I On the definition of canonical coordinates in phase space
cianfa72
TL;DR Summary
About the definition of canonical coordinates in phase space (cotangent bundle)
I've a doubt regarding the definition of canonical coordinates in phase space.
As far as I can tell, phase space ##T^*M## is the cotangent bundle of the system configuration space ##M##.
##M## is assumed to be a differential manifold with atlas ##A=\{ U_i, \phi_i \}##. Call ##q_i## the coordinate functions of ##(U_i, \phi_i)##. They define in ##\pi^{-1}(U_i)## the covector basis field ##\{dq_i\}##.
Now at each ##p \in M## any element of the cotangent space ##T^*_pM## can be written as linear combination of ##\{dq_i\}##. Call ##\{ p_i \}## the set of functions defining the components of cotangent element at any point ##p##. Hence any cotangent field (one-form) ##\theta## can be written as
$$\theta = \sum_i p_idq_i$$
Assuming the above is correct, are those ##\{ q_i,p_i \}## the canonical coordinates for phase space (cotangent bundle) ?
Yes.
Ok, so basically ##\{ p_i \}## are coordinates in any ##\pi^{-1}(p) \cong F## with respect to ##\{ dq_i \}_p## picked as basis for covectors at ##T^*_pM##.
Yes, but be careful with the notations. You denote a point in the base manifold ##M## by ##p##, but your coordinates on ##M## are ##\{q_i\}##, and the ##p_i##'s are the components of the one-forms in the basis ##\{dq_i\}##.
Ah ok. To avoid confusion let's call ##a## the point in the base manifold ##M##, so that ##\{ p_i \}_a##'s are the components of the one-forms (covector fields) evaluated at ##a## in the coordinates basis ##\{dq_i\}_a##.
Btw, by a diffeomorphism between ##\{p_i\}## and ##\{z_i\}##, in the new coordinates one-forms ##\theta## are no longer written in the form $$\theta = \sum_i z_idq_i$$ right ? As far as I can tell, the above expression for ##\theta## holds true only in canonical coordinates.
What do you mean by a diffeomorphism? Between what? The contangent bundle and itself or something else? The coordinates of the cotangent bundle are ##(q_i,p_i)##.
I meant a differentiable one-to-one onto map with inverse differentiable from the ##\{p_i\}## to say the ##\{z_i\}##.
A one-form (covector field) ##\theta## written as ##\theta = \sum_i p_idq_i## in ##\{ q_i,p_i \}## canonical coordinates can no longer be written as ##\sum_i z_idq_i## in the new ##\{q_i,z_i \}## cotangent bundle coordinates.
My question was about the manifold. A diffeomorphism of which manifold? My guess is the cotangent bundle. But these, that you've written above are not coordinates of the cotangent bundle.
Why not? What is the relationship between the p's and the z's?
Sorry, I'm confused a bit. I took a look at Lee - Introduction to Smooth Manifold.
Long story: starting from a ##m##-dimensional smooth manifold ##M## and its maximum atlas, one can define a corresponding atlas for the cotangent bundle ##T^*M## turning it into a differentiable manifold on its own. Said ##q^i## the ##U##'s chart coordinates for ##M##, take as ##p_i## the coordinates that assign to each covector at point ##a \in U## in the fiber its components in the coordinate basis ##\{ dq^i \}_a##. By definition ##(q^i,p_i)## are the canonical coordinates for ##\pi^{-1}(U)##.
Now a covector field (one-form) on ##T^*M## is a section of ##T^*(T^*M)##. The canonical one-form ##\theta## (aka tautological one form) is defined in canonical coordinates as $$\theta = \sum_i p_idq^i$$ Suppose to define a "chart diffeomorphism" ##(q_i,p_i) \mapsto (q_i,z_i)## that leaves untouched the ##q_i## while the ##z_i## depending only from the ##p_i## (i.e. the diffeomorphism's matrix representation in those canonical coordinates is block diagonal). As far as I can tell, this time the canonical one-form ##\theta## is given in the form
$$\theta = \sum_i f_i(z_1, z_2 ... z_m)dq^i$$ and cannot be written as ##\theta = \sum_i z_idq^i##.
Oh, i see, yes you are right. I thought you meant a general one form and a map that only chages the p's. For example if ##p=z^2## and q stays the same, then ##pdq## becomes ##z^2dq##. But now i see what you meant.
