
Yes you're right (check my edit - my net is giving me probs) umm I don't know what to say, you just have to train yourself to spot it I guess.
Code:
Multiply both sides
Should be
Code:
Multiply both sides
Right?
I don't think it is a matter of "remembering". Just add the fractions:
y/x+ 3= y/x+ 3x/x= (y+ 3x)/x.
I understand that, however, what I can't wrap my head around is doing the same thing if the term is being raised to the power of something. Namely, ((y/x)+3)N where N is integer > 1
Let's say I had N=2, ((y/x)+3)2
Expanding gives y2/x2 + 6(y/x) + 9
y2/x2 + 6(y/x)(x/x) + 9(x2/x2)
[y2 + 6(yx) + 9x2] (1/x2)
(y+3x)2 (1/x)2
.'. ((y/x)+3)2 = (y+3x)2 (1/x)2
Now, since N=1 is true (intuitive), N=2 is true (proven), and you guys claim N=5 is also true, does that mean ((y/x)+3)N = (y+3x)N (1/x)N for 1..2..3..N by induction?
If the above is true, am I overthinking this all? Is it mathematically correct to do this:
((y/x)+3)N
((y/x)+3(x/x))N
((y+3x)/x))N
(y+3x)N (1/x)N
If the above is true, am I over thinking this all? Is it mathematically correct to do this:
((y/x)+3)N
((y/x)+3(x/x))N
((y+3x)/x))N
(y+3x)N (1/x)N
You are definitely over thinking this. What you've done is correct. Remember [itex]a^n/b^n=(a/b)^n, a^nb^n=(ab)^n[/itex]. It is just basic arithmetic.
I concur, definitely over thought. Simple algebra.
FAQ: ODE Homogeneous Eqn - What did I do wrong this time?
What is an ODE Homogeneous Equation?
An ODE Homogeneous Equation is a mathematical equation that involves a function and its derivatives, where the function is only dependent on one variable. It is called homogeneous because all the terms in the equation have the same degree.
How do I know if I did something wrong with my ODE Homogeneous Equation?
One way to check if you made a mistake is by verifying if all the terms in the equation have the same degree. If there are any terms with different degrees, it is likely that an error was made.
What are some common errors when solving ODE Homogeneous Equations?
Some common errors when solving ODE Homogeneous Equations include incorrect differentiation, forgetting to account for boundary conditions, and making algebraic mistakes while simplifying the equation.
How can I avoid making mistakes when working with ODE Homogeneous Equations?
To avoid making mistakes, it is important to double check your work and be meticulous with your calculations. It is also helpful to practice solving different types of ODE Homogeneous Equations to become more familiar with the process.
Can I use software to solve ODE Homogeneous Equations?
Yes, there are many software programs and online tools available that can solve ODE Homogeneous Equations. However, it is still important to have a basic understanding of the mathematical principles behind the solutions to ensure accuracy and to be able to interpret the results.
