I On injectivity of two-sided Laplace transform
The discussion centers on the injectivity of the two-sided Laplace transform and references the use of the Stone-Weierstrass theorem in establishing this property. A set of functions defined as ##\psi_\lambda(x)=e^{-\lambda x}## is considered, with extensions to continuity on ##[0,\infty]##. There is a query regarding the application of the Stone-Weierstrass theorem to the two-sided Laplace transform and how to modify the function set ##H## accordingly. Additionally, the conversation touches on the implications of Curtiss' theorem in proving that if two probability density functions have the same bilateral Laplace transform, they must be equal. The discussion concludes with uncertainty about the specific theorem referenced by Chareka in relation to Curtiss' work.
psie
TL;DR Summary
I am studying a theorem in probability that the Laplace transform of a (nonnegative) random variable determines the law of that random variable, which is equivalent to its injectivity. The book only treats Laplace transforms of nonnegative random variables, but since the moment generating function (mgf) is in fact the two sided Laplace transform, and since mgfs exist for arbitrary sign random variables, I wonder how to extend the result to say the two-sided Laplace transform is also injective.
I will omit the theorem and its proof here, since it would mean a lot of typing. But the relevant part of the proof of the theorem is that we are considering the set ##H## of functions consisting of ##\psi_\lambda(x)=e^{-\lambda x}## for ##x\geq 0## and ##\lambda\geq 0##. We extend the functions by continuity so they are defined on all of ##[0,\infty]##, namely we put ##\psi_\lambda(\infty)=0## if ##\lambda>0## and ##\psi_0(\infty)=1##. Having a compact set ##[0,\infty]##, we can apply the Stone-Weierstrass theorem to say that ##H## is dense in ##C([0,\infty])##.
I have seen another proof of the injectivity of the Laplace transform (not related to probability), but that also uses the Stone-Weierstrass theorem. So how would one go about showing the two-sided Laplace transform is injective? I guess one would like to consider ##[-\infty,\infty]## and apply the Stone-Weierstrass theorem also, but I'm unsure how one would modify ##H##.
I hope this can help.
Thank you. This was helpful. In proving the main theorem, Theorem 2.2, they rely on "Curtiss' theorem". I have looked at Curtiss paper but I am unsure which theorem Chareka means. Do you know which theorem Chareka is referring to?
If ## \{M_n(t)\} ## is a sequence of moment generating functions corresponding to a sequence of distribution functions ## \{F_n(x)\} ##, then convergence of ## \{M_n(t)\} ## to a moment generating function ## M(t) ## on ## (-\delta,\delta) ## implies that ## \{F_n(x)\} ## converges weakly to ## F(x) ##, where ## F(x) ## is the distribution function with moment generating function ## M(t) ##.
Ok, but how does it follow from this that $$L_{u^\ast}(s')=L_{v^\ast}(s')\implies u^\ast=v^\ast,$$where ##u^\ast,v^\ast## are probability density functions (and ##L_u## the bilateral Laplace transform of ##u##)? This is what Chareka concludes in Theorem 2.2 due to Curtiss theorem. This is the part I have a hard time understanding.
I do not know because I have not seen it.
Probably they used the equation $$ M(s)=E(e^{sX})=E(e^{-(-s)X})=B(-s) $$ where ## B(s) ## is a bilateral Laplace transform.
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
