On the representation of integers?
In summary, the conversation discusses the concept of using q = (1, 2) and (x, y, z) = (1, 2, 3, ..., n) to represent positive integers (a, b, c) in the form of a sum of powers of 2. For q = 2, a new notation is introduced as [x] = ∑(q-1)2^n, where x is a positive integer. This leads to the Polynomial Conjecture, which states that there are only finitely many positive integers that can be represented in this form. The conversation also touches on the significance of using brackets and the potential application of this concept.
velikh
TL;DR Summary
We describe the representation of positive integers in the form of the power series ##q2^n##. This allows us to consider positive integers based on the comparison of partial sums of such power series.
Let (a, b, c) be some arbitrary positive integers such that:
(q2^0 + q2^1+ . . . + q2^x),
(q2^0 + q2^1+ . . . + q2^y),
(q2^0 + q2^1 + . . . + q2^z),
where: q = (1, 2), (x, y, z) = (1, 2, 3, . . ., n).
In the case if and only if q = 2, we accept the following notation :
[(q-1)2^0 +(q-1)2^1 + . . . + (q-1)2^x] := \Delta{a},
[(q-1)2^0 +(q-1)2^1 + . . . + (q-1)2^y] := \Delta{b},
[(q-1)2^0 +(q-1)2^1 + . . . + [(q-1)2^z] := \Delta{c},
Indeed, it is obvious that if q = 1, then [(q-1) 2 ^ n] = 0
Polynomial Conjecture. We assume that: there exist only finitely many positive integers so that:
[(q-1)2^0 +(q-1)2^1 + . . . + [(q-1)2^z] := \Delta{c} = 0,
For example:
23=[2^0+2^1+2^2+2^3+(2^3)], where; \Delta{a}:=2^3,
40=[2^0+2^1+2^2+2^3+2^4+(2^0+2^3)], where: \Delta{b}:=2^0+2^3,
63=[2^0+2^1+2^2+2^3+2^4+2^5+( 0 )], where: \Delta{c}:=0
Is this a theorem or a conjecture ?
What does this generally mean ?
Thank you sincerely!
Mathematics news on Phys.org
Has it been proved? If it has been proved to be true, then it is a theorem. If it has not be proved to be true (and has not been proved to be false) then it is a conjecture.
Likes jedishrfu and sysprog
I have difficulties to understand you. E.g. you say: Let ##a,b,c## such that ... and then they do not occur anymore? They remain unexplained. Also you should use LaTeX for a better readability. Here is how it is done:
https://www.physicsforums.com/help/latexhelp/
Likes sysprog
$$a:= \sum_{n=0}^x q2^n , ~~~~~ b:= \sum_{n=0}^y q2^n , ~~~~~ c:= \sum_{n=0}^z q2^n, $$
where: $$q = (1, 2), ~~~(x, y, z) = (1, 2, 3, . . ., n). $$
For example:
$$a:=23=[2^0+2^1+2^2+2^3+(2^3)],$$ where: $$\Delta{a}:=2^3,$$
$$b:=40=[2^0+2^1+2^2+2^3+2^4+(2^0+2^3)],$$ where: $$\Delta{b}:=2^0+2^3,$$
$$c:=63=[2^0+2^1+2^2+2^3+2^4+2^5+( 0 )],$$ where: $$\Delta{c}:=0.$$
One more example:
$$d:=31=[2^0+2^1+2^2+2^3+2^4],$$ where: $$\Delta{d}:=0.$$
Sincerely thank
If you allow ##q \in \{\,0,1\,\}## instead, which makes no significant difference, then you simply have the binary representation of natural numbers.
##q \in \{\,1,2\,\}## and ##\Delta## only confuses this otherwise simple fact by the application of a shift operator and an artificially shortened representation by introducing ##\Delta##.
Likes sysprog
Then maybe like this:
$$[a]:= \sum_{n=0}^x (q-1) 2^n :=2^3$$
Although I still need to think.
