MikeGomez
- 344
- 16
I've posted to Stackoverflow and no one answers, and I've signed up for Khronos but it won't let me open a new thread for a question, so I was hoping maybe someone here knows something about opengl es 2.0.
I've searched the internet for about a week now and ran into a lot of promising leads but nothing works out so I need some feedback on my own code instead. Thanks.
I'm currently using Eclipse ADT for Android target.
I'm able to get several thousand lines on the the screen and I am happy with that. The problem is I can't figure how how to make each line a different color. Here is the current working code.
Code:
static float LineCoords[] = new float [3 * 2 * MAX_LINE_LIST];
static float color[][] = new float [MAX_LINE_LIST][4];
static ByteBuffer bb;
public void draw2(float[] mvpMatrix) {
// Add program to OpenGL ES environment
GLES20.glUseProgram(mProgram);
// get handle to vertex shader's vPosition member
mPositionHandle = GLES20.glGetAttribLocation(mProgram, "vPosition");
// Enable a handle to the line vertices
GLES20.glEnableVertexAttribArray(mPositionHandle);
// get handle to fragment shader's vColor member
mColorHandle = GLES20.glGetUniformLocation(mProgram, "vColor");
// get handle to shape's transformation matrix
mMVPMatrixHandle = GLES20.glGetUniformLocation(mProgram, "uMVPMatrix");
GLES20Renderer.checkGlError("glGetUniformLocation");
// Apply the projection and view transformation
GLES20.glUniformMatrix4fv(mMVPMatrixHandle, 1, false, mvpMatrix, 0);
GLES20Renderer.checkGlError("glUniformMatrix4fv");
if(g_NumLineList > 0)
Bufferptr.put(LineCoords);
Bufferptr.position(0);
// Prepare the prim coordinate data
GLES20.glVertexAttribPointer(mPositionHandle, (COORDS_PER_VERTEX),
GLES20.GL_FLOAT, false, 0, Bufferptr);
// Set color for drawing the line
GLES20.glUniform4fv(mColorHandle, 1, color[0], 0);
// Draw with 2 verts per line
GLES20.glDrawArrays(GLES20.GL_LINES, 0, 2 * g_NumLineList);
// Disable vertex array
GLES20.glDisableVertexAttribArray(mPositionHandle);
private final String vertexShaderCode =
// This matrix member variable provides a hook to manipulate
// the coordinates of the objects that use this vertex shader
"uniform mat4 uMVPMatrix;" +
"attribute vec4 vPosition;" +
"void main() {" +
// The matrix must be included as a modifier of gl_Position.
// Note that the uMVPMatrix factor *must be first* in order
// for the matrix multiplication product to be correct.
" gl_Position = uMVPMatrix * vPosition;" +
private final String fragmentShaderCode =
"precision mediump float;" +
"uniform vec4 vColor;" +
"void main() {" +
" gl_FragColor = vColor;" +
