Operating Torque out of Flywheel
In summary, the conversation discusses a system that harvests energy through an oscillating fin and stores it in a flywheel, which is connected to an induction motor via a smaller gear. The team is struggling to determine if the correct amount of torque will be carried through to the motor to generate the desired amount of power. They know the total energy stored in the flywheel and the dimensions of the gear, but are unsure how to find the force exerted on the smaller gear. The solution involves finding the instantaneous power harvested by the fin and dividing it by the angular velocity, but this method produces values that are too high. They also consider the effect of gearing up the rotational speed, which reduces the torque by a factor of 10. They
LiamH1
Hello, we have built a system in which energy is harvested through the use of an oscillating fin, this energy is stored within a flywheel which operates at a frequency f, we are then connecting this flywheel, via a smaller gear (gear ratio = 10) to an induction motor which should generate electricity.
The induction motor has a set Operating Torque (it is variable but an example would be 3.86Nm) and Speed (once again variable but an example is 1380) it must operate at to generate the desired amount of power. We are controlling the speed it must operate at using the gear system to gear up the rotational speed of the flywheel, however we are struggling to confirm if the correct amount of Torque will be carried through to let the induction motor generate the correct amount of power.
We know the total amount of energy stored in the flywheel (area under the power curve) and we know what the power curve for the oscillating fin is. We also know the dimensions of the flywheel and therefore the dimensions for the smaller gear connected to the induction motor.
E = 1/2*w^2*I
Work = Force * Distance
Power = Tw
I have initially used to the instantaneous power harvested by the fin and divided it by the angular velocity to find the instantaneous Torque however these values seem much too high, (typically find about 8e4 Nm using this method).
I believe that the answer is related to the radius of the smaller gear, and the Force exerted on the belt round the gear, this will equal the torque acting on the centre of the smaller gear and therefore the torque acting on the induction motor. However I do not know how to find the force being exerted on the smaller gear. Is it possible to find this using the energy stored in the flywheel for 1 cycle or using the instantaneous power curve for 1 cycle?[/B]
That should give the right answer. Can you show your working?
Gearing up the rpm gears down the torque. So increasing the rpm by a factor of 10 reduces the torque by a factor of 10.
If there are any friction losses in the small gear bearings those appear magnified by 10 at the flywheel. In general stepping up is a bad idea. Could you use a different motor with more turns and a direct drive?
PS: I'm away from my computer for the next few days but hopefully another person can help.
Related to Operating Torque out of Flywheel
1. What is operating torque out of flywheel?
Operating torque out of flywheel refers to the amount of rotational force required to move a flywheel from a stationary position. It is an important concept in the study of mechanical systems and is used to determine the efficiency and performance of various machines.
2. How is operating torque out of flywheel measured?
The operating torque out of flywheel is typically measured using a torque meter or dynamometer. This device applies a known amount of force to the flywheel and measures the resulting torque. The torque can also be calculated by measuring the force applied to the flywheel and its distance from the center of rotation.
3. What factors can affect the operating torque out of flywheel?
Several factors can impact the operating torque out of flywheel, including the weight and size of the flywheel, the speed at which it is rotating, the surface friction of the flywheel, and the load or resistance being placed on the flywheel. Additionally, any changes in the temperature or lubrication of the flywheel can also affect the operating torque.
4. How does operating torque out of flywheel affect the performance of a machine?
The operating torque out of flywheel is closely related to the energy efficiency and power output of a machine. A higher operating torque means that more energy is required to move the flywheel, which can lead to decreased efficiency and increased wear on the machine's components. On the other hand, a lower operating torque can result in improved performance and reduced energy consumption.
5. Can the operating torque out of flywheel be adjusted?
Yes, the operating torque out of flywheel can be adjusted by altering the weight and size of the flywheel, changing the speed at which it rotates, or adjusting the load or resistance being placed on the flywheel. These adjustments can be made to optimize the performance and efficiency of a machine according to its specific needs.
  • Mechanical Engineering
