One more question on Magnetic Fields
In summary, a metal rod with mass per unit length p and current I hangs from two vertical wires in a uniform vertical magnetic field. The wires make an angle theta with the vertical when in equilibrium. Using the formula F=IL x B, the magnitude of the magnetic field can be determined by finding the vector sum of the weight force and magnetic force acting on the rod. The sign of B can be determined by applying the right hand rule.
andrew410
59
A metal rod having a mass per unit length p carries a current I. The rod hangs from two vertical wires in a uniform vertical magnetic field as shown in the figure below. The wires make an angle theta with the vertical when in equilibrium. Determine the magnitude of the magnetic field.
Figure: http://east.ilrn.com/books/sepsp06t/pse6e.29.64p.e.jpg
I'm not sure where I need to use the theta for in this problem. I know again that we need to apply the formula F=IL x B, but need help starting it.
Again any help is great! thx~! :)
In this case there are two forces acting on the current carrying conductor, perpendicular to each other. Weight force (down), and magnetic force (left). The vector sum of these two forces points in the direction of the two supporting wires, diagonally down at an angle @ (theta) to the vertical axis. Using trigonometry (and perhaps a vector diagram to help you visualise):
tan@ = (magnetic force)/(weight)
= BIL/mg,
so you can find B. To determine the sign of B (positive or negative), you need to see if the diagram is consistent with the right hand rule.
Hi there,
In this problem, theta is the angle that the wires make with the vertical when the rod is in equilibrium. This angle is important because it affects the force that the magnetic field exerts on the rod. Let's break down the problem step by step:
1. First, let's draw a free body diagram of the rod. We have the weight of the rod acting downwards, and the tension in the wires acting upwards. The wires make an angle theta with the vertical, so we can break the tension force into its vertical and horizontal components.
2. Now, let's consider the forces acting on the rod in the horizontal direction. We have the horizontal component of the tension force, which we can label as Tcos(theta), and the magnetic force, which is given by F=IL x B. Since the rod is in equilibrium, these two forces must be equal and opposite.
3. Next, we can consider the forces acting on the rod in the vertical direction. We have the weight of the rod acting downwards, and the vertical component of the tension force, which we can label as Tsin(theta). Again, since the rod is in equilibrium, these two forces must be equal and opposite.
4. Now, we can combine these two equations to eliminate the tension force and solve for the magnetic field, B. We get:
Tcos(theta) = F = ILB
Tsin(theta) = mg
Solving for B, we get:
B = mg / ILcos(theta)
Therefore, the magnitude of the magnetic field is given by B = mg / ILcos(theta).
I hope this helps! Let me know if you have any further questions.
FAQ: One more question on Magnetic Fields
How do magnetic fields work?
Magnetic fields are created by moving electric charges, such as electrons. These moving charges generate a force that can attract or repel other electric charges.
What is the difference between magnetic fields and electric fields?
Magnetic fields are created by moving electric charges, while electric fields are created by stationary electric charges. Additionally, magnetic fields only affect moving charges, while electric fields can affect both moving and stationary charges.
How are magnetic fields measured?
Magnetic fields can be measured using a device called a magnetometer. This device detects the strength and direction of a magnetic field.
What is the unit of measurement for magnetic fields?
The unit of measurement for magnetic fields is the tesla (T). Other commonly used units include the gauss (G) and the oersted (Oe).
How are magnetic fields used in everyday life?
Magnetic fields have a wide range of applications in everyday life. They are used in compasses for navigation, in electric motors and generators for converting energy, in MRI machines for medical imaging, and in credit and debit cards for data storage.
