On the different ways of determining curvature on manifolds
In summary, the different ways of determining curvature on manifolds, such as the sectional curvature, the scalar curvature, the Riemann curvature tensor, and the Ricci curvature, each serve a different purpose in understanding the curvature of a manifold. The Riemann tensor contains all the information about curvature at a point, but it requires a lot of data to encode. The Ricci tensor is a summary of the information in the Riemann tensor, while the scalar curvature is a summary of the Ricci tensor. These summaries lose some information, but are useful for calculations and understanding the overall curvature of a manifold. Additionally, the Gaussian curvature is another scalar measure that summarizes the richer curvature information provided by the two principal curvatures at
trees and plants
Hello. Why do we have different ways of determining curvature on manifolds like the sectional curvature, the scalar curvature, the Riemann curvature tensor , the Ricci curvature? What are their different uses on manifolds? Do they allow each of them different applications on manifolds? Thank you.
The Riemann tensor contains all the information about curvature at a point in a manifold. Curvature at a point can vary in different directions - for instance compare curvature of a cylinder vs a sphere vs a saddle surface embedded in Euclidean 3-space. The wiki article on principal curvatures of a 2D manifold explains that concept nicely.
Since the Riemann tensor applies to a manifold with any number of dimensions, you can imagine it would need a lot of data (to the order of ##n^4/2## real numbers) to encode all the info about curvature of a n-dimensional manifold at a point.
I think of the Riemann tensor loosely as follows. Since it takes four inputs and returns a scalar, we can also consider it as taking three vector inputs - v1, v2 and v3 - and returning a fourth vector v4. If we parallel transport vectors v1, v2 and v3 around a tiny rectangle in the manifold where we first head off in direction v2, then turn into the direction of (parallel transported) v3, then turn in the direction of parallel transported v2, then turn into the direction of parallel transported v3 until we get back to the start point, v4 approximately gives the deviation between the original v1 and its parallel transported version. Every different combination of v1 (vector to be compared with original) and v2, v3 (route for rectangle journey) can give a different answer, so there's a lot of info in that tensor.
The Ricci tensor is a summary of info in the Riemann tensor. Like all summaries, it loses some info. I've never seen an intuitive, physical explanation of the meaning of the Ricci tensor. But I know it is used for calculating Ricci flows, which are useful. In 3D, the Ricci tensor contains all the info in the Riemann tensor. But in higher dimensions, it loses information.
The scalar curvature is a summary of the Ricci tensor, and hence also of the Riemann tensor. As it is a single real number, you can see it is very summarised, and has discarded most of the detail. According to wikipedia, the scalar curvature represents the amount by which the volume of a small geodesic ball in a Riemannian manifold deviates from that of the standard ball in Euclidean space.
Referring back to the wiki article on principal curvatures, note that the Gaussian curvature is a scalar that summarises the richer curvature info provided by the two principal curvatures at a point on a 2D manifold in Euclidean 3-space. That's another case where we use both detailed and summarised (scalar) curvature measures.
Related to On the different ways of determining curvature on manifolds
1. What is a manifold?
A manifold is a mathematical concept that describes a space that locally resembles Euclidean space. In other words, it is a space that can be smoothly mapped onto a portion of a plane without any tearing or folding.
2. What is curvature on a manifold?
Curvature on a manifold refers to the amount by which the manifold deviates from being flat. It measures the amount of bending or warping in the space.
3. How is curvature determined on a manifold?
There are various ways to determine curvature on a manifold, including the use of Riemann curvature tensor, Ricci curvature, and sectional curvature. These measures can be calculated using a combination of differential geometry and calculus.
4. Why is determining curvature important?
Determining curvature on a manifold is important in many areas of mathematics and physics. It helps us understand the geometry and topology of the space, and has applications in fields such as general relativity, differential equations, and cosmology.
5. What are some real-world examples of manifolds?
Some examples of manifolds in the real world include the surface of a sphere, the Earth's surface, a donut shape, and the space-time continuum. These are all spaces that locally resemble Euclidean space but have different curvatures.
  • Differential Geometry
