On Skin Effect and Microstrip Lines
In summary: TEM wave as well?I was talking about a Poynting vector that is perpendicular the conductor. It has been well answered by Bob.
chr0mium
In the field of microwave engineering, skin effect is referred to when people talk about the fact that current, that is, electrons only flows on the surface of transmission lines, e.g. microstrip lines.
I've checked many EM books--everywhere skin effect is demonstrated with both E and H
parallel to the surface of a conductor, with the wave propagating into the conductor.
Now here is a gap between these two. For transmission lines, waves actually propagate in the direction parallel to the line instead of perpendicular to conductors. And if we draw the field lines, most of them lie in the surrounding dielectric materials instead of in the conductor.
Can anyone help me bring these two together?
You make the assumption that the wave outside the transmission line propagates parallel to it but inside the line vertical to it. Like there is a 90 degrees refraction in the propagation of wave when it meets the transmission line conducting medium.
Of course this assumption is just to simplify the theoretical calculations, we can never have 90 degrees refraction angle.
This is a very good question. In an ideal transmission line with zero resistance conductors, all the energy flows between the conductors as a transverse electric magnetic (TEM) wave. The currents in (ideally on) the conductors support the TEM wave (similar to the currents in the walls of a waveguide). In essence a TEM wave is the equivalent of a TE or TM wave below waveguide cutoff. There is a small electric field parallel to the surface of the conductor only if the conductor has a finite resistance. Otherwise, the boundary condition requires Eparallel = 0. This electric field arises not from the TEM wave but from the voltage drop of the currents in the conductors.
The Poynting vector P = ET x HT of the TEM wave points along the direction of the wave propagation. The Poynting vector of Eparallel crossed into the transverse HT points into the conductor, meaning that power is flowing from the TEM wave into the resistive conductor.
Resistive conductor (skin effect) losses in coax cables (e.g., RG-8) are the dominant power losses at RF frequencies. The only other losses are dielectric and radiative, usually only at microwave frequencies.
A very thorough discussion of eddy (skin effect) currents and losses can be found in chapter X of Static and Dynamic Electricity (third edition) by Smythe.
Bob S
Well this is refreshing. So in reality there is a vertical component close to the conducting medium? Is there any source that elaborates on this?
Bob S
Thanks very much!
You mean vertical component of the poynting vector outside but close to the conductor? I guess there must be one which accounts for the radiative losses.
I was talking about a Poynting vector that is perpendicular the the conductor. It has been well answered by Bob.
The only doubt left is, given the conductors are ideal, will an AC current be on the surface, instead of distributed evenly? If so, then we have two separate phenomena both of which make the current flow on the surface, one is lossy, the other lossless. I'll try to find an answer from the Smythe book.
Er what do you mean by ideal conductor? If u mean infinite conductivity then from the skin depth formula one gets that skin depth is zero, that is the current is flowing only on surface.
If conductor is ideal, there is no $E_{parallel}$, thus there is no resistive conductor loss (or the so called skin effect)
There is only one current in or on the conductors; it is required by the boundary conditions for the TEM wave flowing between the microstrips. If there is a voltage drop (parallel to the current) in the conductor, then there are eddy current (skin effect) losses in the conductor, but there are no additional currents. So there is an additional electric field from the IR drop, but no additional current.
If your pulse signals are very high frequencies, the losses scale as the square root of frequency (creating both frequency-dependent attenuation and velocity dispersion), so the rise and fall times of pulses will round off. The losses are dependent on the impedance (Z0) of the transmission line. Usually higher Z0 is better.
Bob S
In reality there are no ideal conductors so there is Eparallel in and on the conductor. Does this imply that there is Eparallel too in the dielectric space between the transmission line conductors?
Oh my, I think I have pinned down the source of my doubt. It all happened when I first learned about skin depth, where there was an equation of electric field in a good conductor
E_x = E_0 * e^{-\alpha * z} * cos(\omega * t - \beta * z)
\alpha = \sqrt{\omega \mu \sigma}
I mistakenly thought that if conductivity \sigma were to be infinite, e^{\alpha * z} would be 1 thus the magnitude E_x would be constant inside the conductor, and it is because the conductivity is not infinite that we have reduced E_x which is called skin effect. It's a simple mathematical mistake coupled with a plausible physical interpretation.
But the truth is, given an infinite \sigma, \alpha would be infinite, and e^{-\alpha * z} would be 0, meaning there wouldn't be any E_x inside a perfect conductor. It is only because in reality \sigma is not infinite that E_x could penetrate a good conductor somewhat, but only up to a "skin depth" beyond which E_x becomes trivial.
Yes, you are absolutely correct. Consider the interesting example of a balanced line, like the 300-ohm TV lead-in line. The skin effect losses are equal in the two conductors, but the currents are in the opposite direction. So the two Eparallel's are equal in magnitude but opposite in direction. So the Eparallel changes polarity midway between the two conductors. In a microstrip, most of the Eparallel is in the strip, and very little in the ground plane.
Bob S
Related to On Skin Effect and Microstrip Lines
1. What is the skin effect?
The skin effect is a phenomenon in which high frequency currents tend to flow more on the surface of a conductor rather than through the entire cross-section. This is due to the interaction between the electrical and magnetic fields, causing the current to concentrate near the surface of the conductor.
2. How does the skin effect affect microstrip lines?
The skin effect can increase the effective resistance of a microstrip line, making it less efficient at carrying high frequency signals. It can also cause the signal to attenuate as it travels along the line, leading to a loss of power.
3. What are the factors that affect the skin effect?
The skin effect is influenced by the frequency of the signal, the electrical conductivity and permeability of the conductor material, and the geometry of the conductor. As the frequency increases, the skin depth decreases, resulting in a stronger skin effect.
4. How can the skin effect be mitigated in microstrip lines?
One way to reduce the impact of the skin effect in microstrip lines is by using a material with high electrical conductivity, such as copper or silver. Another method is to increase the thickness of the conductor, as this will increase the skin depth and reduce the skin effect.
5. What are the advantages of using microstrip lines?
Microstrip lines offer several advantages, including low cost, ease of fabrication, and compatibility with integrated circuit technologies. They also have low radiation losses and can be designed to have controlled impedance, making them suitable for high frequency applications.
  • Electromagnetism
  • Electrical Engineering
  • Classical Physics
