Ohmic and non-Ohmic conductors
  • Thread starter FS98
  • Tags
    Conductors
In summary: Vanadium's post is discussing how a non-ohmic element can be modeled as an ideal resistor, but this doesn't really help when you have to deal with things like temperature.
FS98
105
Do ohmic conductors obey ohms law at high voltages?
Also, I’ve seen it explained that some conductors are non-ohmic because the temperature caused by the current changes the resistance in the circuit. If that’s the case, isn’t ohms law still being obeyed, just with a varying resistance.
FS98 said:
...I’ve seen it explained that some conductors are non-ohmic because the temperature caused by the current changes the resistance in the circuit. If that’s the case, isn’t ohms law still being obeyed, just with a varying resistance.
Yes. Ohm's law is valid at each instant in such a situation.
There is a lot of confusion between R = V/I and the full statement of Ohm's Law which implies the V/I ratio is constant at constant temperature.
Take a Tungsten wire in the Lab and keep it in a water bath. It will follow Ohm's Law because it is a metal and the temperature is constant. Put a thin tungsten filament in a light bulb and its temperature will change as the current varies (of course). I would say that the Ohm's Law conditions are no longer there so the lamp doesn't have a constant resistance. This could be indistinguishable from a different (non-metallic) substance / component that happens to have the same V:I characteristic as the tungsten filament. Who could then say that "Ohm's Law" tells us the resistance is V/I"?
If we look at Boyle's Law, we are happy to say P/V for gas in a cylinder is constant at constant temperature. Some simple gases do follow Boyle's Law but we would never say that gas in a Stirling Engine is following Boyle's Law. To my mind, using the definition of Resistance as a statement of Owm's Law is just sloppy. For this I blame the (often highly competent) Electrical Engineers for bad usage of words. (Now stepping into my fallout shelter. :nb))
I'm not sure how far this abstraction takes you. Any circuit element at any instant has a voltage across it and a current through it, so one can calculate an instantaneous resistance. The fact that this is possible does not necessarily mean it is useful.
I look at it differently. Ohm's Law is the definition of an ideal resistor. Whether this is or is not a useful model for a physical object depends on the situation. Just like with frictionless planes, stretchless ropes, etc.
No argument there. I really meant it (and should have said so) for resistors experiencing modest changes due to temperature.
Ohn's Law doesn't even require the word "resistance" to be used at all. It just states that the ratio V/I is constant at constant temperature. Calling the V/I 'instantaneous Resistance" implies some time dependence. Perhaps "Effective Resistance" would do better and then you could do Kirchoff calculations to reveal things about a circuit with some non Ohmic components. (This is what we do, ain't it? And it is "useful".)
But aren’t there ways to find resistance without measuring it? So at any instant, the value of R would have to be a single value based on resistivity, length and area? The statement seems stronger than just saying that there exists some current and some voltage.
I think that the problem is that when you apply this to non-ohmic elements you get a result that isn't really helpful. That's Vanadium's point in post #4
The ONLY thing I can think of is that you have to go back and look at the microscopic details of charge transport in the material itself. This is NOT EASY, because you either have to go back to solving for the Boltzmann transport equation, or worse still, go back to the band structure and figure out the scattering rate of the charge carrier. Each one of these still requires experimental intput!
I don't understand how this is now related to your original question in this thread. Has that question been answered and you're going off on a tangent from it?
Zz.
If you operate resistors inside their safe voltage and temperature range, they're ohmic conductors for practical purposes (with few exceptions, such as thermistors). But if resistance depends on voltage then you deal with dynamic or incremental resistance, and the term non-ohmic alerts you that circuit analysis is not as simple. It doesn't imply that a Law of Nature is being violated.
FS98 said:
Do ohmic conductors obey ohms law at high voltages?.
Define high voltage?
"Ideal" ohmic conductors would. "Real" ohmic conductors would require more information. All real world conductors have some limitations. For example too much power and copper wire melts. The resistance of molten copper is an order of magnitude higher than solid copper.
The definition of ohmic conductor as I understand it is that the relationship between voltage and current is linear.
In...
V=I*R
R can't be a function of V or I and remain linear.
That said we can ometimes model non-ohmic conductors (like diodes) using a piecewise linear model. Eg for small changes about a fixed operating point the relationship between I and V is sufficiently linear to be useful.
I don't think there really is one. It's a term that's used as shorthand and it never needs to be used in actual circuit analysis.
Related to Ohmic and non-Ohmic conductors
1. What is the difference between Ohmic and non-Ohmic conductors?
Ohmic conductors follow Ohm's law, which states that the current through a conductor is directly proportional to the voltage applied. Non-Ohmic conductors do not follow this law and have a non-linear relationship between current and voltage.
2. How do Ohmic and non-Ohmic conductors behave differently?
Ohmic conductors have a constant resistance and therefore a constant current-voltage relationship. Non-Ohmic conductors have a varying resistance and therefore a non-linear current-voltage relationship.
3. What factors determine whether a material is an Ohmic or non-Ohmic conductor?
The atomic structure of a material and its ability to conduct electricity determine whether it is an Ohmic or non-Ohmic conductor. Materials with a regular crystal lattice, such as metals, tend to be Ohmic conductors, while materials with irregular structures, such as semiconductors, tend to be non-Ohmic conductors.
4. Can Ohmic and non-Ohmic conductors coexist in a single material?
Yes, a material can have both Ohmic and non-Ohmic regions. For example, a semiconductor material can have an Ohmic region at lower voltages and a non-Ohmic region at higher voltages.
5. How are Ohmic and non-Ohmic conductors used in practical applications?
Ohmic conductors are commonly used in electronic circuits and power transmission systems, as they have a predictable and controllable current-voltage relationship. Non-Ohmic conductors are used in devices such as diodes and transistors, where their non-linear properties can be harnessed for specific functions.
  • Electromagnetism
  • Electrical Engineering
  • Electromagnetism
  • Electromagnetism
