I One more talk about the independence of Einstein's SR axioms
dextercioby
Insights Author
TL;DR Summary
The two known textbook axioms of Special Relativity are generally thought to be independent. Or are they not, really?
Sorry if this is discussed here previously, but I just stumbled upon an article from 1911 which I would like to bring forth to you.
Preamble: it is generally thought that Einstein's (refined) two axioms of SR (1. The laws of physics are invariant upon shifting from one IRF to another. 2. The one-way speed of light in vacuum is constant in any IRF) are independent, in the sense that, no matter how much physical/mathematical theory you can derive from 1., axiom 2. can never be reached (proven).
Is it correct? Well, two Austrian physicists, Philipp Frank and Hermann Rothe, write an article of 30 pages published in Vol. 34 of the 4th series of the Annalen der Physik (Publication year = 1911) whose conclusion is (original in German, then my perhaps imperfect translation to English below)
"Unter allen Transformationsgleichungen, die eingliedrigen linearen homogenen Gruppen entsprechen, gibt es drei Typen, bei denen der Betrag der Kontraktion nicht von der Richtung der Bewegung I am absoluten Raume abhaengt. Darunter hat nur ein Typus eine tatsaechliche Kontraktion der Laengen zur Folge, naemlich die Lorentztransformation [Gleichung (1)], die beiden anderen Typen, die Galilei- und die Dopplertransformation (Gleichung (2) bzw. (129)] lassen die Laengen unverandert. Bei der Lorentztransformation hat die Lichtgeschwindigkeit in allen bewegten Systemen bei beliebiger Fortpflanzungsrichtung denselben endlichen Wert c. Bei der Dopplertransformation hingegen nur bei Fortpflanzung nach einer Richtung, bei der Galileitransformation ueberhaupt nur, wenn die Lichtgeschwindigkeit unendlich waere".
"From all the transformations, which correspond to monomial linear homogenous groups, there are three types for which the amount of the contraction does not depend on the direction of motion in absolute space. From them only type shows a contraction of lengths, namely the Lorentz equation [eqn (1)], while the other two types, the Galilei and Doppler transformation, leave lengths unchanged. For the Lorentz transformation, the speed of light in all systems in motion has the the same finite value c for an arbitrary direction of propagation. For the Doppler transformation, on the other hand, (the finite value c is true) only for one direction of propagatioin, while for the Galilei transformation, actually only when the speed of light is infinite".
It appears that the first axiom is supplemented by the request that space-time transformations between systems are linear monomials. Then, because SR appeared after Lorentz contraction was known, it was required by F & R that this contraction does not depend on the direction of movement, which offered three possible transformations > Lorentz was the only one which showed length contraction (the other two didn't) and, moreover, showed that the speed of light is invariant for propagation under any direction, while for the Doppler one, only under one direction (namely the direction of light > source - receiver).
Was this article known to you? What do you think of this?
I didn't know that one, although I knew from comments on here that people had started poking at so-called "single postulate" derivations of relativity fairly soon after it was discovered.
Here's a more recent article saying much the same thing in English.
dextercioby said:
Summary:: The two known textbook axioms of Special Relativity are generally thought to be independent. Or are they not, really?
This is not the 2nd premise of SR.
It is more along the lines of "The measurement of the speed of light in a vacuum will be independent of the inertial frame in which it is measured"
In particular, there is no assumption of the one-way speed of light being constant since this would have been a true assumption, not something that came from empirical findings.
Mind you, I am speaking of the wording of the SR theory, and not of this 1911 article.
Likes phinds and Ibix
dextercioby said:
Was [the Frank & Rothe] article known to you?
