- #36
Ibix
- 14,047
That's true - you were very careful to specify who measured what and to make sure that the people were at rest with respect to each other when comparing clocks. And that means that there is a unique answer to your question - in each case, there is one minute difference between the watches of the stay-at-home and the traveller at the end of the experiment as they measure it. If you've reasoned that out correctly (and you have) for the Tim/Tom case then the principle of relativity says that it must also be true for Bill/Bob, because both pairs of twins can regard themselves as starting at rest and following the same experimental procedure.Gordie19 said:I was not suggesting any measuring being made across frames.
So where does the three minutes twelve seconds come from? I think you are proposing it because you can't see how clocks can tick slower on both planets. And this is where the relativity of simultaneity comes in - not in your experiment, but in your interpretation of your two experiments.
You seem to be OK with the idea that the first experiment leads to a one minute difference, but you're confused how it works in the second run of the experiment where your actors start on the other planet. You have two options: you can copy my approach in the first paragraph, where I simply switch to the most convenient frame to analyse each half of the experiment, or you can stick with one frame throughout. I think you are doing the second, because that does indeed lead to a 3:12 offset between their watches - and you need the relativity of simultaneity to explain how a 3:12 offset can be consistent with a 5:00 offset.
I'm out of time, so I'll leave it there. Happy to explain more if I'm on the right track.
