Oliver Sacks & pushing the shuttle off course
  • Thread starter atyy
  • Tags
    Course
In summary, Oliver and Paul are discussing the idea of Shane affecting the course of a shuttle in space with his movements. While it may seem possible, it is actually a common perpetual motion fallacy and would not work due to the principles of conservation of momentum. Even if the shuttle were smaller, the movements of a person inside would not be able to significantly alter its course.
atyy
3,379
“Imagine Shane in space,” Oliver said, watching him with pride. “One violent movement and he would push the shuttle off course.”
- from Paul Theroux's My friend, the doctor
Is this possible, assuming Shane does not leave the shutte?
No, the shuttle is far too big to be pushed severely off course by a person, and the person splatting against the opposite wall would put it right back on course. But I expect that the intent of the sentence is about small things upsetting larger things. The very next sentence after your quote is:
"Several times he mentioned, with genuine amusement, the possibility of highly sophisticated technology upset or destroyed by such tics or flailings."
So if the shuttle were smaller, he could push it off course? Or would the correcting splat on the opposite wall come faster, and so correct it faster?
No, you could not ever push it off course. This is a common perpetual motion fallacy. No internal action can ever change the external motion of an object.
Not even the initial push: while to an external observer the initial push may appear to move the shuttle, what they won't know is that all it did was shift the center of mass of shuttle and occupant, leaving the path of the center of mass unchanged.
That's a demonstration of conservation of momentum, similar to what is done in high school physics labs with kids on skateboards.
No, as he is inside the shuttle. As soon as he hits the other side both he and the shuttle stop moving and the course remains unchanged.
Note that because the outside observer can't follow the changing center of mass, he may THINK the TRACK was permanently altered.
More complete explanation, starting with some navigation definitions:
Course is the direction of travel.
Track is the path in 3d spacel; the line along which you travel.
If a person pushes off the right side wall of the shuttle, near the COM (so there is no rotation), a person on the outside would see the shuttle's course change slightly to the right. When the person hits the other side wall and stops, the observer sees the shuttle resume its original course, along a new track, just slightly to the right of its original track.
What the observer doesn't know is that the only thing that actually changed was a shift in the location of the center of gravity on the shuttle, with the center of gravity never actually deviating from the original track or course.
Drakktth & russ watters, thanks! I will tell Oliver Sacks to read this thread:)
If the shuttle had a circular running track in the payload bay then an astronaught running one way round it would cause the shuttle to rotate in the opposite direction. However on it's own that wouldn't change it's course either.
Quite a lot of people have wasted time trying to invent a "reactionless rocket" but that would violate conservation of momentum.
http://en.wikipedia.org/wiki/Reactionless_drive
Edit: if the shuttle had it's engines or thrusters running then changing the direction they point by running around the track would have the desired effect of altering the course... but that's not in the spirit of the question.
FAQ: Oliver Sacks & pushing the shuttle off course
What is the significance of Oliver Sacks and pushing the shuttle off course?
Oliver Sacks was a neurologist and author known for his work on the human brain and behavior. In his book "The Man Who Mistook His Wife for a Hat," Sacks discussed a case study of a patient with a brain injury who had a compulsion to push objects off course. This case study has become a popular topic of discussion in neuroscience and psychology.
How did this case study impact the field of neuroscience?
The case study of the patient with a compulsion to push objects off course shed light on the connection between brain injury and abnormal behavior. It also sparked further research and discussion on the role of the brain in controlling our actions and impulses.
Was this behavior unique to the patient in the case study?
While this behavior was unique to the patient in the case study, similar compulsions have been observed in other individuals with brain injuries or disorders. This has led to further exploration of the brain's role in controlling our actions and the potential for abnormal behavior.
What other contributions did Oliver Sacks make to the field of science?
Aside from his work on the brain and behavior, Oliver Sacks also made significant contributions to the field of neurology, particularly in the study of rare and unusual neurological conditions. He was also known for his ability to make complex scientific concepts accessible to a wider audience through his writing.
How has Oliver Sacks' work impacted our understanding of the human brain?
Oliver Sacks' work has greatly contributed to our understanding of the human brain and its complexities. His case studies and research have shed light on rare and unusual neurological conditions, while also highlighting the brain's ability to adapt and compensate for damage. His work continues to inspire further research and exploration of the brain and its functions.