Yes. :oldsmile:
Heh, congratulations! You are now the 10,000'th person to become interested in the (so-called) 1-postulate derivation(s) of SR. Collect your prize..., oh wait, there isn't any prize, just a whole lot of fun. :oldwink:
I've talked about this quite a few times in PF threads -- see links below. But more recently, I tend to say something like:
strangerep said:
Mmmpff! Must... resist... temptation to talk about 1-postulate derivations... :headbang: :oldbiggrin:
Essentially, my position is that the usual 2nd postulate of SR is unnecessary, but you need another principle, which I call "Physical Regularity" (described in one of the threads linked below) to get all the way to SR and its physically-plausible generalizations.
https://www.physicsforums.com/threa...t-from-only-one-postulate.754310/post-4750899
https://www.physicsforums.com/threa...r-than-the-speed-of-light.988473/post-6336781
https://www.physicsforums.com/threads/why-is-the-speed-of-light-absolute.984712/post-6303339
If you're interested to delve deeper, PM me and I'll send you some (still-unpublished) work which I can't discuss on the PF public forums
Likes PeroK, robphy and dextercioby
We’ve had this discussion before, but it remains interesting to me as a question about the history of science if not the science itself.
The discussion is complicated by two factors. First, although Einstein called them “postulates” (did he? Or is that an artifact of translation into English from German?) no mathematician would characterize them as such because they’re not phrased with sufficient rigor (that‘s how more than a century later we can still have disagreements over exactly what they mean). Thus, the question of whether they are independent may not have an unambiguous answer, it may depend on our interpretation of them.
Second, I doubt that Einstein attached much weight to the question of the independence of the postulates, at least in 1905. His argument to his contemporaries relied on two claims and putting them forth as "postulates" allowed him to use these claims without further argument. No mathematician would be completely happy with a structure in which one axiom is on closer examination implied by another - but if you're trying to demonstrate an internally consistent and experimentally supported alternative to the Galilean transforms that's not really a problem.
The second postulate in particular was phrased to address the most likely contemporary concerns and it is not at all clear that a modern presentation of special relativity would cater to the same objections in teh same way.
Likes Delta2, David Lewis, vanhees71 and 3 others
I don't know that paper, and I've to read it, but from what you say it's pretty much consistent with the derivation of the Lorentz transformations from the assumptions that the special principle of relativity is valid (existence and indistinguishability of inertial reference frames), Euclidicity of space for any inertial observer (including the corresponding isotropy and homogeneity of Euclidean affine space). Making these assumptions you get (up to isomorphy) either the Galilei or the Lorentz (or rather Poincare) group as the symmetry group. AFAIK the first investigation in this direction is due to Ignatowsky (also around 1910).
Here it seems the authors also consider other possibilities when the isotropy assumption about space for any inertial observer is not made.
Einstein in the German original called the "two postulates" simply "das Relativitätsprinzip" (the principle of relativity).
Likes Nugatory
Personally, I like to have both postulates separate:
1 is about laws that apply within a frame
2 is about how a quantity transforms between frames
As the alternative derivation of the Poincare group as the symmetry group of special-relativistic spacetime (aka Minkowski space) shows, the "invariance of the speed of light" is not about transformation properties of a physical quantity but about a universal constant of Nature, i.e., relevant not only for electromagnetic fields (and thus light) but to all phenomena. It's the universal "limiting speed" of the space and can just be arbitrarily chosen, as is the case since 1983 in the SI. You can even use "natural units" and set it equal to 1, then measuring temporal and spatial lengths in the same unit.
But 1 isn't just about laws within a frame; it's saying that the laws take the same form in all frames, which means the quantities appearing in the laws have to transform between frames in the right way.
The view that there is only one postulate is basically saying that 2 is just a special case of the above--the speed of light is a quantity that appears in the laws so it has to transform properly, and since it's a scalar, "transform properly" means "stays unchanged".
Likes Guillermo Navas, cianfa72 and vanhees71
That one-postulate view is my favorite - you may have seen me paraphrase the second postulate as "And we really mean that first postulate, even when it comes to E&M".
To get from there to SR we still must take Einstein's next step: a proof by construction that there is an internally consistent and experimentally supported theory in which the scalar ##c## is the speed of light in vacuum, as distinct from the speed of light relative to an unobserved hypothetical ether. The wording of the second postulate suggests that Einstein won't be introducing an ether ("and we don't need no steenkin' ether either!") but that doesn't make the postulate necessary - if a proof by construction doesn't need an assumption we just don't introduce it.
But as a matter of history, this one-postulate view is a lot more easily sold to a late 20th-century audience than a late 19th-century one.
