On the Heisenberg uncertainty relation
In summary, there are fundamental limits on the accuracy for measuring both position ##q## at time ##t## and momentum ##p## at time ##t+\Delta t##, with tiny ##\Delta t##. This is due to the inherent uncertainty in the state of a particle, as defined by the no-go theorem. It is impossible to prepare states in which position and momentum are simultaneously arbitrarily well localized, measure them simultaneously, or measure one without disturbing the other. This has been rigorously treated in the publication "The quantum theory of measurement" and further discussed in the paper "Violation of Heisenberg’s Measurement-Disturbance Relationship by Weak Measurements". While it may be possible to reduce the uncertainty by quickly transforming the state,
  • #36
ShayanJ said:
It seems to me that there is no difference between ## \epsilon ## and ## \sigma ##. Why do you use different names for them?
I wanted to distinguish between irreducible quantum uncertainty and experimental shortcomings such as systematic errors. I'm not an experimentalists, so I can't say much about it. ##\epsilon## is the precision of the measurement apparatus. In general, ##\epsilon > \sigma##, but if the experimeter has built an ideal device, then they should be almost equal.
I said that after a measurement, the state will collapse onto ##P_A(S)\Psi## with associated uncertainty ##\epsilon_A##, but of course, this is an idealization. In general, you will have to take measurement theory into account and put more work into analyzing what the state and its uncertainty will be after a measurement.
  • #37
nice post Rubi well detailed.
  • #38
rubi said:
Let's approach it in a deductive way. We define the uncertainty of an observable ##A## in a state ##\Psi## as ##\sigma_A^\Psi =\sqrt{\left<\Psi,A^2\Psi\right>-\left<\Psi,A\Psi\right>^2}##. Without loss of generality, let ##\left<\Psi,A\Psi\right>=0## (otherwise, use ##A'=A-\left<\Psi,A\Psi\right>##). We are interested in bounds on the product ##\sigma_A^\Psi \sigma_B^{U(t)\Psi}##, where ##U(t)## is the time evolution operator. We find:
This is not because you are a bad engineer, but because quantum mechanics limits your ability to prepare a state in such a way that it produces a statistically robust definite outcome for ##B## at time ##t=\Delta t## (assuming you first measured ##A## with accuracy ##\epsilon_A##).
That is much needed and answers a question that has troubled me for ages.
The statement ''non-commuting variables cannot be measured simultaneously' which is bandied about like gospel is actually incomplete and should read "non-commuting variables cannot be measured simultaneously with arbitrary precision". In fact, if the wave function is an not eigenvalue of the operator, then the operator will show some fluctuation. Bohm states this clearly in his book 'Quantum Theory' and leaves the proof as an exercise.
  • #39
Ok, let's say we measured the eigenvalue of the observable ##A## to be ##A_i## using a device with a measurement accuracy ##\epsilon_A##. Then (if we neglect measurement theory) the state ##\Psi## will collapse to the state ##\Psi_{(A_i,\epsilon_A)}=\frac{P_A(S(A_i,\epsilon_A))\Psi}{\lVert P_A(S(A_i,\epsilon_A))\Psi\rVert}##, where ##P_A(S(A_i,\epsilon_A))## is a projector of ##A## and ##S(A_i,\epsilon_A)## is some Borel set in the spectrum of ##A##. For example, it could be that ##S=(A_i-\epsilon_A,A_i+\epsilon_A)\cap\mathrm{spec}(A)##. In any case, we get ##\sigma_A^{\frac{P_A(S(A_i,\epsilon_A))\Psi}{\lVert P_A(S(A_i,\epsilon_A))\Psi\rVert}}\approx\epsilon_A##. By our uncertaincy relation, we have:
$$\sigma_A^{\Psi_{(A_i,\epsilon_A)}}\sigma_B^{U(\Delta t)\Psi_{(A_i,\epsilon_A)}} \geq \frac 1 2 \left|\left<\Psi_{(A_i,\epsilon_A)},\left[A,B(\Delta t)\right]\Psi_{(A_i,\epsilon_A)}\right>\right|$$
Thus, independent of the outcome ##A_i##, we have:
$$\sigma_B^{U(\Delta t)\Psi_{(A_i,\epsilon_A)}}\geq \sigma_B^{\Psi,\Delta t,\epsilon_A} :=\inf_{A_i \in \mathrm{spec}(A)} \sigma_B^{U(\Delta t)\Psi_{(A_i,\epsilon_A)}}=\inf_{A_i \in \mathrm{spec}(A)} \frac{1}{2\epsilon_A}\left|\left<\Psi_{(A_i,\epsilon_A)},\left[A,B(\Delta t)\right]\Psi_{(A_i,\epsilon_A)}\right>\right|$$
In general, ##\sigma_B^{\Psi,\Delta t,\epsilon_A}\neq 0##. For example in our case, we have ##\sigma_p^{\Psi,\Delta t,\epsilon_x} = \frac{\hbar}{2\epsilon_x}+O(\Delta t^2)##.
