Old City & Guilds Current Limitation Question
  • Thread starter Thread starter Abbsdad
    Current
The discussion revolves around a question from an old City & Guilds paper regarding a resistive load rated at 65 W and 110 V, intended for use on a 230 V supply. Participants seek assistance in calculating the current in the load, the necessary voltage drop across a series inductor, the inductor's inductance, and the circuit's phase angle. Additionally, they inquire about the advantages of current limitation and practical examples. There is a request for reading materials related to this topic, as existing resources primarily focus on MCBs and fuses. The conversation highlights the need for educational resources on electrical impedance and AC circuit analysis.
Abbsdad
Hi, I have the following question from an old City & Guilds paper:
A resistive load rated at 65 W, 110 V is to be used on a 230 V, 50 Hz supply.
Calculate
(a) current in the load
(b) voltage drop needed across a pure inductor connected in series with the load
(c) inductance of this inductor
(d) phase angle of the circuit
(e) explain the advantage of this type of current limitation and give one practical example.
Could someone point me to any reading material on this please as I can only find items relating to MCBs and fuses.
Many thanks.
What's an "old City & Guilds paper"? Is this question for schoolwork?
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
