Onset of fully developed flow in a channel
In summary, the conversation discusses the onset of fully developed flow in a channel with constant flow rate. The Nusselt number remains constant once the hydrodynamic and thermal boundary layers merge and the flow transitions to fully developed. However, if the flow rate is increased, the onset of fully developed flow occurs earlier due to the increased velocity and quicker diffusion of momentum and heat through the boundary layers. This is in contrast to a paper discussing the relationship between Nusselt and Reynolds numbers, which shows fully developed flow occurring at lower flow rates and developing flow at higher flow rates. The reason for this is that at lower Reynolds numbers, viscous forces dominate and the boundary layers merge earlier, while at higher Reynolds numbers, inertial forces take over and the
sanka
52
Suppose we have a case of laminar flow in a channel. For a case of constant flow rate, at some point downstream of the channel inlet, the hydrodynamic and thermal boundary layers will merge and simultaneously developing flow will transition to full-developed flow (not necessarily at the same time). At this point the Nusselt number will be constant.
HOWEVER, am I correct in saying that if the flow rate is increased, the onset of fully-developed flow will occur at some point earlier in the channel than it did for the lower flow rate case? My reasoning for this is that at the higher flow rate, the velocity increases and the momentum diffuses quicker through the boundary layer, causing it to merge earlier in the channel? By the same reasoning, heat will diffuse quicker thorugh the thermal BL, causing it to merge earlier.
This was always my understanding but I was just reading a paper relating Nusselt No. to Reynolds No., which shows the fully developed region occurring at the lower flow rates and the developing region at the higher flow rates.
Thanks in advance for any help
Is this paper you are reading discussing Newtonian fluids?
Yep, it is.
It's okay though, I've managed to figure it out myself. For laminar flow, the onset of fully developed flow occurs at the lower Reynolds numbers because viscous forces tend to dominate and this leads to a thicker BL, causing it to merge earlier in channels/pipes. As the Re No. is increased (but still staying Laminar), the inertial forces take over and the region where viscous effects are important (the BL) is less. Thus, boundary layers do not merge as early in the channel and the transition to fully-developed flow occurs further downstream.
Related to Onset of fully developed flow in a channel
What is the "onset of fully developed flow" in a channel?
The onset of fully developed flow in a channel refers to the point at which the flow in a channel reaches a steady state, with no significant changes in velocity or flow characteristics along the length of the channel.
What factors determine the onset of fully developed flow in a channel?
The onset of fully developed flow in a channel depends on several factors, including the channel geometry, fluid properties, and flow conditions. These factors influence the development of boundary layers and the formation of a fully developed flow profile.
How is the onset of fully developed flow determined in a laboratory setting?
In a laboratory setting, the onset of fully developed flow is typically determined by measuring the velocity profile along the length of the channel using flow visualization techniques or by using mathematical models to analyze the flow data.
What are the practical applications of understanding the onset of fully developed flow in a channel?
Understanding the onset of fully developed flow in a channel is crucial in various engineering and environmental applications. It can help in designing efficient and stable hydraulic structures, such as pipes and channels, and in predicting the transport of pollutants or sediment in natural water bodies.
How does the onset of fully developed flow differ in laminar and turbulent flow?
In laminar flow, the onset of fully developed flow occurs at a relatively short distance from the channel entrance, as the flow remains smooth and well-ordered. In contrast, in turbulent flow, the onset of fully developed flow occurs at a longer distance from the channel entrance due to the presence of eddies and fluctuations in velocity.
  • Mechanical Engineering
  • Materials and Chemical Engineering
  • Mechanics
  • Other Physics Topics
