On the cusp of fully grasping Method of Characteristics
The discussion centers on the Method of Characteristics (MOC) and its application in designing supersonic nozzles. The user has a solid understanding of characteristic lines and their interactions but struggles with deriving the nozzle wall geometry from these intersections. They reference two sources that explain the intersection of characteristic lines and changes in flow parameters but find them lacking in guidance on wall contour derivation. The user seeks clarification on how to translate the information about characteristic line intersections into the actual geometry of the nozzle wall. The request emphasizes a need for practical assistance in applying MOC to nozzle design.
Benjies
TL;DR Summary
A method used to create geometries for the straightening section of rocket nozzles (as well as other systems)
'Lo all,
I've been studying the Method of Characteristics for quite some time now. I understand all the interactions between characteristic lines, and how they modify the flow Mach number and direction of the flow when these characteristic lines intersect. I have just a couple of hangups that I was hoping this forum might be able to help me with. My primary sources are here:
[1] http://mae-nas.eng.usu.edu/MAE_5540_Web/propulsion_systems/section8/section.8.1.pdf
[2] https://www.ijert.org/research/desi...method-of-characteristics-IJERTV2IS110026.pdf
In [1], at the end of section 2., the author displays that you can find the position of where the two characteristic lines intersect, and then states "thus, helping in developing the supersonic nozzle". Similar information in [2] on slide 21. Trouble is, all these paper have displayed is that you can derive the position of the characteristic line intersection, as well as the change in flow angle (theta), and finally the change in Mach number at this point downstream. But this only provides us the position of characteristic line intersection- this doesn't provide me the position of the wall of my nozzle at all. How has this given me the geometry of my wall?
I fundamentally get how the characteristic lines are generated, and how they interact during intersections. But I seem to be missing something in these sources that displays how wall contour is derived from these characteristic meshes.
Thank you!
To be clear- I am asking for HELP with MOC- I am not sharing this for pure information! Probably should have mentioned that in my title, or something.
Due to the constant never ending supply of "cool stuff" happening in Aerospace these days I'm creating this thread to consolidate posts every time something new comes along. Please feel free to add random information if its relevant. So to start things off here is the SpaceX Dragon launch coming up shortly, I'll be following up afterwards to see how it all goes. :smile: https://blogs.nasa.gov/spacex/
Thread 'SpaceX Starship development: 7th flight January 10'
Watch the progress live This is a fully stacked Starship (top) and Super Heavy (bottom). A couple of too-small-to-see cars near the bottom for scale, I also added a Saturn V and the Statue of Liberty for comparison. 120 meters tall, about 5000 tonnes when fully fueled. Twice the mass and over twice the thrust of Saturn V. The largest rocket ever built by mass, thrust, height, and payload capacity. N1 had the largest diameter.[/size] But its size is not the revolutionary part. It is designed...
