On the physical meaning of principal stress
In summary, Principal stress is a type of stress that combines normal and shear stresses to produce a maximum or minimum stress. It is important in real world applications as it allows engineers to determine the maximum stress an object can withstand by using Mohr's circle. This is useful for checking against material allowables in design.
lushforest
Hi everyone, I was looking up Mohr's circle on planar stress and stress/strain relation and all that
and I read a context on principal stress. It said that if there is both normal (tensile) stress and shear stress in a given area, then the principal stress at that location is greater than the normal stress.
Well, I was just wondering what really is the importance of principal stress in real world applications...
does principal stress mean the MAXIMUM stress an object can be under in a given area dA?
And when there is a principal stress then there is no shear stress, but I didn't get that either because how could there be no shear stress?
ref: http://wiki.answers.com/Q/What_are_called_principle_planes_and_principle_stress
It depends on the plane within the object for which the stress is calculated. Normal (as in perpendicular) stresses and shear stresses act differently on a given plane. In a sense, the principal stress acts to combine normal stresses and shear stresses to produce a maximum (or a minimum) stress.
A meatier article on stress is here: http://en.wikipedia.org/wiki/Stress_(mechanics)
SteamKing's right on about principal stress. As you look at a material under stress, the stresses are different when you look at it in different directions (the T = n * σ part of Cauchy's stress tensor). The idea is to find an orientation for a differential volume such that the shear stress is zero for that element. That means all the stresses are normal stresses, and these stresses are called principal stresses. Mohr's circle tells you the orientation that satisfies that condition.
You use it all the time in the real world. Usually you're given material allowables in design, but they don't specify at some normal stress what the max shear stresses need to be. You usually get a tension (and maybe a compression) allowable, so using Mohr's circle, you can get principal stresses and check those against your allowables.
Related to On the physical meaning of principal stress
1. What is the physical meaning of principal stress?
The physical meaning of principal stress is the maximum normal stress that a material experiences in a specific direction. It is a measure of the force per unit area that is applied to a material, causing it to deform or change shape.
2. How is principal stress different from other types of stress?
Principal stress differs from other types of stress, such as shear stress and normal stress, in that it represents the maximum stress experienced by a material in a particular direction. It is also important to note that principal stress is a scalar quantity, meaning it has magnitude but no direction.
3. What is the significance of principal stress in engineering and material science?
Principal stress plays a crucial role in the design and analysis of structures and materials. It helps engineers and scientists understand the behavior of materials under different loading conditions and determine their strength and failure mechanisms. This information is essential for developing safe and efficient designs.
4. How is principal stress calculated?
Principal stress can be calculated using the equations for normal stress and Mohr's circle. By plotting the normal stress values on a graph and using trigonometry, the maximum and minimum principal stresses can be determined. Alternatively, it can also be calculated using stress transformation equations.
5. Can principal stress be negative?
Yes, principal stress can be negative. A negative principal stress indicates that the material is experiencing compressive stress, while a positive principal stress represents tensile stress. Both types of stress can cause deformation and failure in materials, so it is essential to consider both when analyzing a structure or material.
17K
