On the equivalent definitions for solvable groups
In summary, there are three equivalent definitions for solvable groups: the existence of a chain of subgroups with certain properties, the existence of a chain of subgroups with different properties, and the existence of a chain of subgroups with yet another property. These definitions are equivalent for finite groups, and they all involve the concept of normality and a specific type of quotient group. However, the lengths of the chains may vary, and there is no guarantee that they will be equal. Additionally, there are theorems that deal with normal and composition sequences, and these can help establish the uniqueness of a group's simple constituents. Ultimately, the choice of definition may depend on the specific goal or problem at hand.
hihiip201
170
We have the 3 equivalent definition for solvable groups:
There exists a chain of subgroups
1 < G1 ...< Gi + < G i+1 < Gr = G
such that Gi is normal in Gi+1 and Gi+1/Gi is abelian.
Another definition is
there exists
1 < H1 ...< Hi + < H i+1 < Hs = H
such that Hi is normal in Hi+1, and Hi+1/Hi is cyclic
, the last definition is similar but the quotient group is isomorphic to Z/p.
so my question is, does s need to be equal r?
thanks
There is no reason why they should be the same. The definition involving r (which, according to Wikipedia, is only equivalent for finite groups) requires that each ##H_i## be a maximal normal subgroup of ##H_{i+1}##. The steps in the H sequence are smaller than those in the G sequence, since the factor groups (quotients of successive elements) are cyclic, which is 'smaller' than Abelian, so one would expect the H sequences to generally be longer than the G sequences. That is, generally r would be longer than s. It may even be the case that s never exceeds r, but I have no proof of that.
This cannot be proven. E.g. if ##\mathbb{Z}_6## is a factor, then it's both Abelian and cyclic, but there is still a refinement possible. The maximal length will be reached, if all factors are simple.
This is the correct definition.
There are several theorems which deal with normal sequences and composition sequences. The latter is a normal sequence whose factors are simple, such that no refinement is possible.
Two normal sequences have isomorphic refinements. (O. Schreier)
Is there a composition sequence, then each normal sequence can be refined to a composition sequence and two composition series are isomorphic. (Jordan, Hölder)
Two sequences are isomorphic, if the sets of factors are the same.
as a consequence of the results stated by fresh_42, one knows that a finite group has associated to it a unique collection of "simple constituent groups", namely the simple factors of any composition series. Then one way to say a group is solvable is to say that its simple constituents are all cyclic of prime order. Since this is true of any abelian group, the two definitions you gave are equivalent.
Just which characterization you wish to use, may depend on what goal you have in mind, as usual. For example if you want to prove that the Galois group of a solvable polynomial is a solvable group, you want to be able just to show as a key step say, that the Galois group of X^n-1 is abelian. But if you want to show conversely that a polynomial (over the rationals say), is solvable if it has a solvable Galois group, then it is useful to begin from a decomposition of its splitting field into a series of field extensions of prime degree, obtained via the fundamental theorem of Galois theory from a composition series for the group.
These two results are explained in detail in my free class notes:
http://alpha.math.uga.edu/%7Eroy/843-2.pdf
http://alpha.math.uga.edu/%7Eroy/844-2.pdf
Likes lavinia and jim mcnamara
Related to On the equivalent definitions for solvable groups
1. What is the definition of a solvable group?
A solvable group is a type of mathematical group in which the commutators (elements of the form [a,b] = aba^-1b^-1) of its elements eventually become the identity element when iteratively applied. In simpler terms, this means that the group can be "solved" or broken down into smaller, simpler groups.
2. How are solvable groups different from other types of groups?
Solvable groups are unique in that they have a specific property called solvability, which is not present in other groups. This property allows for the group to be reduced to simpler forms through commutators, making it easier to study and understand.
3. What are some common equivalent definitions for solvable groups?
Some common equivalent definitions for solvable groups include: being a group that has a normal series with abelian quotients, being a group whose derived series eventually reaches the identity element, and being a group that has a composition series with abelian factors.
4. Can all groups be classified as solvable or not?
No, not all groups can be classified as solvable or not. There are some groups that are considered "unsolvable" or "non-solvable" because they do not meet the criteria for solvability, such as the simple groups and the alternating groups.
5. How does the concept of solvability relate to other areas of mathematics?
Solvability has important connections to other areas of mathematics, such as Galois theory and algebraic geometry. In Galois theory, solvable groups are used to study field extensions and their properties. In algebraic geometry, solvable groups are related to the study of algebraic equations and their solutions.
  • Linear and Abstract Algebra
  • Math POTW for University Students
