Open Channel Flow: Specific Energy
In summary, for the second part of the task, you need to recalculate the x-s area A using the new bottom width b and then use the same flow Q to plot the new specific energy curve. The flow remains unchanged due to the assumption of non-permeable bridge piers.
mototsykl
A trapezoidal channel with bottom width b = 30ft, side slopes m = 2, and flow Q = 5100cfs given, and I am supposed to plot a specific energy curve (E vs y). That part I have done.
For the second part, it is given that 3 bridge piers, each 2 ft wide, are spanning the channel. With the same m and b = 30-3(2) = 24 ft, I need to calculate another specific energy curve.
Question: Is it really that easy? Just change the corresponding x-s area A because of the new b, or does the flow change as well?
Thanks in advance!
Yes, it is that easy. You just need to recalculate the x-s area A for the new bottom width b and then use the same flow Q to calculate the new specific energy curve. The flow remains the same since the bridge piers are assumed to be non-permeable and therefore do not affect the flow in the channel.
Related to Open Channel Flow: Specific Energy
1. What is open channel flow?
Open channel flow is a type of fluid flow that occurs in open channels, such as rivers, canals, and culverts, where the fluid is not completely enclosed by boundaries. This type of flow is governed by the principles of fluid mechanics and is commonly used to study the behavior of water in natural and man-made channels.
2. What is specific energy in open channel flow?
Specific energy is a term used in open channel flow to describe the energy per unit weight of water at a specific point in the flow. It is a combination of the kinetic energy and potential energy of the water and is often used to determine the flow characteristics, such as depth and velocity, at a given location in an open channel.
3. How is specific energy calculated?
The specific energy in open channel flow can be calculated using the Bernoulli's equation, which relates the pressure, velocity, and elevation of a fluid at a given point. It can also be calculated using the specific energy equation, which takes into account the channel slope and roughness, as well as the discharge and depth of the flow.
4. What factors affect specific energy in open channel flow?
The specific energy in open channel flow is affected by various factors, such as the channel geometry, slope, roughness, and discharge. Changes in any of these factors can alter the specific energy and subsequently impact the flow behavior. For example, an increase in discharge will result in a decrease in specific energy, while an increase in channel slope will result in an increase in specific energy.
5. Why is specific energy important in open channel flow?
Specific energy is an important parameter in open channel flow because it helps engineers and scientists understand the flow characteristics and behavior of water in natural and man-made channels. It is also used in the design and analysis of hydraulic structures, such as dams and weirs, to ensure safe and efficient water management. Additionally, specific energy plays a significant role in predicting flood levels and evaluating the potential impacts of floods on surrounding areas.
  • Materials and Chemical Engineering
  • Classical Physics