I would put this a little differently; I would say that the proof by construction is that there is an internally consistent and experimentally supported theory in which a finite scalar ##c## appears in the transformation law between inertial frames. Since it is a scalar, its numerical value must be the same in all frames; and we observe experimentally that that numerical value is the speed of light in vacuum. The "its numerical value must be the same in all frames" part is how we know it's not a speed relative to an unobserved hypothetical ether; but its presence in the transformation law I think is the key observation that makes this theory distinct from Newtonian mechanics (where the transformation law contains no such scalar).
Likes cianfa72
What I mean is:
P1 deals with "per-frame-laws". You can apply these laws in different frames, but they themselves to not deal with multiple frames.
- You pick a frame, then you apply these laws, and they work
- You pick a different frame, you apply these laws, and they still work
P2 is a different kind of rule, that itself deals with multiple frames.
Another way to put it:
P1 : Galiean Relativity is true...
P2 : ... if you replace the Galiean Transformation with the Lorentz Transformation
Dropping P2 here would mean that SR adds nothing to Gallieo.
I know that you can interpret and reformulate it all differently. But I like Einsteins formulation, and I don't think it is redundant, if you interpret it as I wrote above.
P1 contains more than Galiean Relativity, because it speaks not only about mechanical laws, but also about electromagnetic laws, which Galilei did not know.
But it doesn't just deal with those; as you say:
A.T. said:
P1 : Galilean Relativity is true...
"Galilean Relativity" (see further comment below on that term) puts requirements on the transformation laws between frames; they have to preserve the form of all the per-frame laws.
Then you are switching meanings of "Galilean Relativity". In your P1 above it did not require the transformation law to be the Galilean transformation law; but in your P2 here it does. You can't have it both ways.
Just stick to the explicit part, then we don't have to argue about what Galilean Relativity includes or doesn't:
A.T. said:
P1 deals with "per-frame-laws". You can apply these laws in different frames, but they themselves do not deal with multiple frames.
The explicit part has the same issue I raised: P1 puts requirements on transformations between frames, so it's not just about "per-frame laws". And those requirements already imply P2.
Likes cianfa72 and vanhees71
How?
A.T. said:
How?
Because it says the laws take the same form in all frames. That means the transformations between frames have to keep the laws in the same form, which is a requirement on the transformations.
Likes vanhees71
A.T. said:
How?
P1 containing electromagnetic laws is incompatible to Galilei transformation. For example the Lorentz force ##\vec{F} = q (\vec{E} + \vec{v} \times \vec{B})## on the a "moving" point charge, created by the magnetic field of current in an electric wire: In the rest frame of the charge (##v = 0##), a magnetic field does not create a force on the charge. This can only be solved by the relativistic length contraction of the wire and the influence on it's charge density.
PeterDonis said:
I would put this a little differently; I would say that the proof by construction is that there is an internally consistent and experimentally supported theory in which a finite scalar c appears in the transformation law between inertial frames.
Yes, that’s a better way of putting it... and might be even harder to sell at the beginning of the last century.
I think only the first postulate is "das Relativitätsprinzip" (the principle of relativity). The second one is "das Prizinp der Konstanz der Lichtgeschwindigkeit" (the principle of the constancy of the speed of light).
http://myweb.rz.uni-augsburg.de/~eckern/adp/history/einstein-papers/1905_17_891-921.pdf (p5 para 2)
Likes vanhees71 and Sagittarius A-Star
atyy said:
(p5 para 2)
See also end of p1 (p 891), where he lists mechanical, electrodynamical and optical laws in the first postulate and begin of page 2 (p 892), were he describes the second postulate.
1. is fundamental. 2. is one example of physical laws. Say we include into the laws of physics which 1. says that "propagation of physical effects has maximum constant speed c", we may save number of axioms, i.e.
1. The laws of physics, which include that propagation of physical effects has maximum constant speed c, are invariant upon shifting from one IRF to another.
But P1 doesn't list the specific laws that are true. It just says that whatever laws we use, they should take the same form in all inertial frames. That by itself, without assuming specific laws, doesn't imply a certain transformation. It's only P2 that rules out the Galilei transformation.
