On the work done on a frictionless surface
In summary, the formula for work done is equal to the product of force applied and displacement. If the force is applied parallel to the floor, the work done will result in kinetic energy. However, if the force is applied perpendicular to the floor, the normal force will cancel it out and there will be no movement or work done. Therefore, the work done can only be infinite if the force is applied over an infinite distance, which is not possible.
aditya ver.2.0
67
Work done = force applied * displacement
So if I exert N1 force on a mass placed over a friction less floor, then the displacement = ∞.
Then won't the work done = ∞.
How is possible?
In which direction are you applying the force and for how long?
If you apply the force parallel to the floor, then you will accelerate the mass and the work you perform with that force will turn into kinetic energy of the mass. If you apply the force normal to the floor, the normal force of the floor will cancel the force and there will be no movement and hence no work done.
Only if you apply the force over an infinite distance.
How is possible?
It isn't.
Related to On the work done on a frictionless surface
1. What is work done on a frictionless surface?
Work done on a frictionless surface refers to the amount of energy required to move an object from one point to another on a surface that has no frictional resistance.
2. How is the work done on a frictionless surface calculated?
The work done on a frictionless surface is calculated by multiplying the force applied to the object by the distance it travels. This is represented by the equation W = F x d.
3. What are some examples of a frictionless surface?
Some examples of a frictionless surface include ice, air hockey tables, and certain types of lubricated surfaces.
4. What are the benefits of working on a frictionless surface in scientific experiments?
Working on a frictionless surface allows for more accurate and precise measurements and calculations, as there is no external force acting on the object to hinder its movement. It also eliminates the need for additional calculations to account for frictional forces.
5. Can a completely frictionless surface exist in real life?
In theory, a completely frictionless surface can exist, but it is difficult to achieve in real life as there will always be some degree of friction present due to imperfections in the surface or the presence of air molecules. However, scientists have been able to create surfaces with very low levels of friction for experimental purposes.
  • Mechanics
  • Mechanics
