On board a laser powered solar sail
In summary, using an on board laser to propel a solar sail spacecraft is not an effective means of propulsion due to the cancellation of thrust from the reflected light on the sail. However, the laser can still be used to help deploy and adjust the sail. Some proposals suggest using lasers in orbit near the sun to propel a lightweight spacecraft, such as Breakthrough Starshot, but there are still many technical challenges to overcome before this becomes a feasible option. Additionally, this technology could potentially be used for smaller scale missions, such as remote sensing of asteroids.
NineNinjas911
Can an on board laser be used to propel a solar sail spacecraft if the laser is pointed at the sails ?
Would Newtons third law affect the laser and maybe prevent the ship from moving ?
Thank you for answering my very ignorant questions.
NineNinjas911
Science news on Phys.org
Reflection from the sail cancels the scant laser thrust overall. Sail 'stops' when the guy-lines tension.
I suppose you could use the laser to help deploy and adjust the sail, which then reflects *solar* light.
Not in any effective way. If the light is absorbed when it reaches the sail then there is no net thrust, because the force on the sail is equal and opposite to the force on the laser. If some fraction of the light is reflected then there will be some thrust, but never more than you'd get if you got rid of the sail and just pointed the laser out the back.
Likes Vanadium 50, Dale and russ_watters
If the sail had near perfect reflection, it would be analogous to thrust reversers on an airplane jet engine.
You can create thrust with a laser (albeit inefficiently), and you can use a reflector to change the direction of that thrust.
However, the best solar sail proposals do not put the laser on-board the spacecraft . (Lasers and their power supplies are heavy.) They use lasers in orbit near the sun aimed at a solar sail spacecraft that has small mass. One imaginative proposal I saw in the 1970s had an aluminum sail the size of The Moon but weighing only 1 gram, plus a 2 gram payload, It could be accelerated to 0.3 c (by lasers orbiting the sun) before leaving our solar system. Of course, the next question is what can you do with a 2 gram payload?
A recent example of a laser propelled mission proposal could be Breakthrough Starshot [1]. I haven't looked at the technical details so I am not aware if this is just warm air or a solid concept that realistically can be carried out in the near future, or somewhere in between. Maybe someone here can add a comment on that.
[1] https://en.wikipedia.org/wiki/Breakthrough_Starshot
Interesting. But the Wiki article says it is still R&D. They don't mention how it will be able to have enough transmit power to send pictures back to Earth. Also, how they punch so much laser power through the atmosphere. But it illustrates the very good concept that if we focus on spaceships weighing grams rather than tons, many things become easier.
They have a long list of essential challenges [1] that indeed seem to keep the final project goal in R&D for a some time to come. However, small scale validation or isolated parts of it, e.g. accelerating nanostructures with lasers, could potentially become feasible near-term. We have already have had a few actual light-sail experiments so it seems obvious that scaling down whenever possible should make access to experiments from actual LEO much more realistic. It is not hard to imagine the Starshot concept being useful on a much smaller scale also for say, cheap and fast remote "nano-sensing" of smaller asteroids (cheaper in the sense of price per asteroid visited).
[1] http://breakthroughinitiatives.org/challenges/3
Likes anorlunda
FAQ: On board a laser powered solar sail
How does a laser power a solar sail?
A laser beam is directed at the solar sail, which is made of a thin, reflective material. The photons from the laser beam transfer their momentum to the sail, propelling it through space.
How does a solar sail differ from traditional spacecraft?
A traditional spacecraft uses fuel to propel itself, while a solar sail uses the momentum of photons to move. This makes solar sails more efficient and allows them to travel much greater distances.
How do you control the direction and speed of a solar sail?
The direction and speed of a solar sail can be controlled by adjusting the angle of the sail in relation to the incoming laser beam. The sail can also be maneuvered by using the gravity of nearby planets or other objects.
What are the potential applications of a laser powered solar sail?
A laser powered solar sail could be used for long-distance space travel, such as sending probes to other planets or exploring the outer reaches of our solar system. It could also be used for satellite propulsion, reducing the need for traditional rocket fuel.
What are the challenges of using a laser powered solar sail?
One challenge is maintaining a constant and precise laser beam over long distances. There are also concerns about potential damage to the sail from debris or intense radiation in space. Additionally, the sail may be limited in its ability to maneuver and may require additional propulsion methods for more precise movements.
