psie
- 261
- 32
- TL;DR Summary
- I'm confused about a comparison theorem related to ODEs and a definition of sub solution.
I'm reading Ordinary Differential Equations by Andersson and Böiers. There is a comparison theorem I have some questions about. I have also checked Teschl's Ordinary Differential Equations and Dynamical Systems, but there I have problems with his definition of a sub solution. I'll elaborate below. Here follows a theorem in the book I first stated:
This definition is not made in the book, but I guess ##y(t)## is called a super solution. What confuses me in this theorem are the inequalities and how the theorem is modified when we change some of the inequalities to strict inequalities.
For completion, I post the proof of the theorem here. You can skip this of course. It uses the following lemma, stated without proof for the sake of brevity;
Theorem. Assume that ##f(t,x)## is a continuous function in the strip ##\{(t,x); t_0\leq t\leq t_1\}## and satisfies a Lipschitz condition in a neighborhood of every point there. Furthermore, assume that ##x(t)## and ##y(t)## satisfy $$x'(t)=f(t,x)\quad\text{and}\quad y'(t)\geq f(t,y)$$ respectively, when ##t_0\leq t\leq t_1##. Then $$x(t_0)=y(t_0)\implies x(t)\leq y(t)\quad\text{when }t_0\leq t\leq t_1.$$
- First, I assume a corresponding result holds for a function ##w(t)## that satisfies ##w'(t)\leq f(t,w)##, so that ##x(t_0)=w(t_0)\implies x(t)\geq w(t)## when ##t_0\leq t\leq t_1##, right?
- Second, I'm working a problem where a function ##y(t)## satisfies ##y'(t)> f(t,y)## on a half-open strip, i.e. ##t_0\leq t<t_1## (because it is undefined at ##t_1##). So how is the conclusion of the theorem modified if we change the assumptions to ##y'(t)> f(t,y)## and a half-open strip?
- Finally, in Teschl's book, he defines a sub solution ##w(t)## to be a function that satisfies ##w'(t)< f(t,w)## for ##t_0\leq t<t_1##. However, in my problem, I have a function ##w(t)## that satisfies ##w'(t)\leq f(t,w)## for ##t_0\leq t<t_1## (in particular, ##w'(t_0)=f(t_0,w(t_0))##. Is this not a sub solution then?
Lemma. Let ##x(t)## be a differentiable function such that $$x'(t)\leq Mx(t)+a,$$ where ##M\neq 0## and ##a## are fixed constants. Then $$x(t)\leq e^{M(t-t_0)}x(t_0)+\frac{a}{M}(e^{M(t-t_0)}-1),\quad t\geq t_0.$$
Proof (of theorem). Assume that there is some point ##\tau## in the interval ##[t_0,t_1]## where ##x(\tau)>y(\tau)##. Then let ##\bar t## be the largest ##t## in ##[t_0,\tau]## with ##x(t)\leq y(t)##. Put ##z(t)=x(t)-y(t)##. Then ##z(t)>0## in ##(\bar t,\tau]## and ##z(\bar t)=0##. Furthermore, for ##t## near ##\bar t##, $$z'(t)=x'(t)-y'(t)\leq f(t,x(t))-f(t,y(t))\leq L(x(t)-y(t))=Lz(t).$$ The first inequality comes from the assumptions on ##x(t)## and ##y(t)##, the second one makes use of the Lipschitz condition. [The] lemma (with ##a=0##) now implies, for ##t## in a right neighborhood of ##\bar t##, $$z(t)\leq e^{L(t-\bar t)}z(\bar t)=0.$$ We have arrived at a contradiction.
