MHB Online Sage Commands at the Sage Cell Server
  • Thread starter Thread starter Ackbach
    Cell Server
WolframAlpha has limitations, such as the inability to enter multiple commands and save generated graphs without a Pro subscription, which affects its usability for complex calculations. In contrast, Sage Cell Server allows users to input multiple commands, generate downloadable files for LaTeX documents, and offers better integration with LaTeX compared to Mathematica. However, it lacks features like automatic LaTeX formatting for output and struggles with plain English commands, requiring users to input code directly. Despite these drawbacks, Sage Cell Server is seen as a viable alternative for more complex mathematical tasks. For those needing Mathematica's full capabilities, purchasing the software is recommended, although a free version of the Wolfram Development Engine is available for simpler tasks.
Ackbach
MHB
The problem with WolframAlpha is several-fold: 1. You can't enter multiple commands. 2. Without paying for WolframAlpha Pro, you can't save generated graphs to your hard drive as files which you can then insert into other documents, such as a $\LaTeX$ document. 3. I've noticed WolframAlpha having trouble interpreting direct Mathematica commands - as if it doesn't know what I'm asking it to do.
Enter Sage Cell Server. You can do things like the following:
Code:
t,x,v,a=var('t x v a')
x=2*t^3-7*t^2+7*t
v=x.diff(t)
a=v.diff(t)
p1=plot(x,(t,0,2),color="brown")
p2=plot(v,(t,0,2),color="green")
p3=plot(a,(t,0,2),color="blue")
t=text("0",(-0.05,-1),color="black")
p=p1+p2+p3+t
p.axes_labels(['t [sec]','x(brown) [m], v(green) [m/s], a(blue) [m/s$^2$]'])
show(p)
p.save('2-49a.eps')
The result is a downloadable file that I can insert into a $\LaTeX$ document. You can also save as a pdf if you like, simply by changing the extension in the p.save command there at the end.
If you were looking carefully at my Sage code, you would have noticed a tiny bit of $\LaTeX$ code in there, resulting in the exponent of the m/s$^{2}$ being raised. There is a very tight integration between Sage and $\LaTeX$, which in general raises the bar for CAS packages. Mathematica's integration with $\LaTeX$ is not nearly this good, to my mind.
Downers?
1. You can't save your worksheet. Sage Cell Server mitigates this a bit by providing a "Share" button at the upper-right of any output. According to the Help page for Sage Cell Server, this button provides two links, in addition to a QR code:
Permalink
A URL which contains a compressed version of the code. This is a truly permanent link that does not depend on the server storing the code (since the text is encoded in the URL itself). This URL can be used with a different Sage Cell Server simply by changing the domain name. If the code is too long, the length of the URL may cause problems in some browsers.
Shortened Temporary Link
A shorter URL containing an identifier for the code. The code is stored in a database on the server and retrieved using the ID, so the link will be valid only with a single server, and only as long as the server database retains the input.
However, with all the input being straight ASCII text, you can save the commands to a text file if you like, for later reference.
2. You can't have output automatically $\LaTeX$-ed up, like you can in a regularly installed version of Sage. This is distinct from the occasional $\LaTeX$ stuff like in the plot above. In regular Sage, there's a little checkbox called "Typeset" that turns all of Sage's output into beautiful $\LaTeX$ output via MathJax. This checkbox is not available in the Sage Cell Server. Indeed, the $\LaTeX$ output of Sage (using MathJax, the same as MHB) is one thing prompting me to switch from Mathematica to Sage. I would give Mathematica's input a 9, and its output a 7. For Sage, I would give its input a 7 and its output a 10. However, you can get around this in Sage Cell Server by wrapping the 'view' function around anything you want to typeset in $\LaTeX$. For example:
Code:
view((x^2+2*x-1)/(2*x+4))
produces nice enough output.
3. Sage Cell Server doesn't interpret plain English nearly as well as WolframAlpha. That is, Sage Cell Server doesn't interpret plain English at all. So while WA can easily do what you want with "differentiate t^2", Sage Cell Server is going to want
Code:
x,t=var('x t')
x=t^2
x.diff()
to do the same thing. Not quite so convenient in that case.
However, I think Sage Cell Server is a viable alternative for more complex mathematical calculations, as you can enter multiple commands.
Mathematics news on Phys.org
Good to know about Sage Cell Server. But if someone really needs Mathematica in their work, they should buy it because it is worth the money spent. Same with MATLAB if you are not satisfied with Octave or SciLab.
Update: you can obtain a free version of the Wolfram Development Engine. It's basically Mathematica without the notebook. You execute code on your own machine (so no timeouts). It's great for one-offs.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