Now, if we prepare a quantum system in the state ##\Psi##, measure ##A## at time ##t=0## to accuracy ##\epsilon_A## and ##B## at time ##t=\Delta t## to accuracy ##\epsilon_B## and we repeat this procedure ##N## times, we will get a list of ##N## pairs ##(A_i,B_i)_i##. We can now take an estimator for the variance and calculate for example ##\mathrm{Var}_N((B_i)_i)=\frac 1 N \sum_{i=1}^N (B_i-\bar B)^2##. Then the prediction of quantum mechanics is:
$$\lim_{N\rightarrow\infty} \mathrm{Var}_N((B_i)_i) \geq (\sigma_B^{\Psi,\Delta t,\epsilon_A})^2$$
This has nothing to do with the accuracy ##\epsilon_B## at which you have measured the ##(B_i)_i##. You can measure them to any desired accuracy, but statistically, it will be impossible for you to get the variance down beyond the uncertainty limits of quantum mechanics.
Likes ShayanJ and dextercioby
  • #40
Mordred said:
Inherent fuzziness as the state of a particle isn't distinct as defined by the no go theorem.
It is impossible to prepare states in which position and momentum are simultaneously arbitrarily well localized. (B) It is impossible to measure simultaneously position and momentum. (C) It is impossible to measure position without disturbing momentum, and vice versa.
In the double slit experiment, when a electron both leaves the source and impacts the screen wouldn't you know both its momentum and position?
  • #41
Do you realize that your question reduces to: why can't you know the simultaneous position and momentum of a free electron? So you would want to go back to square one in the Uncertainty principle and go from there.
  • #42
There is no "when" at which both of these events take place. They take place at different times.
No. See above.
  • #43
What if the electron where traveling between two parallel infinite sheets of uniform charge? Then the net force on the electron would be zero but the electron would exert a force on the sheets of charge that would not be zero and would indicate both its position and velocity.
  • #44
This is a classical model, not a quantum model, so it's pointless to use it to try to answer a quantum question.
  • #45
Ok sorry, but what if you performed the double slit experiment with protons or something really large like a buckyball . Even if there is no detector to cause the wave function to collapse the proton or buckyball will still have a gravitational field and the field will be stronger at the slit through which it passes regardless of whether there is detector to fire a photon at it and cause the wave function to collapse via the Compton effect so wouldn't that tell you which slit the proton or bucckyball went through without collapsing the wave function?
  • #46
A. Neumaier said:
(ii) a constraint on the measured uncertainty of both position and momentum in a simultaneous measurement. I am interested in the (ii)-part.
Then start with standard theory about such simultaneous measurements.
It should define, for every density operator, a probability distribution on the (p,q) plane. The map should be linear, for not contradicting the meaning of density operators, and have some correspondence between the actions of p and q shifts for the density operator and the corresponding one on the (p,q) plane. This gives a positive operator-valued measure on the plane, and the symmetry properties reduce this to a quite simple simultaneous measurement: Introduce a second test particle in some fixed state, approximately ##p_1\sim 0, q_1\sim 0## and measure ##q-q_1## and ##p+p_1##, which commute.
The accuracy of this measurement you can evaluate independently, by measuring whatever you like of the prepared state of the second test particle. The natural most accurate measurements are those using harmonic oscillator ground states.
  • #47
A. Neumaier said:
there seems to be no restriction on the precision with which ##q## at time ##t## and ##p## at a slightly later time ##t'## can be measured.
I have no concern about whether or not measurements can be done, or if they are done, what effect they have, nor am I concerned about large ensembles of particles.
I am concerned about basic principles, i.e can position and momentum of a single particle be known at the same time?
Momentum is a vector quantity. So assuming that we already know the mass because we know what type of particle we are measuring, how do we know the direction at a single point in time (assertion alert) - we can't.
But that is not what the question is. The question relates to the precision of measurements taken at two different times, one for q and one for p. To determine the direction for p its position must be 'knowable' at two times to determine the vector value. And assuming we can 'know' where it is twice, regardless of how small Δt is, can we know with certainty what happened in the universe which may have impacted on the particle during Δt.
I find the proposal that we can know momentum of a single particle at a specific time more mystifying than QM.
  • #48
I am trying to draw some conclusion from the discussion so far, based on my question, my clarifying remarks in posts #15, #16, #20, #28, and the contributions cited below.
Strilanc said:
If you're picturing a situation where the measurements take time, then once ##\Delta t## is lower than that time your results will become junk. The specific way in which they become junk depends on how you're doing the measurement. There are many ways to model this, creating many varieties of junk. [...] The main points I wanted to make with it are:
1. You can make explicit models of the "measurements happening so close that they overlap" situation.
2. Those models fail to distinguish between upward and rightward with certainty.
[...] If your measurements aren't arbitrarily fast, then they will overlap and generally break each other's effects. The way they break depends on how the measurements are implemented.
