Open Gas Turbine - calculate T2, T3, T4, efficiency
The discussion revolves around calculating temperatures T2, T3, T4, and efficiency for an open gas turbine, given a pressure ratio of Ο€ = 10 and initial temperature T1 of 293K. The user successfully calculated T2 using the formula T2 = T1*(Ο€)^(k-1/k), resulting in T2 = 565.783K. However, they are unsure how to determine pressures p1 and p2 from T1 and T2, which are necessary for further calculations. They also mention having values for mass flow rate and heat capacity but are unclear on how to relate these to pressure calculations. The thread seeks guidance on these pressure relationships to proceed with the analysis.
Waits
Thread moved from the technical forums to the schoolwork forums
Hello,
I am trying to solve a problem about an open Gas Turbine. The given information would be:
- An open gas turbine draws in air from the surroundings having the m, cp, T1 and constant kL with the next values:
- The air flow is heat over natural gas supplied:
- The pressure ratio is πœ‹ = 10.
- In the turbine, the exhaust gas is brought to ambient pressure relaxed.
- For simplification it is assumed:
ο‚· Medium is an ideal gas.
ο‚· The mass flow of the supplied natural gas can be neglected
become: π‘šΜ‡ 𝑧𝑒 = π‘šΜ‡ π‘Žπ‘ = π‘šΜ‡ 𝐿𝑒𝑓𝑑
ο‚· The heat capacity of the exhaust gas corresponds to the heat capacity
of the air: 𝑐𝑝,π‘Žπ‘–π‘Ÿ β‰ˆ 𝑐𝑝,π‘Žπ‘π‘”π‘Žπ‘
ο‚· The isentropic exponent is the same for all states valid.​
I should calculate T2, T3, T4 and efficiency.
But I am stuck at the temperatures calculation.
- I know T1=20ΒΊ+273=293K.
- I know the relation:
With this I can calculate T2=T1*(πœ‹)^(k-1/k)=293K*(10)^(0.4/1.4)=565.783K
- But now, how can I calculate the p1 or p2, the pressures from T1/T2. If I get p1 or p2, then I can calculate through their relationships with πœ‹, the other pressure and go further to p3. I also been given the mair and cp, but not sure how I can relate this to the pressures.
Thank you very much in advance.
Waits said:
Hello,
View attachment 303733 With this I can calculate T2=T1*(πœ‹)^(k-1/k)=293K*(10)^(0.4/1.4)=565.783K
Can you please provide the exact word-for-word statement of this problem?
Kindly see the attached pdf. My attempt to solve it, is in it. I'm wondering if my solution is right. My idea is this: At any point of time, the ball may be assumed to be at an incline which is at an angle of ΞΈ(kindly see both the pics in the pdf file). The value of ΞΈ will continuously change and so will the value of friction. I'm not able to figure out, why my solution is wrong, if it is wrong .
TL;DR Summary: I came across this question from a Sri Lankan A-level textbook. Question - An ice cube with a length of 10 cm is immersed in water at 0 Β°C. An observer observes the ice cube from the water, and it seems to be 7.75 cm long. If the refractive index of water is 4/3, find the height of the ice cube immersed in the water. I could not understand how the apparent height of the ice cube in the water depends on the height of the ice cube immersed in the water. Does anyone have an...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
