Oloa Olivier's type integral π/4
In summary: Finally, using the substitution $x=\tan t$, we get:$$\int_{0}^{\infty}{1\over \sqrt{1+x^2}}\mathrm dx=\int_{0}^{\pi\over 2}{1\over \sec^2 t}\cdot\sec t\cdot\tan t\cdot\mathrm dt=\int_{0}^{\pi\over 2}{\sin t
Tony1
$$\int_{0}^{\pi\over 2}{\ln (2\cos x)\over x^2+\ln^2(2\cos x)}\mathrm dx={\pi\over 4}$$
I am very surprise it has a very simple closed form. I was expecting something else, probably involving a few other constants, like $\ln a$, $\pi$ ...
I don't know how to go about to show that it is $\pi\over 4$. I did try a substitution of $u=\ln(2\cos x)$, which make the integral looked more harder than it is...
$$\int_{0}^{\infty}{\mathrm du\over \tan x}\cdot{u\over x^2+u^2}$$
Can anyone help. Thank you!
Mathematics news on Phys.org
Hello there,
It is indeed surprising that the integral has a simple closed form, but it is true. Let me explain how to show that it is equal to $\pi\over 4$.
First, let's take a closer look at the integral:
$$\int_{0}^{\pi\over 2}{\ln (2\cos x)\over x^2+\ln^2(2\cos x)}\mathrm dx$$
We can see that the integrand involves both $\ln(2\cos x)$ and $x^2+\ln^2(2\cos x)$. This suggests that a substitution might be helpful. Let's try $u=\ln(2\cos x)$. This gives us $\mathrm du={\mathrm dx\over \tan x}$. Substituting this into the integral, we get:
This is the same integral that you have in the forum post. Now, we can use the fact that $\tan x={x\over \sqrt{1+x^2}}$ to rewrite the integral as:
$$\int_{0}^{\infty}{\mathrm du\over \sqrt{1+x^2}}\cdot{u\over x^2+u^2}$$
Next, we can use the partial fraction decomposition to split the integrand into two parts:
$${\mathrm u\over x^2+u^2}={1\over 2}\cdot\left({1\over x+iu}+{1\over x-iu}\right)$$
$$\int_{0}^{\infty}{\mathrm du\over \sqrt{1+x^2}}\cdot{1\over 2}\cdot\left({1\over x+iu}+{1\over x-iu}\right)$$
Now, we can use the fact that $\int_0^{\infty}{1\over x+iy}\mathrm dx=\pi\over 2$ to evaluate the integral. This gives us:
FAQ: Oloa Olivier's type integral π/4
What is Oloa Olivier's type integral π/4?
Oloa Olivier's type integral π/4 is a mathematical formula used to calculate the value of the integral of a function over a specific interval, where the upper limit is π/4. It was developed by mathematician Oloa Olivier and is commonly used in calculus and other fields of mathematics.
How is Oloa Olivier's type integral π/4 different from other types of integrals?
Oloa Olivier's type integral π/4 is unique in that it specifically uses the upper limit of π/4. Other types of integrals may have different upper limits or may not have a specific upper limit at all.
What is the significance of Oloa Olivier's type integral π/4 in mathematics?
Oloa Olivier's type integral π/4 is significant because it allows for the calculation of integrals over a specific interval, rather than over an entire range. This can make certain calculations easier and more precise.
Can Oloa Olivier's type integral π/4 be used for any type of function?
Yes, Oloa Olivier's type integral π/4 can be used for any continuous function over the interval [0, π/4]. However, it may not be applicable for functions that are not continuous or do not have a defined upper limit.
Are there any real-world applications for Oloa Olivier's type integral π/4?
Yes, Oloa Olivier's type integral π/4 is used in various fields such as physics, engineering, and economics to solve problems involving integrals over a specific interval. It can also be used in computer graphics and image processing for calculating areas and volumes.