From its general sound I like this answer, but could you please give the criterion by which you decide under which circumstances a spin measurement actually measures spin, and under which conditions it must be considered junk. This cannot only depend on the timing because even if there is only a single measurement done, what precisely qualifies it as a measurement of spin up, say?
A. Neumaier said:
I am not even sure what it means to have measured position, let alone how to specify the accuracy of the measurement. If someone knows (with authoritative references) I'd like to be enlightened.
This request still holds. If I have a detector that measures something, what is the criterion that allows me to say that I have measured the position of a particle?
A. Neumaier said:
Taking rubi's explanation ''we have just measured the position. The quantum state will be sharply peaked on some definite position'' for what it implies to have done an accurate position measurement as a temporary definition, and demand the same for momentum, an accurate momentum measurement should imply that the state is projected to a quantum state sharply peaked around the measured momentum. The measurement is presumably the more accurate the more narrow the peak.
rubi seems to suggest that the criterion for being a position measurement is whether the posterior state is sharply peaked on some definite position. But if I take the analogous criterion for measuring the presence of a particle in a beam than a valid photodetection should put any initial state, a superposition of the no-photon state and the 1-photon state into a definite 1-photon state, while actually the posterior state is always the 0-photon state. Thus this cannot be the general criterion.
rubi said:
Let's approach it in a deductive way. We define the uncertainty of an observable ##A## in a state ##\Psi## as ##\sigma_A^\Psi =\sqrt{\left<\Psi,A^2\Psi\right>-\left<\Psi,A\Psi\right>^2}##. [...]
Thus, quantum mechanics predicts that if you have measured ##A## with accuracy ##\epsilon_A## at ##t=0##, then you can measure ##B## with accuracy at most ##\frac{c_\Psi^{\epsilon_A}}{\epsilon_A}## at time ##t=\Delta t##. [For:] If you perform the experiment a large number of times, then no matter how many digits your measurement apparatus can display, if you calculate the uncertainty ##\sigma_B## afterwards, you will get a number that exceeds ##\frac{c_\Psi^{\epsilon_A}}{\epsilon_A}##. You can't build a device that can produce a smaller uncertainty. This is not because you are a bad engineer, but because quantum mechanics limits your ability to prepare a state in such a way that it produces a statistically robust definite outcome for ##B## at time ##t=\Delta t## (assuming you first measured ##A## with accuracy ##\epsilon_A##).
This seems to me like arguing that one cannot measure with high accuracy the number of eyes on an individual classical die (cast from a thoroughly mixing source) because upon performing the experiment a large number of times, you cannot get the standard deviation below ##\sqrt{35/12}##.
My question is not about the final posterior state but about the accuracy of a single pair of measurements ##q(t)## and ##p(t+\Delta t)## on a single particle. The underlying difficulty is to find out how to make the measurement concept clear enough that this can be distinguished from determining a probability distribution and its spread. Because identifying the two means making a measurement on the ensemble, not on the single case.
One has already the same situation classically with a randomly prepared die. But nobody disputes in this case that one can measure the eyes of a single die to higher accuracy than the square root of the variance.
rubi said:
(See post #43 for more.)
The reference is no longer correct; please edit it!
  • #49
This is the closest thing to localizing an atom I ever came across -
arXiv:quant-ph/0512006v2 9 Mar 2006
Time-resolved and state-selective detection of single freely falling atoms
Torsten Bondo, Markus Hennrich, Thomas Legero, Gerhard Rempe and Axel Kuhn
We report on the detection of single, slowly moving Rubidium atoms using laser-induced fluorescence. The
atoms move at 3 m/s while they are detected with a time resolution of 60μs. The detection scheme employs a
near-resonant laser beam that drives a cycling atomic transition, and a highly efficient mirror setup to focus a
large fraction of the fluorescence photons to a photomultiplier tube. It counts on average 20 photons per atom.
  • #50
The specific criteria I have in mind for "is a process a Z axis measurement?" is whether that process distinguishes between the up/down basis states. The process must return "Off!" for a qubit in state $|0\rangle$ and "On!" for a qubit in state $|1\rangle$. That's basically it. (I guess I also want it to leave the target qubit in the claimed state [no extra rotations], and to not mess with other qubits I care about.)
There is a huge variety of such processes. The effects of overlapping those processes with an X axis measurement are varied. The results won't be literally useless junk, in the sense of conveying no information about the system. But they will be junk in the sense of not doing what you expect, of not achieving the intended purpose.
I gave one example of a measurement process (continuous CNOT onto ancilla, measure ancilla at leisure, no three-qubit interaction despite overlapping the two CNOTs) that does one weird thing when measurements are overlapped. With the criteria of "normally it distinguishes between Up and Down", you can easily create other situations that do different weird things. The trick "think about measurement as controlled operations onto a fresh ancilla" is very helpful for understanding these situations.
