MHB ODE system. Limit cycle; Hopf bifurcation.
Jason4
Problem:
The following two-dimensional system of ODEs possesses a limit-cycle solution for certain values of the parameter$a$. What is the nature of the Hopf bifurcation that occurs at the critical value of $a$ and state what the critical value is.
$\dot{x}=-y+x(a+x^2+(3/2)y^2)$
$\dot{y}=x+y(a+x^2+(3/2)y^2)$
By setting each equation to zero, i found the only equilibrium point to be $(0,0)$.
For the Jacobian matrix at $(0,0)$, I have:
$J(0,0)=\left( \begin{array}{cc}
a & -1\\
1 & a\end{array} \right)$
So:
$\tau=2a$
$\delta=a^2+1>0$
$\bigtriangleup=-4<0$
which gives:
$a<0$: $(0,0)$ is an attractor spiral.
$a>0$: $(0,0)$ is a repellor spiral.
$a=0$: $(0,0)$ is a center.
Does this mean that paths spiral into $(0,0)$ for negative $a$, and then spiral out towards a stable limit cycle? And, for positive $a$ beyond the limit cycle, paths spiral in towards it?
How do I find the critical value?
If you go to polar coordinates you can really see what's going on
$\dot{r} = r\left(a + x^2 + \dfrac{3}{2}y^2\right),\;\;\; \dot{\theta} = 1$.
Paths outside the limit cycle spiral outwards, whereas paths inside the limit cycle spiral into $(0,\ 0)$.
When $a$ is positive, there is no limit cycle.
Clearly, the critical value of $a$ is 0.
Yeah I see I got that backwards.
So when $a$ is positive, paths spiral out from $(0,0)$. When $a$ is negative, paths spiral in toward $(0,0)$, and the limit cycle is unstable?
Yes, the limit cycle is unstable. (See my previous post.)
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
