On local trivializations and transition functions of fibre bundles
So the structure group is always reducible to those two groups.(If you are talking about a vector bundle, then there is a scalar multiplication, so you can in fact multiply by any non-zero number)In summary, the structure group for the [-1,1]\hookrightarrow E\rightarrow S^1 bundle is either the trivial group or Z/2Z, depending on whether the transition functions are multiplication by 1 or -1 respectively. Any other multiplication will not give a homeomorphism and therefore will not be a valid structure group.
lennyleonard
23
Hi everyone!
I would like to ask you some clarifications on an explicit example of local trivializations and transition functions of fibre bundles: namely on the [tex][-1,1]\hookrightarrow E\rightarrow S^1[/tex] bundle (which I guess is the simplest possible example).
Following Nakahara (chapter 9, example 9.1) we pick [tex]U_1=(0,2\pi)\,\,U_2=(-\pi,\pi)[/tex] as an open covering for the base space [tex]S^1[/tex] and label [tex]A=(0,\pi)\,\,B=(\pi,2\pi)[/tex] the intersection [tex]U_1\cap U_2[/tex].
Now Nakahara takes as local trivialization on A
[tex]\phi_1^{-1}(u)=(\theta ,t)\,\,\text{and}\,\,\phi_2^{-1}(u)=(\theta ,t)[/tex]
for [tex]\theta\in A \,\,t\in [-1,1][/tex], then he says that on the B section we have two possible choices, namely
[tex]1)\,\,\,\phi_1^{-1}(u)=(\theta ,t)\,\,\text{and}\,\,\phi_2^{-1}(u)=(\theta ,t)[/tex]
[tex]2)\,\,\,\phi_1^{-1}(u)=(\theta ,t)\,\,\text{and}\,\,\phi_2^{-1}(u)=(\theta ,-t)[/tex].
Now, my questions:
1) Shouldn't we have both this possibilities for the A sector as well? Does Nakahara simply not state them because they would not add anything to the example (you end up with either a cylinder or the moebius strip anyway :) )
2) Why, disregarding the specific sector (A or B), are we limited to the two choices aboce, i.e.
[tex]\phi_1^{-1}(u)=(\theta ,t)\,\,\text{and}\,\,\phi_2^{-1}(u)=(\theta ,\pm t)[/tex]
I mean, couldn't I pick the choice
[tex]3)\,\,\,\phi_1^{-1}(u)=(\theta ,t)\,\,\text{and}\,\,\phi_2^{-1}(u)=(\theta ,\frac{t}{a})[/tex]
with [tex]a\in\mathcal R/\{0\}[/tex]??
In this way we should have for the transition function [tex]t_{12}(\theta):t\rightarrow \frac{t}{a}[/tex], so that with the final choice of
on the A sector and
on the B sector the bundle would have the structure group [tex]G=\{e,1/a\}[/tex] which is something different from the cylinder or the Moebious strip!
Where am I mistaking??
Thanks to all of you for your time!
The transition functions must be isomorphisms of the fiber. Multiplication by a real is not even a homeomorphism of the unit interval
But you can take the whole real line as the fiber and then multiplication by a real will be a linear isomorphism of the fiber thus making the bundle a one dimensional vector bundle.
That said, you are correct that different structure groups will give the same total space of the bundle but different bundles because they have different structure groups.
However for a line bundle over the circle, the structure group can be reduced to either the trivial group or to Z/2Z. In the first case the bundle is trivial and the total space is a cylinder. In the second case, the bundle is non-orientable and the linear isomorphism in Z/2Z is just multiplication by -1. This is the Mobius band.
Try going through the cases you pose and see which ones can be reduced to the trivial group and which can be reduced to Z/2Z but no further.
Another instructive example is the twisted torus.
Take a cylinder and identify the opposite boundary circles by a 180 degree rotation. If you consider the structure group to be the whole circle then this bundle is trivial. That is, its structure group can be reduced to the identity map. If you consider the structure group to be Z/2Z ( the square of a 180 degree rotation is the identity) then this bundle is not trivial.
Thank you for your kind answer lavinia! But I'm afraid I'm going to need a little more help to get to the bottom of this :)
Is it now clear that i cannot take [itex]a\in\mathbb R/0[/itex], but what is I restrict to [itex]1\leq |a|<\infty [/itex]? This gives indeed a homomorphism beween the fiber! I really cannot see how such transition function can give a structure group ONLY reducible to [itex]e[/itex] and [itex]\mathbb Z_2[/itex]
Thanks again for your help!
Numbers with absolute value greater than 1 still don't work. Multiplication moves the end points either shrinking them or expanding them.
Ok, I totally messed up-- I meant [itex]|a|\leq 1, a\neq 0[/itex].
What about this mapping?
Sorry for the inconvenience :) :) :)
Multiplying by any number other than 1 or -1 can not be a homeomorphism of a finite interval.
Related to On local trivializations and transition functions of fibre bundles
1. What is a fibre bundle?
A fibre bundle is a mathematical construction that describes how a space locally looks like a product space. It consists of a base space, a total space, and a projection map that maps points from the total space to the base space. The fibres, which are homeomorphic copies of a fixed space, are attached to each point in the base space.
2. What are local trivializations?
Local trivializations are charts that describe how the total space of a fibre bundle locally looks like a product space. They are used to understand the structure of the total space and how it relates to the base space. A fibre bundle may have different local trivializations depending on the chosen base space and fibres.
3. What are transition functions?
Transition functions are mathematical functions that describe how the local trivializations of a fibre bundle are related to each other. They are used to glue together the local charts to form a globally consistent structure. Transition functions can be thought of as the "glue" that holds a fibre bundle together.
4. What is the significance of transition functions in fibre bundles?
Transition functions are crucial in understanding the topology of a fibre bundle. They provide a way to compare different local trivializations and determine if they are compatible, which is important for constructing a consistent global structure. They also help in studying the properties of the fibres and their relationship to the base space.
5. How are fibre bundles used in physics?
Fibre bundles have many applications in physics, particularly in the study of gauge theories and field theories. They provide a framework for describing and understanding the symmetries and interactions of physical systems. In particular, the concept of a principal bundle, which generalizes the notion of a fibre bundle, is widely used in modern theories such as gauge theories and general relativity.
  • Differential Geometry
