Op-amp (ua741) with only positive supply voltage
In summary, when operating with only positive supply voltage, the Op-amp will still work, however the +V will be +V and the ground will be -V. This is done with a voltage divider to create a voltage halfway between +V and ground. A relatively large capacitor is usually connected between the junction of the voltage divider resistors and ground, or +V or both.
weitao
32
Normally the connection of supply voltage is +-V but now is +V and ground.
What happen if Op-amp (ua741) with only positive supply voltage? The op-amp still function?
Yes it can still function. The +V remains +V, the ground becomes -V and you need to create a pseudo ground in place of the ground. This is usually done with a voltage divider to create a voltage halfway between +V and ground. A relatively large capacitor is usually connected between the junction of the voltage divider resistors and ground, or +V or both.
Is it necessary that one of the input (role as voltage reference) must be half of the total of the supply voltage?
No. It can be anywhere between +V and ground.
What would the capacitor do in the circuit? also, if voltage divider is used, wouldn't that consume power from the power supply?
If all you want to do is amplify an unchanging DC voltage then you may not need the capacitor. The purpose of the capacitor is to provide a low impedance path to the pseudo-ground. It should do that even at the lowest frequency the op amp will handle. How low of an impedance is for you to decide. If it is not low enough, the pseudo-ground will develop a voltage which may cause positive or negative feedback.
Yes it will, and if you want a low impedance DC pseudo-ground, it will draw substantial power from the power supply. If you get into that situation you may be able to accomplish the same effect with a high resistance divider and an op amp buffer.
Or use a virtual Earth input?
A google search will turn up plenty of information, e.g., http://www.eng.yale.edu/ee-labs/morse/compo/sloa058.pdf[/color]
FAQ: Op-amp (ua741) with only positive supply voltage
1. What is an op-amp (ua741) with only positive supply voltage?
An op-amp (operational amplifier) is an electronic device that amplifies the difference between two input voltages. The ua741 is a specific model of op-amp. When an op-amp has only a positive supply voltage, it means that it can only accept positive input voltages and output positive voltages.
2. What is the purpose of using an op-amp with only positive supply voltage?
An op-amp with only positive supply voltage is often used in applications where the input and output signals are both positive. It can also be used in circuits where a negative supply voltage is not available. Additionally, it can simplify the circuit design by eliminating the need for negative voltage components.
3. Can an op-amp with only positive supply voltage be used in circuits with negative input or output voltages?
No, an op-amp with only positive supply voltage cannot be used in circuits with negative input or output voltages. It is designed to only work with positive voltages, so using it in a circuit with negative voltages can damage the op-amp and affect the accuracy of the circuit's output.
4. How does an op-amp with only positive supply voltage differ from one with both positive and negative supply voltages?
An op-amp with both positive and negative supply voltages has a wider input and output voltage range compared to one with only positive supply voltage. This allows it to handle both positive and negative voltages and produce a more accurate output signal. Additionally, an op-amp with both supply voltages may have different internal circuitry to accommodate the negative voltage.
5. What are some common applications of an op-amp with only positive supply voltage?
An op-amp with only positive supply voltage is commonly used in audio amplifiers, signal conditioning circuits, and sensor circuits. It can also be used in battery-powered devices and portable electronics where a negative supply voltage is not available. Additionally, it is often used in circuits with single-ended power supplies to simplify the design and reduce costs.
