- 29,208
- 7,029
- TL;DR Summary
- I cannot see how my gas ovens can 'know about' whether or not the auto ignite has been successful. They can be turned on and off by a programmer.
I cleaned the two ovens in our conventional gas stove. They light themselves - trying a few times if the flame doesn't strike and give up if no dice. One of the ovens would strike and light, then go out and try again - clunk pause clunk pause etc. I decided to have a look at the burner unit as I thought I must have disturbed the thermocouple circuit that I expected, right next to the burner. But the only wires going to the burner are two separate ignition cables. No other visible sensor in the vicinity.
I decided that the oven thermostat must be doing the job and gave it another special cleaning (Sodium Hydroxide type cleaner - very effective on oven grot). That seems to have solved the problem and a lit flame is enough to raise the thermostat temperature enough for it to be happy that the remote flame is burning. Clearly the system (whatever it is) is sufficiently reliable for the stove to be 'approved'.
Now, a normal safety cutout for a gas burner uses a thermocouple that's immersed right in the flame and the electromagnet is retained in place after just a few seconds of holding it there manually (that's what happens with the gas rings).
I'm sure some PF member must have come across this and I'd like to know it I'm right or what else happens. (Bearing in mind the system didn't seem to work until I cleaned off the thermostat sensor)
