High School Opening this jar is made easier by cooling or heating?
Heating a glass jar with a wooden lid can make it easier to open, as the glass expands more than the wood, increasing the diameter of the opening. Conversely, cooling both the jar and lid causes the glass to contract more than the wood, making the lid tighter. The discussion highlights the importance of understanding the coefficients of thermal expansion (CTE) of different materials. Some participants noted that real wood behaves differently depending on the grain direction, complicating the issue further. Overall, both heating and cooling may not guarantee an easier removal of the lid due to these complexities.
robertphy
I've found this question online and don't agree with the explanation given.
There’s a tight lid on a jar that you need to get loose.
The lid on this jar is made of wood and is supposed to unscrew from the jar — if only it wasn't stuck. The coefficient of thermal expansion of the glass jar is higher than that of the wood lid.
How can you make the lid easier to remove?
Explanation
If you heat the lid and the jar, then the jar will expand more than the lid does — which would make the lid of the jar even tighter and more difficult to open.
If you cool the lid and the jar, then the jar will contract more than the lid does, leaving the lid relatively large compared to the jar and easier to remove.
I disagree. If you heat the jar, the diameter of the top opening increases more than the diameter of the wooden lid, making it looser. The opposite happen if you cool the jar and the lid.
Can you please clarify what's happening, in your opinion?
Thank you
Science news on Phys.org
Why would the wood expand more than the glass if its CTE is less than that of glass?
Thank you
The CTE of the glass is greater than that of glass, so it should expand more on heating and contract more on cooling.
Likes robertphy and vanhees71
Which one has the female contact surface or thread?
That one has to expand, or the other one has to contract.
Likes robertphy, russ_watters and 256bits
Looks like the devil's in the details.
A cork in a bottle is similar in line to the OP reasoning.
Likes russ_watters and Lnewqban
Thank you, now I understand the point.
Surprisingly, they're limited to opening only American jars: :smile:
My high school English teacher would say that this a dangling modifier. :smile:
Interestingly, real wood has a different coefficient of thermal expansion with the grain than across the grain. This suggests that the lid shape is not preserved. So the real world experience could be that both heating and cooling make the lid more difficult to remove.
  • · Replies 16 ·
15K
  • · Replies 16 ·
14K
