Oligomerisation of L-Lactic acid to Prepolymer
The discussion centers on the synthesis of polylactic acid (PLA) from L-lactic acid for a thesis project. The user seeks clarification on the chemical process involved in the polymerization of lactic acid to form a prepolymer of PLA. The key point is that the polymerization occurs through auto-esterification, where the acid and alcohol functional groups of lactic acid react, resulting in the formation of ester linkages and the release of water as a byproduct. This explanation addresses the user's inquiry about the molecular changes during the polymerization process.
MahoneyTree
TL;DR Summary
I need help undersating what happens in the chemical process.
I am working on my Thesis in which i synthesised PLA out of L-lactic acid. I am using the Methods from a research paper from the HEIA-FR which i linked here aswell.
https://www.chimia.ch/chimia/article/view/2012_951/4616
The second step is to perform a polymerisation of pure lactic acid to a prepolymer of PLA. I have done this and know what the educt aswell as product formulas are, but I don't know what happens in terms of a chemical process during the polymerisation.
Simply put, I need someone to explain to me what happens to the lactic acid molecule durng the polymerisation so that it turns into the prepolymer.
Thank you very much for your help
Chemistry news on Phys.org
It's an auto-esterification where the acid and alcohol functional group of lactic acid bind, releasing water.
Is this what you were looking for?
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