Likes Sagittarius A-Star and dextercioby
You can of course build SRT from different "postulates". My favorite is to have the symmetry properties of spacetime as basic assumptions. In case of SRT it's the special principle of relativity and Euclidicity of space and time-translation invariance for any inertial observer. From these assumptions you can derive that there are only the Galilei-Newton and the Einstein-Minkowski space times realizing the symmetries as the Galilei group for Galilei-Newton spacetime and as the (proper orthochronous) Poincare group for Einstein-Minkowski spacetime.
Which one is the better description is of course a question to be decided by empirical evidence, and it's clearly Einstein-Minkowski space time (which then has to be extended to a Lorentz or maybe an Einstein-Cartan manifold when the gravitational interaction is included.
Sure, but the 2nd postulate follows from the assumption that the 1st one holds for electrodynamics (including optics), because for Einstein it's clear that Maxwell electrodynamics is the correct theory concerning electrodynamics.
Einstein's answer:
Einstein (1916) said:
The special relativity theory rests on the following postulate which also holds valid for the Galileo-Newtonian mechanics.
If a co-ordinate system K be so chosen that when referred to it the physical laws hold in their simplest forms, these laws would be also valid when referred to another system of co-ordinates K′ which is subjected to an uniform translational motion relative to K. We call this postulate "The Special Relativity Principle".
The Special Relativity Theory does not differ from the classical mechanics through the assumption of this postulate, but only through the postulate of the constancy of light-velocity in vacuum which, when combined with the special relativity postulate, gives in a well-known way, the relativity of synchronism as well as the Lorentz transformation, with all the relations between moving rigid bodies and clocks.
Source
Likes vanhees71, A.T. and atyy
Yes, you can say:
P1 + Maxwell -> P2
But the natural way is to start with the postulates:
P1 + P2 -> Maxwell
vanhees71 said:
... because for Einstein it's clear that Maxwell electrodynamics is the correct theory concerning electrodynamics.
It's clear to him, but he expresses that in P2. P1 is completely agnostic on this. The idea that P2 is redundant comes from conflating P1 with P1 + what Einstein knew and expressed in P2.
Likes vanhees71
Of course from a modern point of view, you may say P1+P2->Maxwell, but fortunately special relativity works for everything, as far as we know, not only electrodynamics. It leads you to Minkowski space as the space-time model with the proper orthochronous Poincare transformations as the symmetry group. Gauging this symmetry then also very naturally leads to GR (or its extension to Einstein-Cartan theory when spin is taken into account).
  • #31
P1 + P2 -> Maxwell
But P1 + P2 does not give you Maxwell. The Lorentz transformations by themselves, which is basically what P1 + P2 amounts to, do not give you Maxwell's Equations; those are by no means the only possible equations which are Lorentz invariant.
Likes vanhees71
  • #32
P1 + P2 tells you that Maxwell is correct and doesn't need modifications while Newton does.
  • #33
Yes, but if you already know Maxwell is correct, you can use that to deduce P2, as @vanhees71 said. But you cannot use P2 to deduce Maxwell.
More generally, either P1 by itself or P1 + P2 does not tell you what the laws of physics are. It only tells you that, whatever they are, they must be invariant under transformations between inertial frames (P1) and those transformations must be Lorentz transformations (P2). If all you're interested in is those general constraints on the laws of physics, then P1 + P2 is sufficient. But to know what the laws of physics actually are, you need to know more than just P1 + P2.
  • #34
But regarding Maxwell not much, according to the following paper.
paper said:
Special Relativity and Maxwell’s Equations
Richard E. Haskell
19. Discussion
In the preceding sections we have derived Maxwell’s equations directly from special relativity and Coulomb’s law.
Source:
http://richardhaskell.com/files/Special Relativity and Maxwells Equations.pdf
From that you get P1 + P2 + Coulomb's law + conservation of 4-momentum -> Maxwell
  • #35
From that you get P1 + P2 + Coulomb's law (+ conservation of 4-momentum) -> Maxwell
More precisely, P1 + P2 + Coulomb + 4-momentum conservation + the Lorentz force law -> Maxwell.
Whether the things that need to be added to P1 + P2 in this case are "not much" is a matter of opinion.
  • #36
To my understanding, they derive the Lorentz force law from Coulomb's law + transformation law for force.
