cyberdyno
- 14
Notes by ScienceWeek:
In the late 19th century, what we now call "classical" physics incorporated the assumed existence of the "ether", a hypothetical medium believed to be necessary to support the propagation of electromagnetic radiation. The famous *Michelson-Morley experiment of 1887 was interpreted as demonstrating the nonexistence of the ether, and this experiment became a significant prelude to the subsequent formulation of Einstein's *special theory of relativity. Although it is often stated outside the physics community that the ether concept was abandoned after the Michelson-Morley experiment, this is not quite true, since the classical ether concept has been essentially reformulated into several modern *field concepts.
The following points are made by Frank Wilczek (Physics Today January 1999):
1) Isaac Newton (1642-1727) believed in a continuous medium filling all space, but his equations did not require any such medium, and by the early 19th century the generally accepted ideal for fundamental physical theory was to discover mathematical equations for forces between indestructible atoms moving through empty space.
2) It was Michael Faraday (1791-1867) who revived the idea that space was filled with a medium having physical effects in itself... To summarize Faraday's results, James Clerk Maxwell (1831-1879) adapted and developed the mathematics used to describe fluids and elastic solids, and Maxwell postulated an elaborate mechanical model of electrical and magnetic fields.
3) The achievement of Einstein (1879-1955) in his paper on special relativity was to highlight and interpret the hidden symmetry of Maxwell's equations, not to change them. The Faraday-Maxwell concept of electric and magnetic fields, as media or ethers filling all space, was retained by Einstein. Later, Einstein was dissatisfied with the particle-field dualism inherent in the early atomic theory, and Einstein sought, without success, a unified field theory in which all fundamental particles would emerge as special solutions to the field equations.
4) Following Einstein, Paul Dirac (1902-1984) then showed that photons emerged as a logical consequence of applying the Rules of Quantum Mechanics to Maxwell's electromagnetic ether. This connection was soon generalized so that particles of any sort could be represented as the small-amplitude excitations of quantum fields. Electrons, for example, can be regarded as excitations of an electron field, an ether that pervades all space and time uniformly. Our current and extremely successful theories of the *strong, electromagnetic, and weak forces are formulated as *relativistic quantum field theories with *local interactions.
5) The author states: "Einstein first purified, and then enthroned, the ether concept. As the 20th century has progressed, its role in fundamental physics has only expanded. At present, renamed and thinly disguised, it dominates the accepted laws of physics."
http://scienceweek.com/2005/sw050708-6.htm
Physics Today http://www.physicstoday.org
