On the ratio test for power series
The discussion centers on the ratio test for power series and the conditions for convergence. It clarifies that the power series converges when the limit of the ratio of coefficients leads to a radius of convergence \( R \), establishing the relationship \( |x-c| < R \) as equivalent to \( 0 \leq r < 1 \). The confusion arises when considering cases where \( R = 0 \) or \( R = \infty \), as the standard limit definitions do not hold. It is concluded that for \( R = 0 \), the series diverges for all \( x \neq c \), while for \( R = \infty \), the series converges for all \( x \). Overall, the ratio test effectively determines the convergence based on the value of \( R \).
schniefen
I have a question about a proof of the ratio test for power series.
The following definition is relevant. If the power series ##\sum_{n=0}^\infty a_n (x-c)^n## converges for ##|x-c|<R## and diverges for ##|x-c|>R##, then ##0\leq R\leq \infty## is called the radius of convergence of the power series.
In these lecture notes, there is the following theorem and proof:
Theorem 10.5. Suppose that ##a_n\neq0## for all sufficiently large ##n## and the limit $$R=\lim _{n\to \infty }\left|\frac{a_n}{a_{n+1}}\right|$$ exists or diverges to infinity. Then the power series ##\sum_{n=0}^\infty a_n (x-c)^n## has radius of convergence ##R##.
Proof. Let $$r=\lim_{n\to\infty}\left|\frac{a_{n+1}(x-c)^{n+1}}{a_n(x-c)^n}\right|=|x-c|\lim_{n\to\infty}\left|\frac{a_{n+1}}{a_{n}}\right|.$$ By the ratio test, the power series converges if ##0\leq r<1##, or ##|x-c|<R##, and diverges if ##1<r\leq\infty##, or ##|x-c|>R##, which proves the result.
I'm confused about "...the power series converges if ##0\leq r<1##, or ##|x-c|<R##...". In other words, why is ##|x-c|<R## equivalent to ##0\leq r<1##?
I guess the author reasons as follows. If $$R=\lim _{n\to \infty }\left|\frac{a_n}{a_{n+1}}\right|,$$ then for ##0<R<\infty##, we have $$\lim_{n\to\infty}\left|\frac{a_{n+1}}{a_{n}}\right|=\lim_{n\to\infty}\frac1{\left|\frac{a_{n}}{a_{n+1}}\right|}=\frac1{R}.\tag1$$ So $$r=|x-c|\frac{1}{R}$$ and then clearly ##0\leq r<1## is equivalent to ##|x-c|<R##. But what about when ##R=0## and ##R=\infty##? Then ##(1)## is not defined/not valid. This confuses me and I'd be grateful for a comment or two.
It is fairly easy to show from the definition of the limit of a sequence and the definition of a sequence diverging to +\infty that <br /> \lim_{n \to \infty} |b_n| = \infty\quad\Rightarrow\quad\lim_{n \to \infty} \frac{1}{|b_n|} = 0 and <br /> \lim_{n \to \infty} |b_n| = 0 \quad\Rightarrow\quad \lim_{n \to \infty} \frac{1}{|b_n|} = \infty.
Thank you for replying.
Ok, I guess in computing ##r## the author assumed ##x\neq c##. Because if ##R=0##, then, as you write, $$\lim_{n\to\infty}\left|\frac{a_{n+1}}{a_{n}}\right|=\lim_{n\to\infty}\frac1{\left|\frac{a_{n}}{a_{n+1}}\right|}=\infty.$$ And so ##r=[|x-c|\cdot\infty]=\infty##, i.e. we have divergence of the power series for ##R=0## for all values of ##x\neq c##. Thanks!
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
