- #36
starthaus
- 1,568
kev said:You are both wrong. The wiki solution is a correct and exact symbolic solution for a 1D relativistic elastic collison of 2 unequal masses. I have checked it in a spreadsheet and it gives the correct answers for all masses and velocities. The <<C part comes after the exact solution where they compare the relativistic solution to the classical solution at low velocities where the two solutions should agree approximately.
They actually calculate:
[tex]P_T = \frac{m_1u_1}{\sqrt{1-u_1^2/c^2}} + \frac{m_2u_2}{\sqrt{1-u_2^2/c^2}} = \frac{m_1v_1}{\sqrt{1-v_1^2/c^2}} +\frac{m_2v_2}{\sqrt{1-v_2^2/c^2}} [/tex]
Did you actually read the relativistic section of the Wiki article?
Yes, I did. Did you see where the author makes the approximation [tex]u_1<<c[/tex] and [tex]u_2<<c[/tex]? I bolded it for you. The author is also using :
[tex]v'_1=-u'_1[/tex]
[tex]v'_2=-u'_2[/tex]
with no proof whatsoever.
This means that he's calculating subrelativistic regimes, contrary to your claim.
By contrast, my solution is a simple algebraic derivation from base principles. So, it is correct by derivation.
