On the interpretation of a correlator with different definite states
In summary, the conversation discusses the expressions for transition amplitude and expectation value of operators in field theory. The question is raised about the meaning of a specific formula and whether it has been seen in other books. The expert summarizes that in general, the formula represents the weak value of an operator and provides a link for further information.
Israel.cma
Hello everyone, I was reading Ashos Das book on field theory, chapter 4.3, and I had this question.
This expression:
\begin{equation} \left< \psi_f | \psi_i \right> \end{equation}
is the transition amplitude of two states.
This expression:
\begin{equation} \frac{ \left< \psi|T(U_1...U_n)|\psi \right>}{\left< \psi | \psi \right>} =\left< T(U_1...U_n) \right> \end{equation}
is the expectation value of the operators U when used in that state (for example, the ground state).
But what does it would mean?
\begin{equation} \frac{ \left< \psi_f|T(U_1...U_n)|\psi_i \right>}{\left< \psi_f | \psi_i \right>} \end{equation}
I though that maybe is the expectation value of the operators U IF after the measure the state changes from the state 1 to the state 2.
Does anyone have seen that formula in another books or knows that does it means?
In general,
$$\frac{ \left< \psi_f|A|\psi_i \right>}{\left< \psi_f | \psi_i \right>}$$
is a weak value of the operator ##A##. For more details see https://en.wikipedia.org/wiki/Weak_value
I answered this old question because it was suggested by PF as an unanswered thread and because I believe it may be interest to many readers here, even if the OP is not active any more.
FAQ: On the interpretation of a correlator with different definite states
What is a correlator?
A correlator is a mathematical tool used to measure the degree of correlation between two variables. It is commonly used in scientific research to analyze the relationship between different variables and make predictions.
2. What are definite states?
Definite states refer to the specific values or conditions that a variable can have. In the context of a correlator, this can refer to the different values of the two variables being measured.
3. How does the interpretation of a correlator change with different definite states?
The interpretation of a correlator can change depending on the specific values or conditions of the variables being measured. This is because the degree of correlation between the variables may vary, leading to different conclusions about their relationship.
4. What factors can affect the accuracy of a correlator's interpretation?
The accuracy of a correlator's interpretation can be affected by various factors, such as the sample size, the quality of data, and the type of statistical analysis used. It is important for scientists to consider these factors when interpreting the results of a correlator.
5. How can the interpretation of a correlator be useful in scientific research?
The interpretation of a correlator can provide valuable insights into the relationship between different variables, which can help scientists make predictions, identify patterns, and understand complex systems. It can also aid in the development of theories and hypotheses in various fields of study.
