- #36
Gokul43201
Staff Emeritus
- 25
1. This arrow is not present in the original paper; only in the NASA article cited in the OP.sylas said:What I found ... bizarre ... was the comment "dangerously bordering on misleading". What the..?
The figure shows zonal temperature anomalies. The paper -- which I have read -- makes a strong case for aerosol and black carbon effects being behind a strong regional warming effect in the Arctic, which is running well above the global trends.
The diagram includes an arrow, which neatly shows one of the features of the record that their hypothesis explains quite nicely; a strong kink in the Arctic temperature record at about the time of a sharp change in aerosol emissions.
2. The arrow is positioned at 1967. The (US) Clean Air Act regulating SO2 emissions was passed in 1970. The kink in the Arctic temperature anomaly appears at 1967.
3. There is yet a stronger kink in the Arctic anomaly at about 1915 (coincidentally, another low point in the AMO). So, the 1967 kink is not the only distinct (let alone most distinct) kink in the anomaly record plotted in that figure.
4. As I understand it, the actual figure 2 in Shindell (2009) is primarily meant to show the large divergences in the correlation coefficient between global anomalies and different regional anomalies; not to "show" that the effect of aerosol forcings can be "seen" in the Arctic anomalies.
5. Was there a "sharp change in aerosol emissions" around 1967? From the little digging I've done, I've seen plots that say things between (a) there was a sharp decrease in US sulfur emissions around 1970, and (b) there wasn't much of a decrease in North American + European + East Asian sulfur emissions until late in the '70s, but there was a slow down in the increase starting around 1970. Most of the figures I looked at didn't cite the original sources, so I'm not sure how accurate they are. (Example: http://adamant.typepad.com/seitz/images/clip_image002.jpg ).
Where did you get that idea? If there is one thing I am aware of, it is that I am by no means qualified to contradict most anything published in refereed papers in Climate Science, least of all, the overall model itself. My only complaint here is with the manner of presentation of one particular figure on the NASA page, and not with the hypothesis of the Shindell-Faluvegi paper. Do you find it inconsistent that I can completely accept the regional aerosol forcings determined by Shindell and Falugevi and also doubt that these forcings can be eyeballed out of the regional anomaly curves (as suggested by the modified figure in the NASA page)?You, evidently, have a different hypothesis.
I must not have made myself very clear then, since I, in no way objected to the hypothesis, nor even presented a different hypothesis. And I certainly didn't attempt to make the point that any hypothesis different from mine (if I were to present one), became "dangerous" or "misleading" because I disagreed with it (if I were to disagree, and in this case, I don't).Bully for you; there's nothing wrong with that, in principle.
Is it "dangerous" or "misleading" for anyone else to present a case for a different hypothesis from yours? I can't make any other sense of the remark.
I did no such thing (should I ask you to read my post again, before mischaracterizing it?). I specifically limited my comment to the figure in the webpage, and I didn't even call that "dangerous". I said that I found it "dangerously bordering on misleading". Furthermore, having read the paper now, I see that the figure (as presented on the NASA page, with the arrow) and the figure caption (this, I expected) are different from those in the paper.I think you SHOULD read the paper before declaring it "dangerous".
Thanks for the discussion. Let me stress that I am not proposing any kind of alternate hypothesis that disagrees with the conclusions of the Shindell paper. I am not even saying that the AMO is a dominant factor in explaining the Arctic anomalies. All I am saying is that the NASA page gives the impression that the 1967 kink is essentially due to cuts in aerosol emissions, while, I believe that (i) the kink itself (not the overall excess in the Arctic trend, which the paper makes clear is due largely to aerosols) may be an artifact of several coincident events (of which, off the top of my head, I named the AMO and the PDO, which you explain are irrelevant in this case), and (ii) unless there is a strong mathematical case for it, eyeballing kinks, even if it seems to make a rather pleasing visual statement, should not serve as a surrogate for the results of a pretty complex model involving several interacting factors.It's specifically about the Arctic, which is treated as a zone above 60 North in the paper.
Skyhunter has already pointed out that the timing of these indicies don't actually fit very well with the particular trend THIS paper is exploring. He might have added... neither does the location! The AMO is defined by Atlantic sea surface temperatures from latitude 0 to latitude 70. The PDO is a defined as a shift in temperatures from East to West and back again, in the Pacific, from about latitude 20 to 60 or so.
Such oscillations are important factors for global weather patterns in mid latitudes, but they are pretty much dead in the water for explaining such a strong Arctic excess over the global trends.
But as a layperson, I have a question relating to your above paragraph:
From a rough estimate, I would guess that about 5/9 (or about 56%) of the Arctic latitudes (i.e., lats above 60N) lie below 70N lat, which you mention is the upper boundary for the AMO data. This looks like a large fraction to a casual observer like me. Is this number irrelevant (or insignificant due to its value, contrary to its appearance to me) to a statement (not exactly yours) that the AMO is essentially inconsequential to Arctic climate (which I assume includes the area weighted anomalies shown in Fig 2)? If such a statement is true, is there a reasonably accessible-to-layperson explanation for why this is so?
Can we keep the pop-psychology out of this thread?I suspect you have a hammer, and are now seeing everything as a nail. It gets comical when you actually call it "dangerous" to discuss screws.
