Ohm's law and using motor as generator
In summary, a dc motor can be used as a generator in reverse if the motor has onboard electronics that turn it into an AC induction motor. The voltage and current will be proportional to the load connected to the generator, but will sag when applied with a load.
dean48
hello i was wondering about how a dc motor would work as a generator and how the voltage and current would scale with ohms law. for example let's say i had a 350 watt motor that's 36 volts and generates 9.72 amps now let's say i use that motor as a generator but only generate 200 watts how would the current and voltage scale in proportion
:welcome:
You would know that the voltage times current equals 200. But the actual voltage and current depends on the load connected to this generator.
When acting as a motor, you had to supply the 36 volts and enough mechanical load to draw that current.
Acting as a generator, you must supply mechanical power to the shaft and electric load to the terminals.
Think of motors and generators as devices that transform mechanical power to/from electric power. Ohms Law is not much help.
hello thanks for the reply, but i think i may have to rephrase my question. basically what i was asking is if i use a dc motor in reverse as a generator the max capacity of that generator would be 350 watts at 36 volts and 9.72 amps now if i use the generator and decide to only generate 200 watts considering i keep the voltage and current proportional what would the voltage and current be when only generating 200 watts. for example let's say a generator generates 100 watts at 10 amps and 10 volts and now let's say you only generate 50 watts then the current and voltage would be equal to 7.07 because 7.07 x 7.07 equals 50 and if i generated 25 watts it would be 5 amps x 5 volts which would equal 25 watts. sorry if my question is long hopefully its easier to understand now.
Generally the voltage is held constant and the type of load determines what wattage is delivered to the load. A 100 watt incandescent light bulb with the Edison style base commonly used (formerly now due to energy conservation laws) is designed to run on 120 volts and will draw approximately .833 amps. Take the same type of bulb that is a 25 watt bulb will draw only .2083 amps while it is still designed to run at 120 volts. So to answer your question we would first need to know what type of motor you have. A lot of permanent magnet motors work fine as simple generators but some DC motors are not designed to work in reverse. They have on board electronics that turn them into AC induction motors for the purpose of eliminating the commutator and brushes. How much voltage a permanent magnet motor will produce unloaded when used as a generator depends upon how fast you spin it and of course will have some dependence on what voltage it was designed to operate with as a motor. How much current it is able to deliver will depend upon the thickness of the windings and things of this nature. Also keep in mind that you could spin it up and get your unloaded target voltage but when you apply the load you will have some sag in the voltage. There will not be an abrupt stop. There will be a point where the voltage falls below the useable level. Best thing to do is get some cheap hobby motor and start experimenting.
Related to Ohm's law and using motor as generator
1. What is Ohm's Law?
Ohm's Law is a fundamental law of physics that states the relationship between voltage, current, and resistance in a circuit. It states that the current passing through a conductor is directly proportional to the voltage and inversely proportional to the resistance.
2. How does Ohm's Law apply to using a motor as a generator?
Ohm's Law still applies when using a motor as a generator. The voltage generated by the motor is directly proportional to the speed of rotation and the strength of the magnetic field, and inversely proportional to the resistance of the circuit.
3. Can any motor be used as a generator?
No, not all motors can be used as generators. The motor must have permanent magnets or an electromagnet to produce a magnetic field, and it must be able to spin freely to generate electricity.
4. How is the power output of a motor as a generator calculated?
The power output of a motor as a generator can be calculated by multiplying the generated voltage by the current passing through the circuit. This is known as the power equation (P = VI).
5. Can Ohm's Law be used to predict the performance of a motor as a generator?
Yes, Ohm's Law can be used to predict the performance of a motor as a generator. By knowing the resistance of the circuit and the voltage and current generated by the motor, the power output can be calculated and used to determine the efficiency of the motor as a generator.
  • Electrical Engineering
