Python One-line Python Code that returns a sequence of integers
The discussion focuses on creating a one-line Python generator or iterator that produces a sequence of integers by cumulatively adding the ASCII values of the letters in the word "Close." The initial attempt involves using a for-loop to sum the ASCII values and print the results. However, it is clarified that the loop needs to be repeated, and a cumulative sum can be achieved using NumPy's `cumsum` function. Participants suggest using a list comprehension to generate the ASCII values and then applying `numpy.cumsum` to print the cumulative sums. The final solution confirms that multiplying the list of ASCII values allows for generating the desired sequence, which matches the first ten integers provided in the original post.
mathmari
MHB
Hey! 😊
I want to write a one-line Python generator or iterator expression that returns the sequence of integers generated by repeatedly adding the ascii values of each letter in the word “Close” to itself. The first 10 integers in this sequence are: 67, 175, 286, 401, 502, 569, 677, 788, 903, 1004. If the code should not be in one line it would be as follows, or not ?
Code:
sum = 0
for letter in list("Close") :
    sum += ord(letter)
    print(sum)
So that we write that in oe line the for-loop will be
Code:
sum += [ord(letter) for letter in list("Close")]
right? But how do we add at this line the print? :unsure:
Technology news on Phys.org
mathmari said:
Code:
sum = 0
    sum += ord(letter)
    print(sum)
Hey mathmari!
Shouldn't the loop be repeated? (Wondering)
Code:
This doesn't parse since we can't add a list to a number. :oops:
I googled how to calculate a cumulative sum in python and found numpy.cumsum.
That is, we can do import numpy; numpy.cumsum([1,2,3]).
We can repeat a list by multiplying it with a number. For instance 5 * [ord(letter) for letter in list("Close")].
We can print a resulting list by calling print before it. For instance print [1,2,3].
đŸ€”
đŸ€”
Ahh ! So we should write print(numpy.cumsum([ord(letter) for letter in list("Close") ])) , right? :unsure:
Yep. (Nod)
And if we add a multiplier before the list, we get:
Python:
>>> print(numpy.cumsum(3 * [ord(letter) for letter in list("Close")]))
[  67  175  286  401  502  569  677  788  903 1004 1071 1179 1290 1405 1506]
It matches the first 10 integers in the opening post. đŸ€”
Yep. (Nod)
Python:
Ah ok! I got it! Thank you very much! :geek:
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
