Old vs new unitarity cut methods
In summary, the old unitarity cut method involves summing over all possible intermediate states to calculate scattering amplitudes, while the new unitarity cut method only considers specific intermediate states, making it more efficient. The need for a new method arose due to the computational intensity and limitations of the old method, and the new method offers advantages such as handling more complex processes and providing better numerical stability. However, it may not be suitable for all calculations and may not be as accurate as the old method in certain cases. The use of the new unitarity cut method has greatly improved the efficiency and accuracy of calculations in particle physics, allowing for the study of more complex processes and opening up new possibilities for testing and refining theories.
earth2
86
Hey folks,
I've been stumbeling recently about new unitarity methods to obtain one-loop amplitudes by cutting them in all possible channels thereby reducing the full amplitude to products of tree amplitudes (pioneered by Bern, Dixon, Kosower, Dunbar).
From what I understand from my QFT classes cutting a diagram will give you the imaginary part of the amplitude and by dispersion relations one will get the full amplitude. But why don't these guys need to do the dispersion integrals? From what I understand they get the full amplitude through these cuts from the start...no detour via imaginary parts and doing dispersion integrals...
How is this possible when both methods rely on simple unitarity? Where does the difference lie? I don't get it and would be happy if someone could enlighten me!
Thanks
earth2
sky
Hi earth2sky,
Thank you for bringing up this interesting topic. The method you are referring to is called the unitarity method or on-shell recursion, and it has indeed been pioneered by a group of physicists including Bern, Dixon, Kosower, and Dunbar.
To understand how this method works, it is important to first clarify the difference between the dispersion relation approach and the unitarity approach. In the dispersion relation approach, we start with the full amplitude and use the fact that it can be expressed as a sum over all possible cuts of the diagram. This allows us to write the full amplitude as an integral over the imaginary part of the amplitude, which can then be evaluated using the Cauchy's residue theorem. This is where the dispersion integrals come in.
On the other hand, in the unitarity approach, we start with the tree-level amplitudes and use the fact that they satisfy certain on-shell recursion relations. These relations allow us to write the full amplitude as a sum over products of tree amplitudes, with each term corresponding to a different cut of the diagram. This is where the difference lies - instead of integrating over the imaginary part of the amplitude, we are summing over products of tree amplitudes.
So, to answer your question, the unitarity method does not require the dispersion integrals because it bypasses the need for them by directly working with the tree amplitudes. This approach is particularly useful for calculating one-loop amplitudes, where the number of diagrams and cuts can become quite large. By using the on-shell recursion relations, we can greatly simplify the calculation and reduce it to a sum over a much smaller number of terms.
I hope this helps clarify the difference between the two methods. Both rely on unitarity, but the unitarity method takes a more direct approach by working with the tree amplitudes. If you would like to learn more, I recommend checking out some papers by the physicists I mentioned earlier, as well as the book "Scattering Amplitudes in Gauge Theories" by Elvang and Huang.
Best of luck in your studies!
Related to Old vs new unitarity cut methods
1. What is the difference between old and new unitarity cut methods?
The old unitarity cut method involves calculating scattering amplitudes by summing over all possible intermediate states, while the new unitarity cut method uses a more efficient approach by only considering specific intermediate states.
2. Why was there a need for a new unitarity cut method?
The old unitarity cut method was computationally intensive and could only be applied to simple processes. The new unitarity cut method was developed to speed up calculations and make it possible to study more complex processes.
3. What are the advantages of the new unitarity cut method?
The new unitarity cut method is more efficient and can handle more complicated processes. It also has better numerical stability and can be used to study higher-order scattering amplitudes.
4. Are there any limitations to the new unitarity cut method?
The new unitarity cut method may not be suitable for all calculations, as it requires a good understanding of the theory and the scattering processes involved. It also may not be as accurate as the old method for certain types of calculations.
5. How has the use of the new unitarity cut method impacted the field of particle physics?
The new unitarity cut method has greatly improved the efficiency and accuracy of calculations in particle physics, allowing for more complex processes to be studied. It has also opened up new possibilities for testing and refining theories of fundamental particles and interactions.
  • Classical Physics
  • Mechanical Engineering
  • Beyond the Standard Models
  • Differential Equations
