Grimble
- 485
- 11
I have written this to test my understanding of some of the concepts involved with Special Relativity. Any comments, corrections; agreement or disagreement; will be gratefully received:
1.Every IFoR can be considered to be stationary. An observer positioned within one would certainly say that it is.
2.An IFoR has no forces acting upon it; Physical laws and therefore the existing conditions are the same/identical/unchanging between IFoRs
3.The coordinates that obtain within an IFoR, and that are perceived by an observer within an IFoR, are measured in Proper units.
4.Each body can have only one existence.
5.Each and every inertial body that exists in space possesses innate(ontological?) dimensions .
6.Those innate dimensions are those measured within that body's own frame of reference.
7.Measurements made from any other body, or frame of reference, are made under different conditions using different coordinates
8.So a single body that exists alone in space is not moving and possesses innate dimensions, due to its composition and structure.
9.If a 2nd body were to be present, at rest relevant to the 1st then it, too, would use the same coordinates and measure the same dimensions.
10.But if that 2nd body were to have a constant velocity, relative to the 1st, then it* would use a different set of coordinates to measure the dimensions of the 1st body. These coordinates and measurements being related by the Lorentz transformations.
11.The 2nd body's measurements are just as real to the 2nd body as the 1st body's are to her but does this mean that the 1st body has changed dimension, or that it has developed a new existence with different dimensions? I think not.
12.The different measurements taken by the 2nd body are due to the different conditions under which they are measured. i.e. the relative velocity of the two bodies.
13.For any two IFoRs, with whatever relative velocity, a third can be imagined that is permanently mid-way between the first two, and this 3rd one would have an equal but opposite relative velocity with each of those first two.
14.Any measurement taken by the third of, let us say, one second, from the 1st body and transformed into the 3rd body's coordinates, would be equal to the similar measurement taken from the 2nd body and transformed into the 3rd body's coordinate, because the transformations would be made using equal relative velocities.
15.Consequently we can say that the proper** seconds measured in each of the first two bodies are equal as measured by an independent observer.
16.The same process can be applied to any two IFoRs.
17.Therefore Proper time in any IFoR is exactly equal to proper time in any other IFoR as measured/transformed/calculated by an independent observer.
* I realize that this is anthropomorphising the bodies, so let us consider that they may be astronauts
** see 3. above.
I just hope I am getting some of this right, now
Grimble
** see 3. above.
Grimble