Sincerely thank
Let (x, y) be some arbitrary positive integers such that:
$$x:=\sum_{n=0}^kq2^n, ~~~ y:=\sum_{n=0}^{k+1}q2^n, ~~~\text{where: q = (1, 2), k = (0, 1, 2, 3, . . ., n).}$$
For example:
$$x:=[2^0+2^1+2^2+2^3+(2^3)]= 23, ~~~\text{where:} ~~~\sum_{n=0}^x(q-1)2^n = 2^3,$$
$$y:=[2^0+2^1+2^2+2^3+2^4+(2^0+2^3)]=40, ~~~\text{where:}~~~ \sum_{n=0}^y(q-1)2^n =2^0+2^3.$$
In the case if and only if q = 2, we accept the following notation:
$$[x]:=\sum_{n=0}^k(q-1)2^n,~~~[y]:=\sum_{n=0}^{k+1}(q-1)2^n$$
(As a disjunctive proposition.) We say that for any arbitrarily large positive integer X, there exists a positive integer Y greater than X whenever for both the following condition is fulfilled so that:
$$[x]:=\sum_{n=0}^k(q-1)2^n=0, ~~~[y]:=\sum_{n=0}^{k+1}(q-1)2^n=0.$$
That is:
$$\forall x\in\mathbb{N}\setminus{0}\,\exists \,y>x\,|\,y\in\mathbb{N}\setminus{0}\,:\,y=\sum_{n=0}^{k+1}(q-1)2^n = 0.$$
For example:
$$x:=[2^0+2^1+2^2+2^3+2^4]=31, ~~~\text{where:} \sum_{n=0}^k(q-1)2^n =0,$$
$$y:=[2^0+2^1+2^2+2^3+2^4+2^5]=63, ~~~\text{where:} \sum_{n=0}^{k+1}(q-1)2^n = 0.$$
This seems unnecessarily complicated. The series for y is the same as the series for x, but with one additional term, ##k2^{n + 1}##.
velikh said:
For example:
I'm not following your examples at all.
Based on your definition for x, if q = 1 and k = 3, then ##x = \sum_{n=0}^kq2^n = 2^0 + 2^1 + 2^2 + 2^3 = 15##.
Using your definition for y, again with q = 1 and k = 3, then ##y = \sum_{n=0}^{k + 1}q2^n = 2^0 + 2^1 + 2^2 + 2^3 + 2^4 = 31##. Clearly we get the same numbers plus the last term ##2^4##.
Why? What is the significance of brackets around x and y?
This makes no sense to me. If q = 1, then q - 1 = 0, and you have two finite sums all of whose terms are 0. Of course both sums are zero. If q = 2, then you have two finite sums whose terms are nonnegative powers of 2, so neither sum can be zero.
I don't get what you're trying to do here.
velikh said:
That is:
For example:
[/quote]
Likes sysprog
Thank you very much for your participation and the questions asked. I will try, as far as possible, to explain some perhaps controversial definitions.
The fact is that ##x## and ##y## are not power series. However, ##x## and ##y## are positive integers that can be considered as partial sums of the same power series.
By the way, some of these partial amounts include recurring members (in this case ##q = 1, 2##). At the same time, some of them include each member of the sequence ##q2 ^ n## that corresponds to a certain value of n only once (in this case ##q = 1##).
Additional terms of the power series for which ##q = 2## are called a "number growth" and are denoted by ##[x]## or ##[y]##.
So, such partial sums that contain ##2 ^ n## only once (for a certain value of ##n##) are rarely meet. The essence of the question is how long can this last? In other words, how often such ##x## or ##y## for which ##q = 1## occur in relation to others for which ##q = (1, 2)## ?
"Whether there exist a limit of a power series ?" should read as "Whether there exist a limit on the number of partial sums of power series (for which ##q = 1, 2##) ?"
The point is, that you can easily convert your system from ##q_i\in \{\,1,2\,\}## to ##\tilde{q}_i\in \{\,0,1\,\}## which would result in a binary representation of integers. Neither of the above is a power series, they are all finite sums. If you converted the representation into binary, you can still do whatever you want with the highest powers. What you did is simply ##x=b_0\ldots b_n = 111\ldots 1 + R## where the ##b_i## are the binaries of ##x## and then talk about ##R##.
Likes sysprog and velikh
Before that I did not work with binary system of calculus. Nevertheless, if I understand correctly, namely:
$$63 = 111111$$
$$43 = 101011 = 31 + 12 = 11111 + [1100] := N + [x]$$
$$31 = 11111$$
$$20 = 10100 = 15 + 5 = 1111 + [101] := N + [x]$$
However, I do not quite understand how it is possible to describe in binary representation the condition that:
$$\sum_{n=0}^k(q-1)2^n = \sum_{n=0}^k(1-1)2^n + \sum_{n=0}^k(2-1)2^n = 0 + \sum_{n=0}^k2^n~~~
\text{whenever :}~~~ q = (1, 2).$$
I suppose, however, I doubt that
$$\text{if}~~~\tilde{q_i}={0\wedge 1}, \text{then}~~~ q_i = 0,$$
$$\text{else if} ~~~\tilde{q_i}={0 \vee 1}, \text{then}~~~ q_i = 1. $$
What does the subscript i for the q stand for ?
$$x=b_0b_1\dots b_{i-1}b_i=1110101\dots 01$$
$$63 = 111111$$
$$31 = 11111$$
Most of the above is correct, but it would be better to identify binary numbers using a subscript so that they aren't misinterpreted as decimal (base-10) number.