  • #37
maybe also of interest to realize that possible derive the photon speed ##c## just by noticing that photons travel along null geodesics of spacetime ##\mathscr{E}##. If observer (4-velocity is ##u##, 4-acceleration is ##a##) at ##O \in \mathscr{E}## and photon at ##M \in \mathscr{E}##, velocity ##V \in E## of photon measured with his local frame is nothing but ##V = c(1 + a \cdot \overrightarrow{OM})n - \omega \times_u \overrightarrow{OM}##, where ##n## is unit vector in local rest space of observer, defining direction of photon propagation with respect to observer. Inertial observer characterised by ##a = \omega = 0##, or simply, ##|V|_g = c##.
exercise for the brave...! prove that equation for ##V## is correct ;)
anyway, much nicer to derive this result by first making some assumes about the geometry of spacetime, and not other way around... don't u think :)
  • #38
Ah, yes, you're right.
  • #39
Source:
Fortunately SRT does not only necessarily lead just to electromagnetism but is just a spacetime model which is flexible enough to apply to all of physics. You can argue that GR, needed to include the gravitational interaction, really goes beyond it, but you can as well argue that gravity fits to the general scheme how to describe the interactions within field theories using the gauge principle with the specialty that what's gauged in the case of gravitation is the spacetime (Poincare) symmetry itself and not some intrinsic symmetry of the fields, which is the case for the other fundamental interactions.
Now, how do you get within SRT to Maxwell's theory for the electromagnetic interaction. What you have is the fundamental symmetry of Minkowski space (proper orthochronous Poincare transformations) and the paradigm that everything should be described by local field theories (an argument dating back to Faraday's qualitative insight based on his observations on electricity and magnetism). Then you can systematically study which representations of the symmetry group you can build with fields, fulfilling the constraints of causality. As it turns out, within classical physics, these are the massive and massless representations in terms of tensor fields (including of course scalar and vector fields too).
That's already pretty nicely constraining the possible types of fields and the corresponding action functionals but you need some input from experiment to know, which field might describe the phenomena in question. In the case of electrodynamics everything hints at a massless vector field with 2 polarization degrees of freedom propagating with the speed of light. What then fits of all the representations in form of local tensor-field realizations of the Poincare group is a massless vector field, which necessarily must be a gauge field in order to avoid unphysical continuous intrinsic degrees of freedom and ending up with the said to polarization states. A massless vector field has two helicity states rather than 3 spin states, and these build the basis of the observed polarization states (left- and right-circular polarizations, from which you can build any general elliptic polarization state you like). In addition we know that the em. interactions also obeys the symmetry under spatial reflections, which leaves you with practically one choice for the free-field Langrangian if you restrict yourself with the lowest dimensions.
Coupling this to matter you need a conserved charge and the corresponding Noether current, being determined from the additional constraint of gauge symmetry. In this way you end up with Maxwell's electrodynamics, but as you see, you need far more empirical input than just Einstein's two postulates on the space-time structure.
For me that greatest ingeniuty of Einstein's approach to solve the problem of the violation of Gaileo symmetry of Maxwell's equations was to extract the minimal needed assumption from Maxwell's theory to modify the space-time model such that Maxwell's equations can be symmetric under changes between inertial frames of reference, namely this additional postulate of the independence of the speed of light from the motion of the light source, leading to an additional fundamental constant of nature, the "limiting speed" of Minkowski space (the choice of the value of this speed is just convention defining the system of units, as is the case within the SI units since 1983 and of course also in the newest version of 2019, where almost all base units are defined by choosing particular values of all the fundamental natural constants, except ##G##, which simply is too difficult to measure with sufficient condition today to be included in the list of fixed values to determine the base units of the SI).
That the em. field is indeed a massless vector field and that the speed of light is indeed the limiting speed of Minkowski space is now to be interpreted as a question of experiment. Today there's no experimental hint that this assumption is wrong. Usually the empirical status is given by an upper bound for a possible photon mass which is ##m_{\gamma} < 10^{-18} \text{eV}/c^2##.
