Oil emulsification by way of the put-off water
  • Thread starter Thread starter abdulbadii
    Oil Water
The discussion centers on the emulsification of white mineral oil with water, specifically focusing on the timing of water addition. It highlights that when water is mixed with mineral oil, they may not naturally combine or remain mixed without an emulsifier. The role of the emulsifier is crucial, as it facilitates the mixing process when added to one component before introducing the other under agitation. There is a call for clarification on the theoretical mechanisms behind emulsification, indicating a need for deeper understanding of how to achieve a stable oil-in-water emulsion.
abdulbadii
TL;DR Summary
How is the white oil emulsified O/W but thre water is to be put off later
How is the correct work to be done on white mineral oil emulsified as O/W but most of the water is to be deferred / put off later by indefinite amount of time?
At the time water is added/mixed that mixture just become exactly the same as the emulsification mixture being done at once
Chemistry news on Phys.org
Difficult to understand what you said. Mineral oil and water may not mix or may not stay mixed. An emulsifier would be added to one of them and then the other is to be added with agitation; and the result may be an emulsion. Some other member could explain the theory or the mechanism.
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
