Op amp with zener in feedback loop
In summary: The output is stable provided the input current does not change too rapidly.In summary, the opamp can hold its - input at zero, equal to + input as long as there is no current flowing into the - input node from Vin.
likephysics
636
Getting confused on understanding how opamp works with zener in Feedback loop.
Referring to the ckt here (attached.)
(replace diode with 5V zener)
Using virtual short, when the input voltage is zero, opamp output is 5V?
Basically the opamp sources current into the zener.
When the input is -1V, the opamp output is still 5v?
Opamp has to pump 5V to keep the zener conducting.
The current flows from output of opamp thru the zener into the input resistor and to the -1v souce?
The current flowing in the resistor will be (-1/R)?
I think you already know the answer.
Let's take that one last...Back to opamp basics.
What is the most basic assumption?
The designer has surrounded the opamp with a circuit that allows it to hold its inputs equal. Else it isn't "operating".
The designer nailed your opamp's + input right down to 0 volts.
Question is then, can it hold its - input node at zero?
Sure, so long as it can deliver current to the node that's equal and opposite the current from Vin, Vin/R.
If there's ANY current of either polarity into the -input node from Vin, Vout will be very near either +5 or -0.6 so as to push equal and opposite current through the zener. So the opamp can hold its -input at zero, equal to + input.
Not sure what you mean by 'virtual short'...
Now we have to depart from practical thinking to near-idealistic thinking.
That opamp has open loop gain of around 100,000 to maybe a few million. Let's just pick an even million to demonstrate.
So,,,, if voltage at its - input node were one microvolt and gain is a million, output would be 1 volt and Zener would not conduct.
You'd need five microvolts at -input node to get 5 volts output and make Zener conduct..
AHA ! There's the secret ! Five microvolts is so close to zero that we assume the -input node stays at zero , which is only a a mild exaggeration.
To make it more precise, we could re-state your question as a statement:
Using virtual short, when the input voltage is zero less than 5 microvolts, opamp output is less than 5Volts
To be even a little more precise we'd say
Using virtual short, when the input voltage is zero less than 5Volts/Avol, opamp output is less than 5Volts
Avol being open loop gain of the opamp...
But - then we should add in factors for the amplifier's offset voltage...
The possible refinements are endless.
For practical work It's best to just remember the opamp wants to hold its inputs equal, and be aware you can refine ad nauseum if you want or need to.
Zero needn't go out to six decimal places. We just take things to extremes sometimes to keep our thinking straight.
old jim
Likes likephysics
A zener diode in the feedback loop converts the op-amp into an input sign comparator. The circuit shown is a cheap and dirty way to generate logic level voltages from op-amps running on higher voltage split supplies. For positive input currents, output is –Vpn = logic low. For negative input currents, output is +Vz = logic high.
Likes likephysics
Related to Op amp with zener in feedback loop
1. What is the purpose of using a zener diode in the feedback loop of an op amp?
The zener diode in the feedback loop of an op amp serves as a voltage reference, allowing for precise control and stabilization of the output voltage. It also helps to protect the op amp from voltage spikes and fluctuations.
2. How does the presence of a zener diode affect the gain of the op amp?
The zener diode in the feedback loop of an op amp can either increase or decrease the overall gain, depending on the configuration. In a non-inverting amplifier configuration, the gain is increased while in an inverting amplifier configuration, the gain is decreased.
3. Can any type of zener diode be used in the feedback loop of an op amp?
No, it is important to choose a zener diode with a breakdown voltage that is within the range of the op amp's supply voltage. Using a zener diode with a higher breakdown voltage can lead to instability and potential damage to the op amp.
4. What is the role of the resistor in series with the zener diode in the feedback loop?
The resistor in series with the zener diode helps to limit the amount of current flowing through the diode. This can help to prevent the diode from overheating and failing, as well as ensuring a stable output voltage.
5. Are there any disadvantages to using a zener diode in the feedback loop of an op amp?
One potential disadvantage is that the zener diode introduces noise into the circuit, which can affect the overall accuracy and precision of the output voltage. Additionally, the zener diode may require a higher supply voltage, which can limit the range of input voltages that the op amp can handle.
  • Electrical Engineering