I.e., like this: ##63 = 111111_2##
The parts I don't understand are ##N + [x]## that you used in two of the equations above. What is this supposed to mean?
Again, this seems like an unnecessarily complicated way to write something that is fairly simple.
If q = 2, then ##\sum_{n=0}^k(q-1)2^n = \sum_{n=0}^k2^n##
If q = 1, then ##\sum_{n=0}^k(q-1)2^n = 0##
It is not true to say that
##\sum_{n=0}^k(q-1)2^n = \sum_{n=0}^k(1-1)2^n + \sum_{n=0}^k(2-1)2^n = 0 + \sum_{n=0}^k2^n~~~
\text{whenever :}~~~ q = (1, 2)##
We are currently at 14 posts, and it is still not clear to me what you are trying to say or trying to do.
Likes sysprog
This really has nothing to do with calculus (meaning differential calculus or integral calculus).
The binary representation of integers and even floating point numbers is very well-known in computer science. Any positive integer can be represented in binary as a finite sum of powers of 2; i.e., as $$\sum_{k = 0}^n a_k2^k$$, where ##a_k## is either 0 or 1.
For example, the binary representation of 23 is ##1\cdot 2^4 + 0 \cdot 2^3 + 1 \cdot 2^2 + 1 \cdot 2^1 + 1 \cdot 2^0##, or more compactly, as ##10111_2##.
Negative numbers can also be represented in binary form, using what is called twos-complement notation.
Floating point numbers can also be represented, with the two types most commonly used being 32-bit single-precision (float) or 64-bit double-precision (double).
@velikh, instead of trying to reinvent the wheel by coming up with your own representations for integers, do a search to see what is already there. A search using "binary representation of integers" brings up lots of hits.
As it is not difficult to notice, the first of these two sums ##N = b_ob_1b_2b_3. . . b_i## increases very slowly. While the second of these two sums ##[x] = R## alternately changes either increases or decreases.
Further, patterns of the change in the first sum ##N## are obvious and do not cause difficulties for understanding. However, on the contrary, changes in the second sum ##[x] = R## do not show any laws and seem arbitrary; in order to verify this, it suffices to trace the behavior of these two sums for the first ##100## positive integers.
But since this should not be so, then this is of interest. Whether there exist a pattern of the change in the second sum ##[x]## and what are these changes?
As a complement, there exists another way to describe positive integers in binary.
Let ##x## be some arbitrary positive integer such that:
$$x:=\sum_{n=0}^k\tilde{q_i}2^n,~~~\text{where:}~~\tilde{q_i}\in\{0, 1\},~~~(k, i)=(0, 1, 2, 3, \dots , n).$$
For example:
$$x=40=2^0+2^1+2^2+2^3+2^4+[2^0+2^3]= b_0b_1b_2b_3b_4b_5+[b_0b_1b_2b_3],$$
$$x:=\sum_{n=0}^k\tilde{q_i}2^n | \tilde{q_i}\in\{1\} + \sum_{n=0}^k\tilde{q_i}2^n | \tilde{q_i}\in\{0, 1\}:=N+R,$$
$$\textit{where:}~~~(k, i) = (0, 1, 2, 3, . . ., n).$$
$$x=11111_2 + 1001_2=9_{10}$$
We assume that do not exist two equal sums such that: $$R= \sum_{n=0}^k\tilde{q_i}2^n | \tilde{q_i}\in\{0, 1\}.$$
Since you haven't made clear what it is you're trying to do by this point, I am closing this thread. Possibly this is due to inexperience in communicating in English.
FAQ: On the representation of integers?
What is the representation of integers?
The representation of integers refers to the different ways in which whole numbers can be expressed or written. This can include decimal notation, binary notation, and other mathematical notations.
What is the importance of understanding the representation of integers?
Understanding the representation of integers is crucial in various fields of mathematics and computer science. It allows for efficient computation and storage of large numbers, and is essential in areas such as cryptography and data encryption.
How is the representation of integers different from that of real numbers?
The representation of integers is different from that of real numbers in that integers do not have decimal or fractional parts. Integers can be represented in a finite number of digits, while real numbers require an infinite number of digits to be fully expressed.
What are some common methods for representing integers?
Some common methods for representing integers include decimal notation (base 10), binary notation (base 2), hexadecimal notation (base 16), and octal notation (base 8). Each of these methods has its own advantages and applications.
Can integers be represented in non-numeric forms?
Yes, integers can also be represented in non-numeric forms, such as in words or symbols. For example, the integer 5 can be represented as "five" or "V" in Roman numerals. These non-numeric representations are often used in everyday life, such as in counting, telling time, or writing out dates.
