Oil Formation Volume Factor at saturation conditions
In summary, the conversation discusses the use of data to calculate the oil formation volume factor at saturation conditions. Using the oil and gas gravities, gas-oil ratio, and density of reservoir oil, the author correctly calculates the value of 2.25 rb/stb. The importance of considering units and conversion factors in oil and gas reservoir engineering is also mentioned.
PetEng
\check{}
Given the following data I need to find the oil formation volume factor at the saturation conditions;
A single flash separation of Angolan reservoir oil gave a stabilised (for stock tank) oil gravity of 37.19’ API and a gas gravity of 1.015. The GOR (gas oil ratio) of the separation measured as 1899 scf/stb. From a separation experiment (constant mass study) the density of reservoir oil at saturation pressure 3790psia and reservoir temperature 250F was determined to be 559.4kg/m3.
What is the oil formation volume factor at the saturation conditions?
oil gravity = 37.19API
gas gravity = 1.015
GOR = 1899 scf/stb
saturated reservoir oil density = 559.4 kg/m3
I used this method;
Bo = [ ρ(oil) + ρ(gas)*GOR(stb/stb)] / ρ(reservoir)
= [838.8 + 1.243*338] / 559.4
BO = 2.25 rb/stb
ρ(oil) = density of oil at surface (from 37.91 API)
ρ(gas) = density of gas at surface (using SGgas=1.015 to find MWgas and ideal gas equation PV=nRT to find density)
GOR (STB/STB) = 1899/5.615 = 338
ρ(reservoir) = density of reservoir oil at saturation = 559.4 kg/m3
Have I done this correctly?
Yes, you have correctly calculated the oil formation volume factor at saturation conditions using the given data. Your method is correct and the resulting value of 2.25 rb/stb is accurate. It is important to carefully consider the units and conversion factors when using equations to solve problems in oil and gas reservoir engineering. Keep up the good work!
FAQ: Oil Formation Volume Factor at saturation conditions
1. What is the Oil Formation Volume Factor (FVF) at saturation conditions?
The Oil Formation Volume Factor (FVF) at saturation conditions is a measure of the change in volume of oil when it is brought from reservoir conditions (high pressure and temperature) to surface conditions (low pressure and temperature).
2. How is the Oil Formation Volume Factor (FVF) at saturation conditions calculated?
The Oil Formation Volume Factor (FVF) at saturation conditions is calculated by dividing the volume of oil at surface conditions by the volume of oil at reservoir conditions. This ratio is typically expressed in units of barrels per stock tank barrel (bbl/STB) or cubic feet per barrel (ft3/bbl).
3. What factors affect the Oil Formation Volume Factor (FVF) at saturation conditions?
The Oil Formation Volume Factor (FVF) at saturation conditions is affected by several factors, including reservoir pressure, temperature, and the composition of the oil. As reservoir pressure decreases, the FVF increases, and as temperature increases, the FVF decreases. Additionally, the presence of gas in the oil can also affect the FVF.
4. Why is the Oil Formation Volume Factor (FVF) at saturation conditions important?
The Oil Formation Volume Factor (FVF) at saturation conditions is an important parameter in the oil industry because it is used to calculate the amount of oil that can be produced from a reservoir. It is also used to determine the amount of oil in place and to estimate the ultimate recovery of a reservoir.
5. How can the Oil Formation Volume Factor (FVF) at saturation conditions be measured?
The Oil Formation Volume Factor (FVF) at saturation conditions can be measured in the laboratory using PVT (pressure-volume-temperature) analysis. This involves taking a sample of the oil from the reservoir and measuring its volume at different pressures and temperatures. The data is then used to construct an FVF curve, which can be used to calculate the FVF at any given pressure and temperature.