  • #40
The argument in this paper feels weird, almost circular. The author is taking the first postulate as “the laws of physics are the same in all inertial reference frames,” but the issue I see is how to define “inertial.” It’s typically the frame of an observer with no net forces acting on them. Ok fine, but in this paper, that basically means that coordinate transformations are functions of ##x^{\mu} ## and ##v^{\mu}## only. Doesn’t this implicitly include a law of physics (namely that ##F\propto a## and therefore coordinate transformations are not functions of second or higher order time derivatives of position)?
There’s nothing in the calculus of variations that restricts the Lagrangian to only being a function of ##x^{\mu}## and ##\dot{x}^{\mu}##; it’s only an empirical observation/physical law. So it almost feels like the first postulate (at least in the linked paper) is saying “the laws of physics are the same in all frames where the laws of physics are the same.” I dunno, maybe I’m missing something, but it feels off to me.
Likes dextercioby
  • #41
A more general approach involves finding the maximal group of coordinate transformations that preserve zero acceleration, i.e., such that under ##(t,x)\to(t',x')## we have $$a := \frac{d^2x}{dt^2} ~=~ 0 ~~~ \Leftrightarrow ~~~ a' := \frac{d^2x'}{dt'^2} ~=~ 0 ~.$$ This turns out to be the group of fractional linear transformations. There's no point involving an acceleration parameter because it's zero by assumption.
With further analysis, one can extract the de Sitter, Poincare and Galileo algebras as physically plausible possibilities. (The first one is the reason why some people advocate so-called "de Sitter Special Relativity", which has an extra universal constant with dimensions of inverse time, as well as the usual universal constant ##c##.)
Likes TeethWhitener and vanhees71
  • #42
Although that is the most general group, I think that taking the affine transformations is better. The non-affine portions of the fractional linear transformations don't make a lot of sense physically.
  • #43
That's what (almost) everyone thinks, and is probably the reason why there's so little relevant literature. (This is strange in itself because there's heaps of literature on the conformal group, yet it also has transformations containing denominators which can become zero.)
More careful analysis of the FL version of velocity boosts (cf. Kerner, Manida, -- refs I've given previously) shows that these transformations are ok if restricted to lightcone interiors. Similarly for the de Sitter (or anti de Sitter) transformations in which either spatial or temporal translations are not well-defined everywhere on Minkowski spacetime.
The crucial step, then, is to understand that the usual abstract concept of Minkowski spacetime is really just a homogeneous space for a particular group of symmetry transformations, i.e., the Poincare group. If one starts from a larger group (or possibly semigroup), and carefully constructs a homogeneous space from scratch, one can reach a physically plausible spacetime geometry -- in the sense that physically measurable intervals remain sensible, and only unphysical intervals (i.e., spacelike intervals) involve pathogical (ill-defined) transformations. But now I'm already straying a little into unpublished research so I'll leave it at that.
Likes vanhees71 and Dale
  • #44
I will be interested to see your paper when it comes out, but spacelike intervals are not unphysical.
  • #45
That depends how you define "unphysical". I mean it as "not directly measurable", and only (potentially) useful in physics by reference to an assumed mathematical model. I.e., one measures timelike and/or lightlike intervals experimentally and then infers spacelike intervals only by reference to the abstract model known as Minkowski spacetime.
Likes vanhees71
  • #46
Understood. That is clear, but I wouldn’t accept that definition.
  • #47
I must confess I haven't read all the responses in this thread, but there is a basic thing in here.
If Maxwell's equations are covariant in all inertial frames, it implies that there is no preferred frame in which it only is (a.k.a the ether). It was thought that light only has a speed ##c## in ether. For all frames which move with a velocity ##\vec v## with respect to ether, the speed of light gets altered by the vector relation ##\vec c' = \vec c - \vec v##.
Now if Maxwell's equations have to remain covariant in all frames (postulate 1), the speed of light has to remain the same in all frames (postulate 2), as Maxwell's equations don't allow for the a change in the speed of light. Far as I can see, the second postulate follows as a consequence from the first.
  • #49
A.T. said:
You assumed Maxwell & the first postulate, not just the first postulate.
The first postulate says "all" laws of physics are covariant in inertial frames, "all" implying the laws of mechanics and electrodynamics.
  • #50
The first postulate doesn't say which laws are correct laws.
Likes vanhees71
